Author Topic: That ain't going to rub out.. (G5 content)  (Read 6357 times)
Offline AZach
Re: That ain't going to rub out.. (G5 content)
« Reply #30 on: August 05, 2019, 09:56:58 PM »
How many miles are on the bike?
23000 miles
Without a doubt , Lack of proper maintenance.
 When was the last time the heads were properly re torqued and valves reset, and the proper mixture checked to see it is not too lean. Also the ignition timing set at full advance they way it should be.
Mike
And I did the valves and points last fall before took the bike to the Kentucky rally.  We set the timing the day before it blew, Chuck adjusted the carbs the best we could do with just sound.
Austin
Indiana Rep
'81 V1000 G5
'86 LeMans IV "200k Flood bike"
'91 CalMans "big valve Cal turned Mk4
'98 EV
'03 Cal Aluminum "mostly parts bike"
'79 Yamaha XS750 Tripple
'94 KLR650 aka "KLR from Hell"
« Reply #31 on: August 22, 2019, 04:57:57 PM »
At the Virginia rally, I was fortunate enough to be called second for a door prize. Snatched this tool off the bench. The lady sitting next to me asked what it was. I said, "I don't know, but it looks like I need it."  :grin:
I didn't realize how soon I would need it, though.
Here, Austin is schooling me on how it works.
He had decided to put new valves in it because the exhaust was pretty beat up. I thought I'd walk to the house, get my phone and do a quick photo essay.
He already had the valves lapped in and was just finished assembling it when I came back.  :smiley:
Kids, anyway.. they're so impatient..
I had to remind him that Luigi was using an antique machine when he milled this head. "Yes, I know you can do a better job with that carbide inserted slab mill you are using on the nozzles, but they hadn't been invented in 1981.. " :grin:
Going back together as we speak.
Yes, it's a used cylinder and piston from Mark at MG Classics. <snapping suspenders>
Offline nobleswood
« Reply #32 on: August 22, 2019, 06:05:38 PM »
Good to see the rebuild has started.  :thumb:
2013 1200 8v Griso
« Reply #33 on: August 22, 2019, 08:16:16 PM »
He brought it back in from a spirited break in ride.  :grin: "Tears of joy.."
« Reply #34 on: August 23, 2019, 12:54:35 AM »
I suppose this should incentivise me to pull my head out of my arse and finish off my Cali. Problem is daytime temps are still maxing out below 15*C and below that my hands simply don't work. I'm like a sort of Tyranosaurus Rex with these weedy little hooks on the end of my arms!
Top end is back together but. Now I just have to put all the extraneous crap back on, replace all the hoses and get it started. That'll be fun.
Not!
