After the 2013 flood I installed the Enduralast voltage regulator/rectifier. It worked great. But now I've traced my electrical problem to an apparent short circuit inside the voltrect box. I found continuity between the green battery-post wire and the orange wire from the ignition switch -- that seems very wrong. I stripped the cover off the wires to make sure they hadn't gotten crushed together, and no, all the wires have good clean undamaged insulation.
Nobody has mentioned this handy troubleshooting hint in this thread yet. Make up a couple of clip leads to put a big light bulb (like a headlight) in place of the blown fuse. That will keep you from blowing your fuse budget (pun intended) while seeking the short. Keep wiggling and/or disconnecting things until the light goes out.Howard
