Author Topic: Assistance needed in Southern Illinois  (Read 1291 times)
Offline groundhog105
« on: July 20, 2019, 10:46:55 AM »
Hey guys I just got a call from Noel Portelli in vandalia Illinois with a problem with his Griso.  He is traveling from California to Pennsylvania.  If anyone is close that can help his phone number is 951-265-9187
« Last Edit: July 20, 2019, 01:55:30 PM by groundhog105 »
Offline delrod
Re: Assistance needed in Illinois
« Reply #1 on: July 20, 2019, 01:17:37 PM »
Bump
Doug in Pittsburg KS
2003EVT
Online bad Chad
« Reply #2 on: July 20, 2019, 01:38:21 PM »
Sorry I can't help at the moment.  But you might want to modify the title of the thread, Vandalia is close to St. Louis MO.  Perhaps say Southern IL so those in close boarder states may be able to help as well?
« Reply #3 on: July 20, 2019, 01:40:17 PM »
I've been looking through the MGNOC contact directory.  Am starting to call a few guys that are closer.  It is a 5 hour drive for me.
« Reply #4 on: July 20, 2019, 01:46:43 PM »
I just talked to Noel and he is going to try and get towed back To St Louis to a Guzzi dealer.   If anyone is nearby with a trailer or truck he could use the help.  Tow trucks are not available for about 3 hours.  Noel related that his Griso was blowing a lot of oil out the motor vent tube.  The bike had been running perfectly since leaving California and suddenly began blowing oil coating the back end the bike swingarm and wheel with oil.
I sent him the MGNOC help list but I don’t think he had any luck with that.
« Last Edit: July 20, 2019, 01:49:44 PM by groundhog105 »
« Reply #5 on: July 20, 2019, 01:51:25 PM »
I contacted Glenn.  He is an hour away from Vandalia.  He will call Noel to see if he can help.
It would help to know the year of Noel's Griso.  I am pondering his oil issue.
« Reply #6 on: July 20, 2019, 01:56:27 PM »
I am wondering if Noel "topped off" the oil level recently?  It is a classic symptom of overfilled oil.  On a Griso the top mark is TOO much.
Online PJPR01
« Reply #7 on: July 20, 2019, 02:44:02 PM »
Exactly...it will blow oil thru the two drain tubes down below and also accumulate into the airbox.  I'd siphon off 1/2 a quart to start with, clean up the box and drain the tubes and see if it continues to accumulate, then drain some more.  As long as the bike is running...he might need a fresh set of plugs if they got fouled...I'd try all that before towing, could be an easy fix.
Presumably it's a low mileage bike and as Dave says...the result of a fresh oil fill...
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
Hymes Inc.
Re: Assistance needed in Southern Illinois
« Reply #8 on: July 20, 2019, 04:02:56 PM »
My v65 did that when it blew a head gasket
« Reply #9 on: July 20, 2019, 06:25:26 PM »
Noel is now in St. Louis at the Guzzi shop and they are checking out the bike.  I think he knows about overfilling and hadn’t added any oil prior to today and hadn’t had any issues.
Thanks for all the replies and suggestions.
« Reply #10 on: July 20, 2019, 06:39:46 PM »
Probably a cracked breather hose or the condom on the condensor box has split. Either of those let go and it's very messy very quickly.
