Author Topic: Test stepper with Guzzidiag  (Read 1461 times)
Pizza Guzzi
« on: July 06, 2019, 01:30:20 AM »
I ran the test stepper motor function on my B12 with Guzzidiag as I've fitted replacement throttle bodies which came with stepper motor.
I expected to hear something happening but no dice, nothing. I temporarily reconnected the old stepper motor ( which I assume had been working as I had a good hot idle ) and total silence there too.
Fuel tank is off the bike so motor of course was not running.
Should the stepper motor be audibly cycling when testing with Guzzidiag ?
Glenn
Offline tris
Re: Test stepper with Guzzidiag
« Reply #1 on: July 06, 2019, 03:22:13 AM »
I think it has to be done with the engine running and the revs go up if it's working
Tris
1993 TW125 "POS" - Resting
beetle
« Reply #2 on: July 06, 2019, 05:11:55 AM »
Tris is correct. Engine needs to be running.
For an engine-off "test", switch the key on, and let the dash to its little dance. Wait a second, then turn the key off. You should hear the stepper whirring as it 'resets'.
Pizza Guzzi
« Reply #3 on: July 06, 2019, 06:31:51 AM »
Thanks for the information, I'll have the bike running again soon !
Glenn
