Author Topic: carburated Ducati 900ss starving for fuel at 5000 rpm -FIXED- !!!  (Read 16757 times)
Offline randy yocum
Re: carburated Ducati 900ss starving for fuel at 5000 rpm -FIXED- !!!
« Reply #60 on: July 03, 2019, 06:35:13 PM »
Thanks, but I found one ,a nice guy Ed Milich from Guzzitech,on ebay $45.00 including shipping from California .Can't beat that with a stick... :thumb:
« Last Edit: July 05, 2019, 05:56:34 AM by randy yocum »
2012 Stelvio NTX
2007 Norge
1998 EV
1981 V-1000 G-5
1997 Ducati 900ss
1983 XL 600R bought new
1978 XS 1100
« Reply #61 on: July 03, 2019, 07:16:12 PM »
True.   :thumb:
Offline Turin
« Reply #62 on: July 04, 2019, 02:29:34 PM »
Ed could probably provide you with jetting specs for open airbox / pod filters.
1985 Sidlow Guzzi
Rough Edge racing
« Reply #63 on: July 04, 2019, 02:44:21 PM »
  I listed the jetting , float levels and placement of the various vent hoses when using pods on a 900 ..But not all 900's are the same ..For the Monster ,96 was the last year of the big valve, hotter cam V2 heads..I'm not sure if the 900 SS continued with the V2 stuff...???
« Reply #64 on: July 04, 2019, 04:41:37 PM »
Thanks, but I found one ,a guy Ed Multch Milich from Guzzitech,on ebay $45.00 including shipping from California .Can't beat that with a stick... :thumb:
Offline Turin
« Reply #65 on: July 04, 2019, 04:53:55 PM »
I had no idea the post '96 motors were lesser spec.
1985 Sidlow Guzzi
Online Tusayan
« Reply #66 on: July 04, 2019, 05:01:16 PM »
All carb 900SSs are in the same state of tune, with sport oriented heads/valves/cams.
As noted later Monsters and also Cagiva Gran Canyons had 750 heads/valves/cams on 900 cc cylinders. This reduces power by perhaps 5 HP, about 68 stock versus 73 or so for an SS. Not a factor for a ‘97 900SS CR.
Removing the air box lid on 2V Ducatis of this era potentially adds power due to more air flow at a given throttle position, the dynamically active part of the air box is below the filter so air box tuning issues do not result when removing the lid.  The factory lid reduces intake noise and makes sure the filter stays dry, but reduces power.  When it is removed the increased air flow needs more fuel or a less combustible mixture occurs, lean misfire etc, which does not allow the added power to occur.  Therefore unless the carbs are jetted for the displacement, heads and air box configuration the bike runs poorly.
« Last Edit: July 05, 2019, 07:31:39 PM by Tusayan »
