Author Topic: USB  (Read 1238 times)
Offline steven c
USB
« on: July 07, 2019, 06:40:36 AM »
Can a USB device work off a 6 volt battery? I mounted one on my 78 Honda with a 6 volt battery but it would not charge the phone which charges at 5.5 volts. It works fine on 12 volts.
chemical properties of aluminium metal
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
Offline Zoom Zoom
Re: USB
« Reply #1 on: July 07, 2019, 10:37:30 AM »
Probably not. Generally speaking these things are just transformers. X in = X out. In this case 12 vdc in = 5.5 vdc out. So 6vdc in would yield about 3 vdc out.
John Henry
edit: Thanks Wayne. I knew it was not really a transformer per se but I didn't know beyond that. I was trying to keep it easy to understand. Thanks for the explanation!
« Last Edit: July 07, 2019, 11:15:41 AM by Zoom Zoom »
Online Wayne Orwig
Re: USB
« Reply #2 on: July 07, 2019, 11:08:13 AM »
Not transformers.
They are usually buck down converters. They use a switching transistor, storage inductor, a few caps to filter it, and a diode to catch the inductor kick.
Older versions use a Darlington pair for the transistor. They needed over about 1.4 volts, just to turn on. So 5 + 1.4, means you need 6.4 volts just to start.
But I have seen some that are LDO (low drop out voltage) with a good mosfet that operate down to near 5 volts.
Alternately, I got a small bag of cheap BOOST converters from China years back for a project. I took one of those and wired it up for a friend to run a 12 volt GPS from his model T 6 volt system. You could do that, boost the 6 to 12, then use a normal charger. Inefficient though, if that matters. It will likely need almost 10 watts in, just to get 5 watts out.
I would get a couple of cheap chargers and test them, I'll bet you find one that works just fine at 6 volts. It is going to depend on the chip used and the power transistor type.
« Last Edit: July 07, 2019, 11:09:24 AM by Wayne Orwig »
Offline steven c
Re: USB
« Reply #3 on: July 07, 2019, 11:28:28 AM »
I ended up getting a cheap back up battery kept the phone plugged into and I was good for the day.
 And thank you for the explanation now I no why it didn’t work for me.
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
