Author Topic: Clean those pipes  (Read 2245 times)
Offline molly
Clean those pipes
« on: July 09, 2019, 10:47:13 AM »
Not sure what this product is called in other countries but it is the bee's knees for cleaning stainless steel exhausts here in the UK.
It is basically a toilet cleaner, the  active ingredient is  hydrochloric acid (10%). So they may be similar products out there.
« Last Edit: July 09, 2019, 11:12:40 AM by molly »
Dave
Lincolnshire, U.K.
Griso 1100
Offline uncle
Re: Clean those pipes
« Reply #1 on: July 09, 2019, 08:09:09 PM »
I'll try just about anything once... My 12 year old Griso is getting harder to keep clean with elbow grease.
Any trick to it?  wipe on - let sit - rub a bit - rinse?
Ever onward...
Offline Roebling3
« Reply #2 on: July 09, 2019, 08:21:09 PM »
Out standing and clever connection; piggy backing your message about s/s cleaning fluid. 'Passivation Services'. Featuring citrus and nitric acid.. . . .Rinse thoroughly!  R3~
Offline Tusayan
« Reply #3 on: July 09, 2019, 08:22:04 PM »
Industrial toilet bowl cleaner, for stainless bowls and sinks, available at places like Smart and Final.  Very aggressive on fasteners, strips the zinc plating and leaves them grey.  Makes S100 seem mild.  I don't think I'd use it on a motorcycle except with surgical precision on areas it won't harm.  I'd probably remove the exhaust first to prevent damaging other surfaces.
Also useable as port man's Alumaprep, for removing corrosion from aluminum before painting.
« Last Edit: July 09, 2019, 08:26:26 PM by Tusayan »
Offline Zinfan
« Reply #4 on: July 09, 2019, 09:03:24 PM »
I use Barkeeper's Friend on my SS pipes.  I would not use a product containing HCl acid on an exhaust system.  Could just be the 35+ years I spent doing  Chemistry control on nuclear power plants but HCl on metal is not conducive to long life.  High heat only makes it worse, rinse very very well.
Offline molly
« Reply #5 on: July 10, 2019, 04:51:24 AM »
Use a pan cleaning sponge, wipe on, leave 30 seconds then  rinse off with water.
It gets rid of the bronze colour on stainless pipes straight away and with a bit of metal polish afterwards makes all good with little effort.
If you apply it carefully and give it a good rinse afterwards there shouldn't be a problem, it is after all a domestic product not hopefully designed by the Russian GRU.
Dave
Lincolnshire, U.K.
Griso 1100
Offline JohninVT
« Reply #6 on: July 10, 2019, 07:25:33 AM »
I'd have a hard time putting something that dissolves dead bodies on chrome or stainless.  Yes, I may have watched too many documentaries about serial killers.  Anyway, I just use Mother's.  It's formulated properly for the intended purpose.
Offline rschrum
« Reply #7 on: July 14, 2019, 05:44:23 PM »
Tried it, worked great! So let the hand wringing, and pearl clutching begin.
15 GRISO
21 streetfighter v4s
24 zx14r 40th anniversary
01 ZRX 1200R
74 Norton Commando
23 Bimota KB4
97 Ducati 916SPS
Central Iowa
Online Chuck in Indiana
« Reply #8 on: July 14, 2019, 07:24:29 PM »
Uhh, what is "it?"
Offline Dilliw
« Reply #9 on: July 14, 2019, 08:15:26 PM »
Optiglanz for my Griso.  Its expensive but you get about 3 years per bottle.
George Westbury
Austin, TX
Offline rschrum
« Reply #10 on: July 14, 2019, 08:18:28 PM »
Uhh, what is "it?"
Bowl cleaner with 10% hydrochloric acid.
15 GRISO
01 ZRX 1200R
74 Norton Commando
23 Bimota KB4
97 Ducati 916SPS
Central Iowa
