Author Topic: Choice of Tires for 16" Frt Wheel Bikes  (Read 2394 times)
Offline Cdn850T5NT
  • Cdn850T5NT
« on: July 18, 2019, 03:38:14 PM »
Folks, I have a 1985 850 T5 NT - i.e. it has 16" X 2.15 front wheel and 18" X 3.00" rear.  The OEM tires were:  110/90 - 16 Michelin A48, and 120/90 - 18 Michelin M48.  I need to buy some tires, and I was considering Continental TKV 11 and 12 (see pix), but these have been discontinued.
Instead, now I am considering Metzeler ME77 Perfect tires, which have an identical pattern, front and back, but they are formulated differently front versus back.  Unfortunately I cannot get 120/90-18 rears... just 110/90 rears.  I lose some load capacity... but not too much.  My bike is not heavily loaded.   Please see photos / graphics.  Note that they only come as S Rated... and they are billed as a touring tire, not really a high performance sport-touring tire.  However, good life expectancy apparently.
I believe that 16" front-tire Guzzi's need all of the help they can possibly get to NOT have an unstable steering - and so for folks who do not usually go on rain-grooved freeways - a central groove, that is straight-as-a-die - is necessary, front and back.  Also, I would bet that an SPII with its big, fork-mounted fairing is worse-off in this whole regard, versus the bikini-fairing on my T5.  No way would I want to add hand-protection / brush-guards for some additional wind protection as I think it would exacerbate matters.
There are, unfortunately, very few choices out there for 16" front wheeled Guzzi's.  Note, as well, that there is very little side-clearance up front... I cannot go to a 120 section-size tire.  To avert all of this difficulty, I may have to change to an 18" front tire (which I believe I can - with some fairly minor fender mods and spacers for the front fork-brace).
Impressions, comments, most welcome!
upload
« Last Edit: July 18, 2019, 03:55:10 PM by Cdn850T5NT »
1985 Eurospec 850 T5 NT (Nuovo Tipo - New Type... i.e. Series III)
Offline Two Checks
Re: Choice of Tires for 16" Frt Wheel Bikes
« Reply #2 on: July 18, 2019, 04:45:32 PM »
16" front tires will kill you!
I wonder how those Wing and Voyager riders ever lived with those big fairings and FIFTEEN inch tires?
Never noticed a thing on my SP II.
1987 1000 SPII "Il Duce' II"
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #3 on: July 18, 2019, 05:06:17 PM »
https://tinyurl.com/16-front-tires
https://tinyurl.com/18-rear-tires
Thx.  I see that it brings up the Continental TKV11, as a front tire, and the Mezeler Lazer front, as well.  The latter is well known - but I am lead to believe that both of these tires in 110/90-16 are ceasing production.  That means I need to move fast to try either of them.  Those are the only ones with the single, central, straight groove, which I think I should have.
For the rear, I could find these (with that same attribute):
DuroTour.  I had not heard of them before.
Anyone have any experience with them?
Thx
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #4 on: July 18, 2019, 05:09:43 PM »
Fair enough...
Not saying that it is so much, the rim size, but the overall gyroscopic effect.  On the fully dressed tourers, above, they no doubt are heavier/wider than the puny 110/90-16 I have.  Further, those fairings are all frame-mounted, I believe.
I heard a Youtube video from a guy in Australia with both an SP, and an SPII.  He said the latter, with its 16" wheel, was a disaster.  The former ran straight as a die.  I noticed the tread pattern he had was NOT central, straight groove....
« Last Edit: July 18, 2019, 05:10:49 PM by Cdn850T5NT »
Offline bigbikerrick
« Reply #5 on: July 18, 2019, 05:27:33 PM »
FWIW I have an 85 Lemans with 16" front running a shinko, and its very stable ,and steers sweetly. I think the 16" front wheel handling problems were proven untrue, although my LM likes about 37 psi in the front tire, otherwise, it just feels a bit "heavy", but never unstable.
 Yes ,the selection of 16" tires is not great, I wish there were more to choose from.  I dont think the shinko has a straight groove down the center, the metzer lazertech I had before did, but I noticed no difference in rain grooves or otherwise.
  As a matter of fact, the fat, meaty front tire works very well for the broken up pavement and occasional brutal chuck hole you find  in the rural areas where I ride.   :thumb:
Rick.
« Reply #6 on: July 18, 2019, 06:09:23 PM »
Thx
The IRC Durotour gets good reviews on various sites, but I've never tried them - I try to stay away from tires with a center groove. I do use IRC tubes and they're the best quality on the market at present IMO. Made in Japan.
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #7 on: July 18, 2019, 06:09:50 PM »
I appreciate the info...
Offline slopokes
« Reply #8 on: July 18, 2019, 06:53:58 PM »
I guess if dr.john could win races on his Guzzi with a 16 inch front wheel then it should work for you.😀
Offline antmanbee
« Reply #9 on: July 18, 2019, 06:58:34 PM »
I always use IRC tubes too but the ones I get seem to be made in Thailand and not Japan.
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #10 on: July 18, 2019, 07:15:19 PM »
Hey, I'm not hankering to change out to 18", believe me.  I would have to do a relief-cut  in my front fender to be able to fit an 18", and I refuse to drill holes or muck with the factory-delivered product (that's just the way I am, hehe).
I will make the 16" wheel work for me.
Online pehayes
« Reply #11 on: July 18, 2019, 09:58:16 PM »
'87 SPII
I use Bridgestone Battleax BT45 F 110/90/16 M/C 59V
Works well as long as you keep the pressure up at 38-40 psi.  Drop a few pounds of air pressure and it starts to feel very heavy.
Offline Turin
« Reply #12 on: July 18, 2019, 10:51:51 PM »
+1 Bridgestone Battlax 110/90-16
The taller tire give you close to the same diameter as a 17" wheel and tire.
'87 Guzzi Lemans and it rides like it's on rails.
1986 Sidlow Guzzi
1996 Triumph Daytona 900
Offline Ryan
« Reply #13 on: July 18, 2019, 11:22:17 PM »
Ran Metzlers on my Interceptors and they were awesome.
Offline huub
« Reply #14 on: July 19, 2019, 12:19:58 AM »
have a look at scooter tires
i run pirelli dragon scooter tires on the 16 inch front wheel of my lario.
absolutely briliant tires ,
way better than the metzeler and bridgestone i tried before
« Last Edit: July 19, 2019, 10:24:26 AM by huub »
omega1
« Reply #15 on: July 19, 2019, 01:06:22 AM »
Pirelli Sport Demon is available in both sizes you require.
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #16 on: July 19, 2019, 09:29:29 AM »
Thank you All for your info + helpful replies :) .
