Author Topic: Brakes - LM3  (Read 977 times)
Offline Vince in Milwaukee
Brakes - LM3
« on: June 23, 2019, 08:15:45 AM »
Changing out the front brake pads of my LM3.  Had a devil of a time getting the pins out.  After cleaning them up a bit, should I apply a very light coat of anti seize or some grease to make the job easier next time?
Gone but not forgotten:
Offline wirespokes
Re: Brakes - LM3
« Reply #1 on: June 23, 2019, 10:05:46 AM »
I've done that - not sure if it's kosher - but the brakes still work as they should. I've thought of making stainless copies and just might one of these times.
Re: Brakes - LM3
« Reply #2 on: June 23, 2019, 10:22:29 AM »
I would probably replace the pins with new ones.  The new ones have a black anodize coating which should hold up better than the old zinc plated units.  At $8 a set I would say they would be worth it.  Of course this assumes that you have the old zinc plated version.
« Last Edit: June 23, 2019, 10:23:01 AM by Dave Swanson »
Offline Diploman
Re: Brakes - LM3
« Reply #3 on: June 23, 2019, 12:10:15 PM »
Applying a - very light - coating of grease to the caliper pins also has the benefit of helping to insure that the pads slide on the pins evenly as intended, avoiding asymmetric wear and potential freeze-up.
2015 KTM 390 Duke
Re: Brakes - LM3
« Reply #4 on: June 23, 2019, 01:00:50 PM »
Thanks everyone.  I took a wire brush and cleaned them up and then applied a very light coating of anti seize.  They slid right in.
