Cylinder Head Removal - Drop the Motor?
Topic: Cylinder Head Removal - Drop the Motor? (Read 1267 times)
Dirk_S
www.dirkshearer.com
Doodler of doodles
July 14, 2019, 05:46:25 PM »
I assume I don’t need to remove the motor in order to take the heads off, but I’m having difficulty fitting a socket over the center stud nut at the top. Do I perhaps need to remove the tank to get an open end wrench onto it?
Last Edit: July 14, 2019, 05:48:44 PM by Dirk_S
Re: Cylinder Head Removal - Drop the Motor?
Reply #1 on:
July 14, 2019, 06:02:48 PM »
Take the tank off or it's bound to get scratched. Makes everything much easier anyway. Unless it's changed, which I doubt, the top nut is a 12mm one so make sure you're using the correct size socket but any decent, thin wall socket should do the trick.
