Author Topic: Blue pipe fix options  (Read 2460 times)
Online Ncdan
« on: July 11, 2019, 08:40:03 PM »
Anyone have a  technique for removing the blue on Crome headers due to excessive heat?
Offline harry h
Re: Blue pipe fix options
« Reply #1 on: July 11, 2019, 08:58:47 PM »
Just did this.  Used Simichrome and a small polishing wheel in a drill.  Worked great and easy.
1972 Eldorado
2016 Eldorado
Offline larrys
« Reply #2 on: July 12, 2019, 08:19:01 AM »
Your pipes are supposed to look like that!
Larry
'13 Monster 1100 EVO
'95 Cal 1100
'68 Bonneville
MGNOC 7248
Offline lorazepam
  • Almost ready for suspenders
« Reply #3 on: July 12, 2019, 08:26:46 AM »
Larry
Yep. They will just turn blue again. I kind of like how it looks, like it is actually ridden.
« Reply #4 on: July 12, 2019, 11:43:12 AM »
Semichrome, eh? I have one pipe on the G5 that came to me that way. Apparently someone adjusted that carb a little too rich at some time it it's life. I'll see if I can make it look like the other one. Thanks.. :thumb:
Offline Dilliw
« Reply #5 on: July 12, 2019, 03:30:12 PM »
I've had luck with Bluejob on the EVT.
George Westbury
Austin, TX
Offline slowmover
« Reply #6 on: July 12, 2019, 04:44:19 PM »
You’ll eventually give up.
Online Ncdan
« Reply #7 on: July 12, 2019, 06:16:34 PM »
Negative regards to suppose to be blue, not with a pipe inside a chrome pipe. Someone left it  idling with the choke on:(
« Last Edit: July 12, 2019, 06:17:10 PM by Ncdan »
Offline bigbikerrick
« Reply #8 on: July 12, 2019, 06:58:05 PM »
I have had good luck with a product called "Wenol Metal Polish" comes in a tube like toothpaste. I can get my stainless pipes to look like chrome with that stuff. Of course the discoloration returns, but sometimes not as bad.
 Wenol is what I use for the aluminum on my eldo also. It leaves a protective coating so the aluminum does not re oxidise so fast. Its good stuff, German made.
Rick.
Online Ncdan
« Reply #9 on: July 12, 2019, 07:35:53 PM »
Anything ever tried aluminum foil and vinegar?
Offline rschrum
« Reply #10 on: July 12, 2019, 07:38:33 PM »
Ceramic coat em.
15 GRISO
21 streetfighter v4s
24 zx14r 40th anniversary
01 ZRX 1200R
74 Norton Commando
23 Bimota KB4
97 Ducati 916SPS
Central Iowa
Online Ncdan
« Reply #11 on: July 12, 2019, 07:58:07 PM »
Ceramic coat em.
I thought about that but I want to keep it factory as it is a very unique bike and mint condition except the blue header pipes. I hope to find a couple good ones to replace the blue two but that’s going to be difficult as it’s a 38 years old bike that was only produced one year, 1983.
Offline rschrum
« Reply #12 on: July 12, 2019, 10:28:32 PM »
cb1100f?
15 GRISO
01 ZRX 1200R
74 Norton Commando
23 Bimota KB4
97 Ducati 916SPS
Central Iowa
« Reply #13 on: July 13, 2019, 05:00:15 AM »
I used to do all that stuff (semi chrome and all the others) way back when.  The discolor would always return.  Hope it works out better for you than it did for me.
Online Ncdan
« Reply #14 on: July 13, 2019, 07:23:41 AM »
cb1100f?
1983 CB1000 custom, duel high low 10 speed transmission. From 80-82 they were 900s but in 83 they were bumped up to 1000cc. As a motor officer we used the 900s for several years dressed with Vetter fairing and bags and trunk. They were indestructible bikes and with the high low tranny did a great job in the city.
