Author Topic: LMIV - One side pushing more air than the other  (Read 1824 times)
Offline bentombed
« on: July 14, 2019, 08:39:04 PM »
not sure if this is a problem or if i am inventing a problem
when the Bike is at idle there is significantly more air coming from the left pipe than the right, the idle is pretty well balanced and the bike rides really well, it's just not pushing the same volumes of air from each side.  is this something i need to worry about?
Online John A
Re: LMIV - One side pushing more air than the other
« Reply #1 on: July 14, 2019, 09:18:55 PM »
Nope, it only happens at idle
« Reply #2 on: July 14, 2019, 09:40:09 PM »
One hopes it isn't pushing 'Air' or you certainly have a problem! :evil:
I'll get my coat.........
Offline wirespokes
« Reply #3 on: July 14, 2019, 11:05:06 PM »
Really? The exhaust is stronger on one side than the other? I'll have to check mine.
« Reply #4 on: July 14, 2019, 11:38:36 PM »
 Left side is the lead cylinder .
« Reply #5 on: July 15, 2019, 12:35:15 AM »
Yup, firing intervals of 270/450 make it so.
Offline wirespokes
« Reply #6 on: July 15, 2019, 06:04:18 AM »
Let's see if I'm understanding this: The left side fires, then 270 degrees later the right side. When the right side fires, the left side is still exhausting and draws some of the pressure through the crossover to the left side, which makes the right side exhaust weaker?
Good thing I never tried balancing the carbs by testing exhaust pressure.
« Reply #7 on: July 15, 2019, 06:26:45 AM »
Nah, it's the amount of time between the power strokes. In the long interval the crank slows appreciably more due to frictional losses and so, as the piston is then moving slower there is more time for the gas in the burning charge to heat up and expand before the exhaust valve opens. Basically both sides, in theory, will expel the same amount of gas, it's just the  time taken before the exhaust valve opens enables the gas to be *Bigger* on the 'Lazy' side.
Offline wirespokes
« Reply #8 on: July 15, 2019, 10:40:43 AM »
That makes sense, and I can even understand it. Here's something I knew nothing about and would be scratching my head over once I did, and here you've got it all figured out.
« Reply #9 on: July 15, 2019, 03:45:19 PM »
He's not nearly as dumb as he looks..  :evil:  :smiley:  :boozing:
Online John A
« Reply #10 on: July 15, 2019, 09:31:59 PM »
I think I'm wrong, seems like if I'm riding a Guzzi that is in tune miles after miles I can sort of sense or feel two singles under me.
Offline bentombed
« Reply #11 on: July 16, 2019, 05:44:32 AM »
ahhh - that explains everything! thank you.
Offline bentombed
« Reply #12 on: July 16, 2019, 05:50:58 AM »
thank you - I feel that information should be in guzziology somewhere to ease the minds of mechanical dummies.
« Reply #13 on: July 16, 2019, 06:23:21 AM »
I beg to differ.
Offline 12SCraig
« Reply #14 on: July 16, 2019, 06:36:04 AM »
Good on You knackers.
Dr Knackers. :cheesy:
Offline wirespokes
« Reply #15 on: July 16, 2019, 10:48:04 AM »
I beg to differ.
At least he's not self conscious about it!
