Author Topic: Califirnia stone shift lever interchange.. ie lose the heal/toe  (Read 1682 times)
Offline s1120
My 02 stone has has pegs, and not boards like the EV. The stones came with heal/toe shift lever, and really with the pegs the heal part just gets in the way of my foot. I doupt I will ever use it at all... just feels odd to me.. Is there another lever that will swap on? Any reason I shouldn't  just hack saw off the heal part??
« Last Edit: July 15, 2019, 08:05:20 AM by s1120 »
Paul B
Offline bete
Re: Califirnia stone shift lever interchange.. ie lose the heal/toe
« Reply #1 on: July 15, 2019, 09:39:21 AM »
Cut mine off 😨,   sounds painful doesn't .
Offline NC Steve
« Reply #2 on: July 15, 2019, 10:26:18 AM »
As a recent Stone buyer I'm interested in this topic too. I'd much rather find a lever that'll fit instead of cutting the stock heel/toe setup tho, I'm also thinking of possibly adding foot boards some day.
'16 Triumph T100
Past:
'19 RE Himalayan
'07 Honda ST1300
Mark Twain
Offline unclepete
« Reply #3 on: July 15, 2019, 12:02:20 PM »
Last year I bought the first cruiser type bike I had ever owned ; also the first with floorboards and heel-toe shifter . 1994 California 1100 .
It felt strange and uncomfortable at first . I thought about changing to foot-pegs and regular shifter while I was getting used to the bike .
I padded the seat to relieve the angle on my knees and adjusted the bars , and tried a couple different windshields , and at some point I quit thinking about it and now feel that the heel-toe / floorboard combination is just right for that bike .
It took about 4000 miles for me to like it .
I have a couple other bikes with different riding positions and conventional shifters , and am not tempted to change them to floorboards and heel-toe , but for that bike they're just right .
I bought the bike for the drivetrain , and it took me a while to 'get' the cruiser thing .
Offline BrotherJim
« Reply #4 on: July 15, 2019, 12:38:06 PM »
I was not particularly fond of the heal-toe shift on my '02 CalStone at first.  I contemplated a rearset conversion kit, but that was was going to be ridiculous money and I would likely have lost my passenger pegs.  As I've ridden the bike, I've got used to the heel-toe and don't mind it so much.  I'm a size 13 boot, so I don't have to move my foot around too much to heel-toe, but times I've tried (accidentally) to upshift with the toe, it has been too much of a reach and I might not engage the next gear properly.  With proper adjustment of the shift lever main linkage, either set-up should work just fine.
Short Time Livin'...
'02 Moto Guzzi California Stone
Offline yellowheader
« Reply #5 on: July 15, 2019, 12:40:22 PM »
I have a Stone with pegs and heel shifter. The shifter wasn't something I would have added myself, but I got used to using it fairly quickly. Now I like it, and it saves wear and tear on the toes of my boots. I don't miss having floorboards, the pegs work fine.
Offline s1120
« Reply #6 on: July 15, 2019, 01:02:02 PM »
Thanks for the input guys. As of now it just gets into the way..  But ive only got a 1000 miles under my belt on it, so Ill hold thill I ride it more..  I also plan on a taller seat... so maybe that will make a difference..
Paul B
« Reply #7 on: July 15, 2019, 02:30:53 PM »
Don’t worry mate, it’ll heel up.
Sorry, heal up.
« Reply #8 on: July 15, 2019, 03:38:00 PM »
I cut the one off the Jackal years ago just like I've always unbolted and removed the heel portion on the 2-pc Harley FL shifters.
I even had a spare unmolested shifter for the Jackal in case I ever changed my mind and wanted to reinstall it, but I never did.
Offline s1120
« Reply #9 on: July 15, 2019, 05:38:25 PM »
Do the stone/Jackal use the same shift lever as the EV?  Being they mount it on the peg... I wasn't sure if they were the same.
Paul B
Offline Rich A
« Reply #10 on: July 15, 2019, 10:20:11 PM »
My convert had a toe/heel shifter, which was useless, of course. I hacked of the heel part, re-shaped it as best I could, then had it re-chromed. Much better that way.
For the Jackal & Bassa, I got to like shifting with my heel.
Rich A
Offline NC Steve
« Reply #11 on: July 15, 2019, 11:14:31 PM »
My Jackal had foot boards when I bought it, and I enjoyed using the heel & toe shifter with them. The new Stone has pegs, and I plan to experiment using the same shifter with them, before either adding boards or cutting the heel portion of the shifter. I want to keep the heel/toe if it feels right.
'16 Triumph T100
Past:
'19 RE Himalayan
'07 Honda ST1300
Mark Twain
Offline wymple
« Reply #12 on: July 15, 2019, 11:39:49 PM »
On my heel-toe setup, I got used to shifting my foot from front to rear on the lever to use the toe only, because my foot is a bit stiff from being badly broken in the past. Shifting with my heel is not comfy. It causes me zero difficulty as I quickly got used to it and don't even think about it.
