Author Topic: Motor centering  (Read 1390 times)
Offline dxhall
Motor centering
« on: July 05, 2019, 06:38:57 PM »
I have begun another Exercise in Brain Damage in which I install a BSA Lightning motor in a Benelli Mojave frame.  Why, you ask?  Because (1) the Benelli frame is a copy of a ‘60s Rickman frame and (2) it’s a cool looking bike.
So here’s the question:  it looks as though I will need to offset the engine a little to get the drive sprocket to line up with the wheel sprocket.  I wouldn’t think that the motor was perfectly balanced in the frame in the first place, but I am not sure what will happen if the center of mass (which always ends up to be somewhere inside the motor) is not on the axis between the wheel centers.  Any thoughts about how that would affect handling?  I need to find my copy of Foales’s book on motorcycle design.
Offline Diploman
Re: Motor centering
« Reply #1 on: July 05, 2019, 06:49:49 PM »
I doubt if offsetting the motor a bit to one side would have much significant effect on the bike's handling , provided that the engine sprocket and the rear wheel sprocket are well aligned.
Such an arrangement, however, might result in a lateral imbalance that could make the bike lean slightly away from the side to which the motor is offset.  To correct this, you could add some mass to the drive chain side:  eg. a 2-into1 exhaust with slinkier on the drive side; a front rotor and caliper on the drive side, etc.  The offset motor might look a bit odd, but at least it would be a conversation piece and any lateral imbalance could be evened up.
2015 KTM 390 Duke
Re: Motor centering
« Reply #2 on: July 05, 2019, 07:19:52 PM »
 Lots of British specials had offset motors , unless we are talking more than an inch you will never feel it .
Online pehayes
Re: Motor centering
« Reply #3 on: July 05, 2019, 08:11:46 PM »
In Vespa virtually 100% of the motor mass is on one side of the center line.
Offline flangeman_70
Re: Motor centering
« Reply #4 on: July 06, 2019, 01:37:54 AM »
Centauro and could also be Daytona (4V Head) are offset approx 10cm to the right. I think it had something to do with getting the gearbox output lined up with the final drive. It’s never been a handling issue for me.
Adam
Adam
SP III 1990
V10 Centauro 1996
Offline Two Checks
Re: Motor centering
« Reply #5 on: July 06, 2019, 02:46:21 PM »
Iirc aren't some of the HD engines offset for the same reason?
1987 1000 SPII "Il Duce' II"
