Author Topic: Eldo 1400 TPS Remove & Replace  (Read 1267 times)
Offline gthorpe
« on: July 07, 2019, 09:53:07 PM »
Now that I've confirmed thru GuzziDiag that the P0155 Fault code is pointing to a defective TPS I need to replace it.
Does anyone know if I can disconnect the two throttle cables from the TPS? If so how do I do that?
Glenn T.
2016 Eldorado 1400
2014 Ducati Monster 796
Re: Eldo 1400 TPS Remove & Replace
« Reply #1 on: July 07, 2019, 10:13:13 PM »
I've only done it once on a 'Prilla. Isn't there a cover that comes off? Start by loosening the adjusters up at the twisgrip all the way. That gives you more wriggle room.
Offline gthorpe
« Reply #2 on: July 09, 2019, 12:17:14 AM »
Thanks, I'll give that a try.
Glenn T.
2016 Eldorado 1400
