Just swap out the ECU's. Ran a V11 Sport's (15M?) in my Calvin for 5K miles (as recommended by Greg Field). Transformed it's personality. Switched back to stock with a re-flash. Dual plugs on Calvin vs single on V11 Sport = pinging under heavy throttle. Try it?
Considering a V11 Sport pistons and heads ( B10 cam already installed) onto my Cali 1100 top end. Any fitment problems?. From everything I gather should be a straight swap. or is it?.. Any comments from our Guzzi Mavens?
I'm pretty sure he'll be doing the swap on a 1990s vintage Cal 1100. Not on a Breva-powered Cal Vintage.
Do you have only V11 engine parts you mentioned or the whole engine?If you have the whole engine just swap it .
Interesting concept.. Are the heads that much better then the stock Cali heads?? Later EV heads?
Interesting concept.. Are the heads that much better then the stock Cali heads?? Later EV heads??
