V65 Speedometer cable replace
Topic: V65 Speedometer cable replace (Read 1154 times)
Pescatore
Gaggle Mentor
August 10, 2019, 04:40:13 PM »
Ciao Guzzisti,
I have this kind of instrument panel on a V65. I need to replace the speedometer cable. I am not sure how to open the speedometer housing.
I removed the screw at the bottom of the housing, but it doesn't slide out.
It seems I have to remove the handlebar clamp in the middle. Has anyone ever done this?
Thanks,
Pescatore
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
guzzisteve
"Just Ride It"
Re: V65 Speedometer cable replace
Reply #1 on:
August 10, 2019, 05:15:53 PM »
There are screws inside of the plastic square to each bucket I believe. Look in where the idiot lites are, should be one each way.
Pescatore
Gaggle Mentor
Reply #2 on:
August 12, 2019, 11:11:43 PM »
Thanks for the tip. I spotted two screws in the parts list drawing that hold up a cover under the panel. I had to remove the headlight to get at them.
Then I saw the mounting screw.
upload
And after fumbling with the reset knob, I realized it is screwed on. Unfortunately it does not screw back in as much because it spins the trip counter. I hope it won't fall off.
Pescatore
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
Diploman
"The future just ain't what it used to be." Yogi
Reply #3 on:
August 13, 2019, 10:54:17 AM »
You might consider the ultimate solution to your old-technology mechanical speedo problems: A Speedhut GPS speedo. (This is a somewhat un-Guzzi remedy, because it actually costs money.) No cable drive, cable sheath, cable or funky reset knob. (All this paraphernalia is surprisingly heavy as well as cumbersome). Extremely simple installation, precisely accurate readout, unaffected by tire changes/brands, completely reliable. The gauge itself is very lightweight. Waterproofing around bezel available on request. A very worthwhile upgrade, IMO, unless you are an authenticity freak. Definitively eliminates speedo problems and inaccuracies.
https://www.speedhut.com/gauge/GR338-GPS-01/1/GPS-Speedometer-120mph
2015 KTM 390 Duke
Pescatore
Gaggle Mentor
Reply #4 on:
August 13, 2019, 08:27:38 PM »
Interesting stuff, thanks.
It would also solve my problem of Km/Mph, but like you said, un-Guzzi and un-authentic.
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
