Author Topic: two low-grade travel tips:  (Read 4766 times)
Offline Daniel Kalal
  • Daytona, Stelvio [Kansas]
    • Trip Reports
« on: June 22, 2019, 08:05:34 AM »
for a simple, waterproof, small-as-possible, earplug holder, you can buy these flexible plastic things at any hobby shop (they're meant to hold beads and things) and cut them with a knife to the exact length.  The diameter is perfect.  You'll get six for two dollars.
If you're doing washing every night (as I do), it's annoying that some hotels have eliminated the possibility of stopping up the bathroom sink.  If you're lucky, the nearby wastecan will be water-tight; there you go.
As I said; low-grade tips.
Re: two low-grade travel tips:
« Reply #1 on: June 22, 2019, 08:13:53 AM »
 Maybe low grade , but useful . Like knowing that really light test monofilament fishing line makes good thread for repairing riding gear .
Offline mechanicsavant
« Reply #2 on: June 22, 2019, 08:29:48 AM »
Being fond of “economical” touring tips these are gooduns. Hey someone oughta do a book, but it’d half to be free!! To get the “cheap tour “ types to get it . :boozing:
« Reply #3 on: June 22, 2019, 08:31:32 AM »
And THAT'S why you never use the ice bucket in a hotel room!
    • Trip Reports
« Reply #4 on: June 22, 2019, 09:42:00 AM »
The flat rubber things they sell to help you open jars make great drain stops.
Good point.  Hardware stores also sell on-purpose rubber disks for drain stops (which, I carry).  The problem is that on occasion you'll come across a fixed mushroom device (as in the photo) that prevents even the standard drain stopper disk from being used.
Offline Texas Turnip
« Reply #5 on: June 22, 2019, 10:28:28 AM »
Daniel,
Are you buying a V85? You are the perfect rider to test one. Moto Guzzi should give you a big discount.
Texas Turnip
    • Trip Reports
« Reply #6 on: June 22, 2019, 10:38:33 AM »
Daniel,
Texas Turnip
Ken, not at this time.  I recently sat on one at Agostini (in Mandello), but didn't take their offer for a ride.  Something I hadn't realized is that instead of the simple seat-height adjustment block on the Stelvio, you need to replace the whole seat for the optional high/medium/low adjustment on the V85.  All they had was the "medium" seat--I'm not even sure if the tall seat is available, yet.  Even so, the bike isn't near as small feeling as I feared it might be.
    • Trip Reports
« Reply #7 on: June 22, 2019, 11:16:07 AM »
The diameter is large enough to seal a drain, even if it has the lump in the middle like your photo showed.
The Ace Hardware rubber disk stopper is 5" (see mine in the photo, below), but it'd take something the size of a frisbee to do the job over that mushroom.
Of course, then there's this style of drain (happens to be in France), which is elegant (I guess) but, hopeless for doing laundry:
..we're having a discussion of drain stoppers.
Offline SmithSwede
  • I don't want a pickle
« Reply #8 on: June 22, 2019, 11:47:14 AM »
And French drains
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
Offline Tusayan
« Reply #9 on: June 22, 2019, 11:48:40 AM »
You can buy the ear plugs in a similar container, at least I did once.  I've been using the container for countless numbers disposable ear plugs ever since.  I also carry a small zip lock bag of new ones on a trip.
Offline Old Jock
« Reply #10 on: June 22, 2019, 12:40:19 PM »
When I used too travel frequently with my job, it was often the case that the basin stopper was missing
I use to carry a squash ball, which worked with various drain diameters, they are squisable to an extent.
Won't help with those with a drain guard but thought I'd offer it up
« Reply #11 on: June 22, 2019, 05:51:09 PM »
 This a useful discussion , we like useful  :thumb:
Offline kirby1923
  • '81 CX100
« Reply #12 on: June 22, 2019, 06:36:59 PM »
I usually call the valet and have them pick up my laundry items and they bring it to the room in the am w/my coffee... all folded.
« Last Edit: June 22, 2019, 06:38:00 PM by kirby1923 »
'81 CX100
Offline Gliderjohn
« Reply #13 on: June 22, 2019, 09:27:48 PM »
Have an old white T-shirt along to slide over the seat when stopped. Keeps it much, much cooler in the sunlight when you climb back on.
Tip two, if windscreen is heavily bug covered drape a towel soaked in hot water over it for about 5 minutes, bugs will easily wipe off.
Back in central KS
Offline SeanF
« Reply #14 on: June 22, 2019, 11:10:19 PM »
I like the earplug storage idea!
My travel laundry method:
A small dry (waterproof) bag works as a dirty clothes receptacle (separates your stinky dirty clothes from the clean.) It also works as a wash basin. Add some water, soap, seal it up & agitate. Let it sit for a while. Then replace the dirty wash water with clean rinse water. Agitate, rinse, repeat as needed.
In a pinch, a plastic shopping bag will work, if you can find one with no holes (and thy are legal in your jurisdiction!)
Remove laundry from the bag & carefully wring dry.
Lay out the extra hotel bath towel and spread your wet clean clothes in it. Roll it up and twist it and/or kneel on it. Then hang everything to dry.
Offline keener
« Reply #15 on: June 22, 2019, 11:24:15 PM »
As long as my room has a shower , there is no problem washing clothes and your feet at the same time  :laugh:
« Last Edit: June 22, 2019, 11:29:44 PM by keener »
smile and tremble
1974 Z1 Kawasaki since new
1998 Suzuki 1200 Bandit
2005 Ducati Multistrada 1000s
2007 Guzzi 1100 Griso
2015 Kawasaki Versys 1000
Offline Testarossa
    • Skiing History
« Reply #16 on: June 23, 2019, 12:17:06 AM »
Digital technology has killed off the simple airtight 35mm film canister -- they were useful in so many ways.
« Reply #17 on: June 23, 2019, 07:19:52 AM »
casino yahtzee
I have a couple of those  :thumb:
Offline sign216
« Reply #18 on: June 23, 2019, 08:09:54 AM »
And leave your shoes outside your door in the evening, so the staff can shine them for you in time for the morning.
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
« Reply #19 on: June 23, 2019, 08:40:19 AM »
 How does one go about convincing the valet to wash and fold an Aerostich ?  :laugh:
Offline kirby1923
  • '81 CX100
« Reply #20 on: June 23, 2019, 08:53:15 AM »
Well the valet is my preferred method and my 'stich hasn't been cleaned (tough job) in quite a while..I like it that way!
I only clean my undies on the road and sadly the places I stay in are  motel 6'ish and have no valet.
So Plan B is to throw away the dirty stuff when down to the "last" clean items stop at a dollar store or such along the way and renew my supply.
'81 CX100
« Reply #21 on: June 23, 2019, 08:55:46 AM »
 Don't give Smithswede and ideas , he'll be asking for a valet in Cedar Vale  :grin:
Offline kirby1923
  • '81 CX100
« Reply #22 on: June 23, 2019, 09:00:29 AM »
Well...He's probably worth it.
'81 CX100
« Reply #23 on: June 23, 2019, 09:07:59 AM »
 Dunno , he keeps asking for aroma therapy sessions , apparently the smell of cow isn't good enough  :grin:
Offline chuck peterson
« Reply #24 on: June 23, 2019, 02:32:10 PM »
You could do the John Steinbeck thing with your wash bucket. Hang it from a rear rack to agitate...dump and rinse at lunch, hang your essentials out to dry all afternoon flapping in the breeze...
 :bike-037:
 :grin:
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
« Reply #25 on: June 24, 2019, 04:06:57 AM »
For earplugs I use a small pill container, screw cap and just the right size.
NZ tends to have plugs in most places but especially overseas we carry a universal type plug, steel back with soft rubber underneath to seal.
Good tip about the waste bucket thanks Daniel.
Offline pebra
« Reply #26 on: June 24, 2019, 11:23:32 AM »
Some related advice needed:
I use those disposable, squishy earplugs while riding. At times the ride is cold and wet, right? Well, when I take the gloves off, my fingers are numb and swollen, and I'm unable to pinch the earplugs to get them out. A bit of a bother, to put it mildly.
I assume some of you must have encountered the same problem  -  how do you solve this???
2009 Griso 8V "Weißgerät"
    • Trip Reports
« Reply #27 on: June 24, 2019, 11:44:24 AM »
There's no need to put them in so deep. They'll still attenuate with a bit protruding.
    • Trip Reports
« Reply #28 on: June 24, 2019, 12:04:39 PM »
I'm not a fan of keeping ear plugs in a sealed container as it can act like a petri dish. I am a fan of disposable individually packaged pairs of ear plugs for sanitary reasons. Wear and throw away.
I start fresh nearly every morning, but I still remove them when I'm not riding...
Offline Rick in WNY
« Reply #29 on: June 24, 2019, 12:08:42 PM »
I'm not a fan of keeping ear plugs in a sealed container as it can act like a petri dish. I am a fan of disposable individually packaged pairs of ear plugs for sanitary reasons. Wear and throw away.  I just bought a 200 count box of LaserLite individual packaged pairs of ear plugs for $23.00
Yes sir! I buy bulk-packs of these on Amazon. I wear them for one day and toss 'em because ear infections SUCK! Don't ask how I know...
Something else I do is carry paracord with me, because some hotels don't have convenient places you can hang laundry to dry. It also works just as well when camping. Oh, and learn to tie some basic knots... very helpful when working with paracord! The Boyscout handbook has a lot of good info on that subject, and there are many more.
Guzzi Owner since May 20, 2017
  2004 California Titanium
