Author Topic: Guzziology Chamfer Crank Oil Holes?  (Read 2211 times)
Offline shiskowd
« on: September 10, 2019, 10:28:49 PM »
I've seen a few posts were there's a reference to a Guzziology suggestion to chamfer oil holes on the crank.  I have two editions of Guzziology (1st and last) and for the life of me cannot find that anywhere.  Can someone point me in the right direction??
« Last Edit: September 10, 2019, 10:29:17 PM by shiskowd »
'14 KTM 500 EXC
'10 KTM 690R Rally
'75 Moto Guzzi 850T
Offline Don G
Re: Guzziology Chamfer Crank Oil Holes?
« Reply #1 on: September 11, 2019, 01:13:19 PM »
If you want to have the drilling's champhered take the crank to your local engine shop, speak to the crank man about what you want, have him measure the journals to be sure it is in spec. champher the drilling's and have the crank polished after the procedure. Easy and affordable. You are likely thinking about the radius at the ends of the crank pin, nothing to worry about on an 850T, unless a crank grind is under taken.  DonG
« Last Edit: September 11, 2019, 01:15:56 PM by Don G »
Offline shiskowd
« Reply #2 on: September 11, 2019, 10:03:12 PM »
Thanks Don - I have a crank guy lined up who has experience with the older Guzzi big twins.  I believe my crank is OK, just want to check against the bearings and polish up.
'14 KTM 500 EXC
'10 KTM 690R Rally
'75 Moto Guzzi 850T
Offline Tony F
« Reply #3 on: September 12, 2019, 04:14:38 AM »
I don't know about any reference to this in Guzziology but chamfering the oil holes on the crank was a trick used by one Charlie Rice who had a Guzzi tuning shop called Rennsport located in Ojai CA around the late 1980s.
It is, I believe, an old Nascar modification. It has been mentioned on a Guzzi forum before (not sure which one) and I recall that there were significant differences of opinion as to its value!
Tony
« Last Edit: September 12, 2019, 04:15:46 AM by Tony F »
Tony
'79 SP1000
KTM Duke 890R
MV Agusta F4 (x2)
« Reply #4 on: September 12, 2019, 02:35:11 PM »
It's been done on hot rod engines for millennia. You are just getting rid of the sharp edge, which is a stress riser.
Offline Tony F
« Reply #5 on: September 12, 2019, 05:20:21 PM »
After a dive into the archives I found the magazine (Motorcyclist August 1988)!
Summarising, the modification (in response to a tendency for oil cavitation) was to port the oilways in the block and crankshaft and fishtail the oil pickup holes in the crank itself. The modified holes then scoop up more oil than normal improving the oil flow to the big ends. Necessary no doubt for the 9,500 rpm red line.
If anyone is interested in a bit of history I can scan the article.
Tony
Tony
'79 SP1000
KTM Duke 890R
MV Agusta F4 (x2)
Offline voncrump
« Reply #6 on: September 12, 2019, 07:18:21 PM »
I served an Automotive Machining apprenticeship in the late 60s to early 70s.
Hamilton New Zealand.
It was standard practice in our workshop to chamfer the oil holes before polishing any crank journal that was reground.
Just a quick touch with a drill bit in an air drill.
Brrrt, brrrrt, brrrt, I still remember the noise.
Cheers Voncrump.
1996 1100 sport
2016 V711
1988  Lario ( long gone )
1982 V50111 (long gone)
« Reply #7 on: September 13, 2019, 08:22:06 AM »
It just seems to make sense, a square edge would act like a scraper, I remember the huge bearings on grinding mills had a taper to encourage the oil into the bearings.
