Author Topic: oil pan gasket, wet or dry?  (Read 3132 times)
Offline amamet
« on: August 19, 2019, 02:39:50 PM »
someone, can't remember who, recommended anti seize on both sides for oil pan gaskets.  I've done both dry and light coat of oil in the past.  is anti seize better, worse?  what's recommended?
thx
allen
Online rocker59
Re: oil pan gasket, wet or dry?
« Reply #1 on: August 19, 2019, 03:11:35 PM »
Wet.
I just dip a finger in the motor oil and dampen the gaskets.
Online LowRyter
« Reply #2 on: August 19, 2019, 03:12:35 PM »
Keep it dry, use a little grease to tack it in place.  Make sure it isn't upside down.
I oiled it down once and it kept oozing.
Offline yogidozer
« Reply #3 on: August 19, 2019, 03:14:57 PM »
Yup, I use a smear of grease. keeps it in place, and prevents it from welding itself to the pan/block.
Online blackcat
« Reply #4 on: August 19, 2019, 03:27:10 PM »
I use to use oil, now I paint them with anti-seize.
Offline Phil G
« Reply #5 on: August 19, 2019, 03:39:09 PM »
Grease,
non stick, reusable  :cool:
Offline Bobic69
« Reply #6 on: August 19, 2019, 05:12:09 PM »
Well that clears that up. :tongue:
Bellagio
« Reply #7 on: August 19, 2019, 05:28:14 PM »
Lick it like a postage envelope....
« Reply #8 on: August 19, 2019, 06:29:04 PM »
 :grin: Good point. Maybe it's not that important.
Offline 80CX100
« Reply #9 on: August 19, 2019, 07:45:29 PM »
      Yup !  :laugh:
     I've done it all different ways, but after having the gasket shift out of alignment on me a couple of times; I like to put grease on the top of the gasket so it will stick into place a little bit as I line the sump cover up, and rarely, if I later drop the sump, the gasket sticks to the cover in one piece and can be reused,,,guzzi content  :thumb:
     fwiw ymmv
      Kelly
2008 California Vintage
2003 V11 Lemans
1979 G5 & 1980 Lemans CX100
Offline dxhall
« Reply #10 on: August 19, 2019, 07:57:25 PM »
I’m a grease guy.  I also start the install by screwing two headless 6mm bolts into the block.  This, plus the grease, holds the gasket in alignment so the pan can just be pressed on.  Make the headless bolts extra long so you don’t forget to replace them before you start tightening.
« Last Edit: August 19, 2019, 07:59:53 PM by dxhall »
Online LowRyter
« Reply #11 on: August 19, 2019, 08:01:34 PM »
this is so funny, what a cluster.
And these are the Guzzi Experts
Offline lucian
« Reply #12 on: August 20, 2019, 07:12:08 AM »
We have a winner!  Great tip  with the index pins,  Thanks.
Offline kballowe
  • - Kevin the Great -
« Reply #13 on: August 20, 2019, 08:35:57 AM »
Grease.
It's like finger painting, so it adds a bit of fun to the project.
 :grin: :grin: :grin:
Offline acogoff
« Reply #14 on: August 20, 2019, 11:55:50 AM »
     A film of your favorite grease on both sides and let it decide if it comes off with the pan or stays on the block. Should be reuseable for a few filter changes.
Marshall County Minnesota USA
