Author Topic: Shane Conley -- a particularly good Youtube teacher  (Read 1423 times)
Moto
« on: July 14, 2019, 11:18:08 PM »
I happened to run into this guy on Youtube and am impressed enough to pass his name along: Shane Conley. I don't recall his name coming up here before.
I first found this excellent demonstration of backward brake bleeding, followed by flushing, a topic that comes up here from time to time:
https://www.youtube.com/watch?v=skaKvS_qH_0
Here's his main page, I think:
https://www.youtube.com/user/conleybuilt/playlists
He has hundreds of videos that he has produced while instructing students at his (former) motorcycle mechanic's college in Iowa. He seems to be a really good teacher, smart, unassuming, and thoughtful about what he says to his students. EDIT: He closed his college when Suzuki offered him a "dream job" in California, a couple of years ago. He seems to have expanded his operations to include a web site of his own now, but I don't know the details.
For what it may be worth, for any who might be interested!
Moto
« Last Edit: July 14, 2019, 11:23:54 PM by Moto »
Re: Shane Conley -- a particularly good Youtube teacher
« Reply #1 on: July 14, 2019, 11:40:30 PM »
Offline balvenie
« Reply #2 on: July 14, 2019, 11:59:51 PM »
Thank you Moto :grin: :thumb:
Oz
04 Cali
« Reply #3 on: July 15, 2019, 09:50:27 AM »
I've had a look and can already tell there's some of these that I could benefit from.
Thanks!
Offline Madtownguzzi
« Reply #4 on: July 15, 2019, 11:16:48 AM »
I do not think it is a good ideal to back bleed a motorcycle with ABS as most of the contaminants from the caliper will be flushed threw the ABS module up threw the master cylinder.  Here is an excellent video on bleeding a Harley with ABS that does not back bleed. https://www.youtube.com/watch?v=_tddIQ3uuBs
The same guy on the Harley video does back bleed the hydraulic clutch which seems OK to me.
https://www.youtube.com/watch?v=aQWSPobQGEA
Randy S.
98 V11 EV
05 HD Electra Glide Classic
Madison, WI
Moto
« Reply #5 on: July 15, 2019, 11:44:26 AM »
That's a good point, of course. Mr. Conley does follow up the reverse bleed with a forward flush until clean fluid flows out of the caliper. I'm not familiar with the internal arrangements of ABS components that might make them more sensitive.
I find a lot of little pointers of value. For example, he was routinely spraying whole areas of the bike with soapy water before doing any operations that might cause brake fluid to be spread around, something I never would have thought of.
Moto
« Reply #6 on: July 15, 2019, 12:30:34 PM »
Moto
I don't quite follow the "why" on that part.   I thought that the point of back-filling the system from the caliper up was to (a) make sure all the old fluid was out of the system and (b) reduce the chance of air bubbles and the need for constant final bleeding to remove them.
Once the whole system is full of clean fluid from the bottom up, and the lever is "hard", what's the point of doing it again from the top?
Moto
« Reply #7 on: July 15, 2019, 02:33:56 PM »
He was doubtful that the system was truly clean once clean fluid appeared at the master cylinder, so he said he would use three or four times more fluid than strictly necessary in order to really clean it out, by conducting the forward flush. At the end of that process he pointed out some residual gunk in the master cylinder caliper that he was finally able to expel by building pressure (with the hand brake lever) and suddenly loosening the bleeder. So his extra effort was rewarded.
Maybe a DYI worker would be better advised to take the time to disassemble and clean the caliper, but he was training would-be professionals who wouldn't be able to bill for that extra service if it wasn't on the work order.
Throughout the series he is emphasizing extra steps or extra care that will produce better repairs.
« Last Edit: July 15, 2019, 02:37:31 PM by Moto »
