Author Topic: 850T weight, dry vs wet?  (Read 3538 times)
Offline Testarossa
    • Skiing History
« on: August 20, 2019, 09:43:42 AM »
I posted this in my 850T rebuild thread and no one responded. I'm genuinely curious so reposting:
I weighed the T at 480 lb with oil but no fuel. Can't vouch for the accuracy of my scales.
Book value is 465 dry, 562 full fuel. That's a 97 lb difference.  Really?  5.5 US gallons of gasoline should weigh only 34 lb, and 5 qt of oil (split sump, gearbox, final drive) should weigh less than 9 lb. That still leaves 55 lb unaccounted for.
The only thing I can think of to explain the difference is that "dry" must not include a 55 lb Marelli car battery. My weighed dry weight includes oil and a 16-lb Yuasa battery -- and the fairing and the LEO sidestand which is probably two pounds heavier than the original. Take those out and I'm very close to the nominal 465 lb dry weight.
So the question is: How did Guzzi report dry weight back in the day? With or without battery?  What does your old Tonti weigh compared to the values in the spec sheet?
Re: 850T weight, dry vs wet?
« Reply #1 on: August 20, 2019, 10:51:16 AM »
Even an ETX30L AGM (about the largest and heaviest that will fit) is only 24 lbs.
Offline chuck peterson
« Reply #2 on: August 20, 2019, 03:41:35 PM »
I count one gallon as 8 lbs, just like water if I remember. 6 gallon tank full adds 48lbs, so there might be another 14lbs closer to your wet weight figure
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline Two Checks
« Reply #3 on: August 20, 2019, 03:50:53 PM »
Gasoline is just over 6 lb. Water is over 8.
1987 1000 SPII "Il Duce' II"
« Reply #4 on: August 20, 2019, 04:08:24 PM »
Guzzi reported dry weight just like HP. They picked a number and posted it as technical data.
I'd say that pretty much nails it.  :smiley:
Online Turin
« Reply #5 on: August 20, 2019, 04:54:37 PM »
Did you figure deducting the fork oil?
I suspect guzzi weighed their bikes by throwing a pile of parts on Luigis bathroom scale.
1985 Sidlow Guzzi
« Reply #6 on: August 20, 2019, 05:02:06 PM »
All big blocks weigh 550.  :smiley:  Luigi threw a dart, and that's where it landed.
Just for S&G, I weighed the Mighty Scura, AeroLario, and Monza when I had some aircraft scales in the hanger doing a weight and balance on an airplane. Surprisingly, to me.. the Scura weighed 495 without fuel but otherwise ready to run, so add roughly 36 lbs of fuel, and it'll beat that 550 number. A little. After all, Guzzis are all about lightness.. :grin:
Offline geodoc
« Reply #7 on: August 20, 2019, 05:12:24 PM »
Bought a digital scale that you can hang from a chain hoist. My Loop with full fuel weighs 535 lb. My '73 Ducati 750 GT with full fuel was 472. My 2001 Triumph Sprint RS with full fuel 536 lb. My garage mate Tom's (pictured below) stock 1974 T150 Trident no fuel was 466 lb.
« Last Edit: August 20, 2019, 05:16:40 PM by geodoc »
Online RinkRat II
  • Lake Powell AZ
« Reply #8 on: August 20, 2019, 05:18:24 PM »
    It is determined by an exacting logarithmic calculation based on the smoke coming out of their.............. .....wind tunnel :evil:
     Paul B :boozing:
« Reply #9 on: August 20, 2019, 05:35:28 PM »
Cool scale, where did you get that George?  I have an overhead crane with an electric winch running off it in my shop, that scale would be great for weighing bikes and other things.
I read that 'dry weight' does not include fluid in the battery, no fluid in the forks, no engine oil or coolant, no brake fluid, they probably even drain the rear drive and  the fluid in the shocks :angry:
Offline geodoc
« Reply #10 on: August 20, 2019, 06:03:46 PM »
Bought it off eBay:
https://tinyurl.com/y6p7x6dw
« Reply #11 on: August 20, 2019, 09:20:57 PM »
Thanks George
Offline Guido Valvole
« Reply #12 on: August 21, 2019, 05:51:05 PM »
Chuck, out of curiosity, what did the Monza weigh?
cr
V50 II
V50 Monza
Le Mans 1000 (IV)
Martinez, CA
« Reply #13 on: August 21, 2019, 07:44:50 PM »
cr
Believe it or not.. I didn't write it down, and now I can't say for certain. :rolleyes: It *seems* it was only 25 lbs lighter than the AeroLario, which surprised me because it definitely feels lighter. Failing memory says a little under 400. I'm pretty sure I posted it here, though. I'll do a search.
« Reply #14 on: August 22, 2019, 01:53:25 PM »
Thanks, Chuck! That sounds about right. Shop manual says 160kg / 353 lbs. Which in the finest Italian tradition would be dry, no fluids of any sort, and helium in the tires...
V50 II
V50 Monza
Le Mans 1000 (IV)
Martinez, CA
« Reply #15 on: August 22, 2019, 05:04:37 PM »
Oh yeah.. forgot to account for the helium.  :smiley:
Offline motoTommaso
« Reply #16 on: August 22, 2019, 06:32:46 PM »
Yes this ^^^  Used it many times for avgas 100LL weight and balance.
Online frozengoose
  • To eaches his onus...
    • smiles from nowhere
« Reply #17 on: August 22, 2019, 09:54:22 PM »
Just out of curiosity, I weighed the T when I got back from town after filling up the tank. Used a bathroom scale, so I guess the weights are maybe plus or minus 5 lbs.
Front wheel on scale = 235
Back wheel on scale = 275
So there you go...       510 lbs with a full tank of gas    Your results may vary.
Big Jon
Jerry Zee
Offline Testarossa
    • Skiing History
« Reply #18 on: August 22, 2019, 10:34:37 PM »
That 510 is within 5 lb of my result.
« Reply #19 on: August 23, 2019, 12:14:54 AM »
My Stelvio is so heavy it pulls small asteroids into orbit around it. If I park it and the Griso together they develop an event horizon and suck everything around them into a deadly vortex! :evil:
Online frozengoose
« Reply #20 on: August 23, 2019, 12:36:42 AM »
I was kind of surprised that the T didn't weigh more, it's so heavy to move around the garage, I always figured that T stood for Tank!
Big Jon
Jerry Zee
« Reply #21 on: August 23, 2019, 12:45:58 AM »
No, it stands for 'Turd'! :evil:
Online frozengoose
« Reply #22 on: August 23, 2019, 01:10:08 AM »
Well like the old philosopher sez, "opinions are like assholes, everybody's got one."
Big Jon
Jerry Zee
« Reply #23 on: August 23, 2019, 01:18:40 AM »
I'm very fond of 'T's. If I did decide to get another older Guzzi it would probably be a T3.
Online frozengoose
« Reply #24 on: August 23, 2019, 01:27:17 AM »
It's got it's short comings, for sure, but after thirty years, I still enjoy cruising it down the highway. But the gravel roads around here are a different story, I guess that's why I ride the v65 a lot more now.
Big Jon
Jerry Zee
