Author Topic: 1400 runs better on low octane?  (Read 8606 times)
Rough Edge racing
Re: 1400 runs better on low octane?
« Reply #30 on: August 27, 2019, 05:42:13 AM »
It isn't about burn rate , which can be manipulated by chemistry . Lower octane ignites easier , and some dyno testing shows that an engine capable of running on 87 will make more power on lower octane than on higher octane . We have this discussion about every year or so , lots of confusion about what octane actually does , in the simplest definition , higher octane is more resistant to ignition , meaning higher compression ratios , usually meaning in modern engines CR ratios above 10.5 to 1 need a bit more octane to prevent pre-ignition . Older designs like a hemi-head Triumph run hotter than a modern design with more effective cooling . Gasoline will flash at 536 degrees F under zero pressure , ethanol at higher temps . Increasing pressure effectively lowers the flash point , as does the distance between the ignition source and the fuel mixture . The closer the ignition source , the lower the flash point . What this all means , octane requirements are dependent on several factors beyond just compression ratio .
 Dusty, do you think Kevin Cameron has a good understanding about the combustion process in engines? How you ever watched his video I have posted here seevral times ?  I will post it again... listen to what he says about the cause of detonation..Then you will understand what how higher octane prevents detonation...
            https://www.youtube.com/watch?v=aH-lDh3rVFQ
And this article written by a leading automotive emissions designer...
           http://www.contactmagazine.com/Issue54/EngineBasics.html
  using this info and understanding combustion, me,an average hobbyist mechanic, set several speed records with my 650 Triumph land speed race beating experienced guys with more higly tuned engines....
« Last Edit: August 27, 2019, 05:43:17 AM by Rough Edge racing »
Offline kirby1923
  • '81 CX100
« Reply #31 on: August 27, 2019, 07:21:01 AM »
Yeah its complicated.
A bit more energy BTU wise with the lower octane, but won't help if the engine "pings" w/the lower rating.
My beemer is 10.3 and under normal riding (not balls out) it gets better mileage with 89 over 91 and I run it w/89 almost always.(a lot of times w/87)
Its a dual plug with a very well designed combustion chamber  and that makes a difference.
The lower price gives you fresher gas and that can be a big factor, that's why I used the cheaper stuff. The majors sell their older gas to the off brand and cheaper stations at a discount.(big).
FWIW
« Last Edit: August 27, 2019, 08:00:35 AM by kirby1923 »
'81 CX100
« Reply #32 on: August 27, 2019, 07:22:30 AM »
I will say I'm all of this that butt dynos are notoriously inaccurate.
I remember a Canadian TV station tested this out using a run of the mill Chevy sedan with a Dyno and tail sniffer.
The Chevy spec'd for "regular" (lower octane) fuel made a hair more power on regular and emissions on premium.
The key there is it was not designed or tuned to use premium.
I asked this engine devolopment engineer the question about fuel octane and power...   David Redszus...http://www.precisionautoresearch.com/general%20info/WhoWeAre/PAR3.htm
 David Redszus » Mon Aug 26, 2019 12:11 pm
Not true. Fuel octane has nothing to do with burn rate...nothing. Two fuels with the same octane ratings can easily burn at different rates. Burn rate is principally a function of inlet air temperature, compression temperature, squish velocity and engine rpm. Suppose we use a 100 octane, unleaded fuel on the dyno optimally tuned, and then add some TEL or TML to the fuel while it is running. There will be no difference in performance. The two fuels are identical except for octane.
Of course, using the higher octane fuel would allow the engine to be tweake to a higher performance level without destruction due to detonation.
If we are speaking about pump gas, then all bets are off since we do not know what the actual octane values, RON and MON, actually are. Neither do we have any idea regarding the actual composition and properties of the fuels.
There is a reason why OEMs use very expensive certification fuels when performing engine tests; consistency.
Maybe it's semantics but stability and the prevention of premature combustion effects whether or not the fuel is fully burned by the time it leaves the combustion chamber. So even if not rate per se it has the effect of more or less power and emissions, no? Granted we're talking RCH's here but the big effect over time is more carbon build up in a motor that wasn't spec'd for premium but ran it.
« Last Edit: August 27, 2019, 07:32:26 AM by Kev m »
« Reply #33 on: August 27, 2019, 07:37:13 AM »
That Kevin Cameron one was really informative.
I never knew the difference..
« Reply #34 on: August 27, 2019, 08:27:22 AM »
 Nothing KC states contradicts what I said .
Rough Edge racing
« Reply #35 on: August 27, 2019, 09:30:16 AM »
 Both of the articles I linked give details  about what higher octane actual does, not in general that it limits detonation...It's the details that matter if a person really want to understand the combustion process ...
Offline MMRanch
  • MMRanch
« Reply #36 on: August 27, 2019, 10:38:15 AM »
Guys
Everybody knows :
Of-course your bike runs faster on the more expensive fuel , because your wallet is lighter !  :wink:
Really :   higher octane is more resistant to ignition
either you need it ... or you don't .    On hot days , at low RPM in the mountains - most of us need it .   on the interstate stock engines don't need the extra "Resistance" to ignition.  :azn:
In middle Tn. there is $.40 to $.60 difference in a gallon of reg. to high test.
« Last Edit: August 27, 2019, 10:42:47 AM by MMRanch »
2016 V7-II Stone
« Reply #37 on: August 27, 2019, 11:21:43 AM »
 Not arguing that , in fact I stated that in the simplest definition higher octane is more resistant to ignition . What I was stating is that burn rates can be altered with chemistry , independent of octane . All octane rating is based on is at what combustion pressure a given octane will start pre-igniting, based on testing with that cool little single cylinder variable compression engine , usually a *Ricardo* IC engine used in labs . Octane rating is nothing more than a number assigned to measure at what CR gasoline begins pre-ignition , the chemists then begin adding chemical into the gasoline until the process returns to normal , and the up the CR in the Ricardo engine until pre-ignition begins again , the add chemicals until the process once again returns to normal . Cameron is describing the difference between pre-ignition and detonation , a different subject than we are discussing .
Offline kirby1923
  • '81 CX100
« Reply #38 on: August 27, 2019, 11:50:34 AM »
In my years of developing aircraft air cooled engines I can say w/o doubt that if you have detonation (real) there will be damage in the top end, usually piston.
Pinging is pre detonation.
Stuff added to the fuel to prevent detonation lowers the energy content of the fuel slightly but that is better than destroying the engine.
Good trade off.
'81 CX100
Rough Edge racing
« Reply #39 on: August 27, 2019, 12:21:21 PM »
  Cameron clearly states detonation is the spontanours combstion of end gases that burn far more rapidly, like an explosion...That "explosion" is ping sound you hear...The problem is not with the main burn...
  Did you read the Cline article?
« Reply #40 on: August 27, 2019, 12:27:03 PM »
Good trade off.
 Good point Mike . Detonation results from incomplete burn of the mixture during the designed time period .
 I mentioned before that the octane needs of an old Triumph engine VS a much more modern design are somewhat different . Back when engines were either undersquare or *square* , meaning the stroke dimension is either larger than or equal to the bore dimension , a hemi head with a large surface area was required to fit ever larger valve sizes . Those engines ran really wide included valve angles , and high dome pistons to fill up the cylinder head volume . Those high domes didn't cool very well , because they were not close enough to the cylinder walls to exchange heat . As the engineers who were working this out began building engines with oversquare bore stroke ratios , the natural result was more available surface area in the cylinder head , meaning the combustion chambers could be flattened out , valve angles became narrower , and pistons didn't need to be domed to fill up empty space to achieve high enough compression ratios for good torque production . The end result was better cooling and more effective combustion . Back to the Turner designed Triumph engine , it was an undersquare design , which meant high domed pistons , which run hotter . A 1400 Moto Guzzi is significantly undersquare , meaning a more flat top piston can be employed , which because of the fact it can transfer heat more efficiently , along with generally better cooling from an increased understanding of air cooling and because one head isn't heat soaking the other as in a Triumph from 1968 , at a given compression ratio , the Guzzi won't need as high an octane rating as the old Triumph .
Whew , think I will let the brain rest  :laugh:
« Reply #41 on: August 27, 2019, 12:34:18 PM »
 Yes , but you are arguing something I never stated . In fact , higher octane than needed can lead to detonation , because it won't ignite at the designed time , meaning incomplete combustion .
 You seem to be indicating I somehow think I am smarter than Cameron , which of course is just silly , that guy knows more about IC engine physics than 99% of everyone . But we were discussing burn rates VS octane , all I was pointing out is those two are largely unrelated . Octane doesn't change burn rate .
Offline JohninVT
« Reply #42 on: August 28, 2019, 04:14:00 AM »
I didn’t say it had more power.  It acts like it’s running less lean.  The 1400’s have a pronounced lean spot at 2800rpm.  If you are decelerating, the engine note changes as it drops through 2800rpm and it feels like you’ve grabbed the brakes.  It’s a helmet knocker.  This is less pronounced with the last two tanks of gas using 87 vs 91.
Maybe it’s my imagination.  We have the holiday weekend coming up.  I’ll put a few tanks of different octane through it and see if it’s all in my head.
« Reply #43 on: August 28, 2019, 04:29:27 AM »
About that 2,7-2,800  point is where the second spark cuts in and out I believe......
« Reply #44 on: August 28, 2019, 07:44:04 AM »
Well done, gents.  The knowledge base continues to expand.
Rough Edge racing
« Reply #45 on: August 28, 2019, 12:22:17 PM »
 Was not my intention to belittle your comments, sorry...yes you are correct that octane doesn't change burn rate so it should have no effect on power all else being equal...
« Reply #46 on: August 28, 2019, 12:48:55 PM »
 It was simply a discussion Tony , no offense taken .
Offline TN Mark
« Reply #47 on: August 28, 2019, 03:15:21 PM »
When a rider typically uses type ‘R’ gas and fills up with type ‘P’ gas and notices a difference; the butt dyno has at that point fulfilled 100% of its possible performance parameter. That the rider even felt or noticed a difference, when every other time just adding gas has resulted in no perceptible difference, again, at that point the butt dyno has performed 100% of its total expectation.
Especially when there could have been an expectation of degradation but an improvement was felt instead.
I don’t believe anyone has stated a butt dyno can perceive a particular percentage of a difference. Just that it can, and every rider should have some level of their butt dyno perceiving a performance change.
Let’s say, unbeknownst to you, someone installed a fresh set of scrubbed in tires on your bike. Would your butt dyno notice a difference? I’d sure hope so.
« Reply #48 on: August 28, 2019, 04:04:15 PM »
The problem comes because we are talking about perceptions (feeling, noticing), and often because we are also expecting to feel or notice. It's often basically a placebo effect as much as we all want to believe we can feel and notice the slightest changes.
Rough Edge racing
« Reply #49 on: August 28, 2019, 04:32:19 PM »
 Depending on the fueing system, I believe slight changes in performance can be possible with different brands or grades of pump gas due to the inconsistant nature of it...Could a rider feel these slight differences? Maybe, maybe not....I do know a bike feels a lot faster accelerating down a narrow road than a wide road... :wink:
« Last Edit: August 28, 2019, 04:32:58 PM by Rough Edge racing »
Online Tom H
« Reply #50 on: August 28, 2019, 04:33:05 PM »
This thread got me thinking.
I decided to try regular gas in my Eldo. It's warm out today and was riding in the city. Starting up at a light I thought I noticed a ping, the Eldo on premium is pretty well behaved. I noticed it again a few times. Then I had to go up a pretty steep hill to get where I was going. The bike would ping bad enough that I had to get off the gas to get it to stop. I normally go up the hill in 3rd, almost had to use second today.
Maybe I'm using the wrong word when I say ping. To me it's the tingey, crackly, pingey sound that you get with a hot engine on a hot day under load. Cars will do it, especially when they are just about to overheat.
The Eldo has done it before on a hot day with premium. For instance. In the desert, on the freeway, a very stiFF (not sill, damn typo) headwind and trying to do 65-70mph. In 5th to get it to stop pinging, I had to let off a bit. I finally had to go to 4th and do about 55-60mph. Not fun when big truck are flying past you.
Unless I have to run regular because nothing else is available, I will stick with premium. I normally get gas at about a half tank or 120 miles. Usually 3 gallons, so it's about 60 cents extra to run premium.
« Last Edit: August 28, 2019, 05:08:48 PM by Tom H »
Offline TN Mark
« Reply #51 on: August 28, 2019, 05:00:00 PM »
You quoted me but by your response I was either not clear or you didn’t comprehend what I posted. I thought at least my tire illustration would have done it for some.
Oh well, use whatever means you have or that you trust to hopefully notice any changes in your own bikes performance.
Tom H, all systems seem to be present and accounted for. Your butt dyno, which includes ones hearing, has determined you should stick to Premium in your beautiful Eldorado. Cool huh?
« Reply #52 on: August 28, 2019, 06:40:18 PM »
You were clear and I was saying we often fool ourselves into thinking we feel what we expect/want.
No big deal... All good.
Offline Bulldog9
« Reply #53 on: August 28, 2019, 06:57:31 PM »
The real question is what tire and oil is best matched to the octane level you are running.  :drool:
MGNOC#23231
Offline TN Mark
« Reply #54 on: August 28, 2019, 07:35:25 PM »
Awesome, thank you!
Oil thread! Love it.
