Author Topic: Wiring in "driving" lights on a V7 Stone  (Read 6201 times)
« on: September 13, 2019, 10:42:30 AM »
I'm adding a pair of small LED lights, mounted to the crashbars. On-off switch will be mounted to the left side of the handlebars. Is there a convenient location to tap into for switched 12 volt power? Somewhere that won't involve removing the tank or hacking into the harness?
Re: Wiring in "driving" lights on a V7 Stone
« Reply #1 on: September 13, 2019, 10:54:48 AM »
I believe the GPS connector that is under/behind the headlight is a fused 12V connection? If the LED driving light draw is low enough I would think that might work.
« Last Edit: September 13, 2019, 10:57:17 AM by Kev m »
« Reply #2 on: September 13, 2019, 11:57:26 AM »
Thanks! I do remember seeing an unused connector there now that you mention it. The lights are 12 watts each.
« Reply #3 on: September 13, 2019, 09:02:42 PM »
This one Kevin? (11)
http://www.thisoldtractor.com/guzzi007/schematics/2013_V7_Series.gif
It comes from a 15 Amp fuse if you put a 5A between the connector and the switch it should blow first if you get a short in the driving light.
« Reply #4 on: September 13, 2019, 09:40:11 PM »
Yea, there's a Tom Tom (GPS) connecter (green) stashed up near the headlight bucket.  Goes hot when ignition is switched on.
Offline SportsterDoc
« Reply #5 on: September 13, 2019, 09:52:01 PM »
Yes, #11 in the schematic linked by Kiwi Roy and powered by keyed switch, which is #14.
And good advice from Roy re low amp fuse for the intended 2 amp load.
« Last Edit: September 13, 2019, 09:54:22 PM by SportsterDoc »
23 V7-850 23 Yam XT250 18 Yam Bolt  22 Triumph St Twin  20 CanAm Ryker 14 Honda CB1100 18 Yam XT250 16 MG V7II 17 Yam TW200 12 Triumph Bonnie 02 Sportster 1200S 03 Sportster XLH883 76 Honda 750F 75 Honda CB360 70 Yam CT1 72 Yam CT2 72 Yam AT2 70 Honda SL350 70 Honda CL350 67 Honda CL160 67 Honda C11
« Reply #6 on: September 13, 2019, 10:01:22 PM »
Cool. Already ordered the Mercedes "piping" (connector with wires referenced in another thread I found on the subject) to hook to it.
Offline jpv7
« Reply #7 on: September 14, 2019, 09:00:31 AM »
Yes.  It's on the headlight circuit.  I tapped my fused, heated grips off of it with no issue on my V7ii.  Koso Apollo 120mm type.
« Reply #8 on: September 18, 2019, 06:27:58 PM »
I picked up the expensive little "piping" yesterday at Mercedes-Benz of Hagerstown and wired up the lights this evening. Cheapy switch, Emgo brackets and small lights all from Amazon. Very noticeable in daylight, need to get it out dark to aim them. Less than $100 for everything.
« Reply #9 on: September 18, 2019, 08:15:42 PM »
Nice job!
Offline MMRanch
  • MMRanch
« Reply #10 on: September 18, 2019, 10:37:56 PM »
Let us know if those extra light has an effect on folks pulling out in front of ya !
Did you get a close up picture of where that GPS plug is ?   I've never noticed it before.
2016 V7-II Stone
Online Perazzimx14
« Reply #11 on: September 19, 2019, 05:10:39 AM »
If you prefer to isolate auxiliary component wiring from the motorcycle Amazon has nice fused sub harness's with relays and a momentary and/or rocker switch all for $13.00.
Sub harness wires directly to the battery via ring terminals then the a trigger wire from the relay is spliced into a keyed power source.
2017 Road Glide Special
2020 Kawasaki KLX300SM
« Reply #12 on: September 19, 2019, 06:16:51 AM »
Nice job (of course) Charlie.. :thumb: If you're not careful you'll turn into a small block guy.  :smiley:
« Reply #13 on: September 19, 2019, 08:04:41 AM »
I probably won't be running them all the time, only as "ditch lights" after dark.
No photo of the green GPS connector, but I saw it in another thread here. Mine is bundled with a few others just forward of the steering head.
Offline Zoom Zoom
« Reply #14 on: September 19, 2019, 08:10:17 AM »
Charlie, it appears you have already dealt with this but for future reference, I have replaced that connector with a standard SAE two prong plug when I have messed with that. Very inexpensive and makes obtaining the mating connector easy. A little solder and shrink wrap and that's it. FWIW, the shielded end of the connector is always with the power feed, as opposed to the device end.
John Henry
« Reply #15 on: September 19, 2019, 05:20:20 PM »
John Henry
I could have any number of connector types, but didn't want to hack the harness, so chose the Mercedes part. Definitely more expensive, but was "plug and play" and looks factory.
Offline nursed
    • Diary of a Retread
« Reply #16 on: February 25, 2024, 09:44:15 PM »
Does anyone know the part # of the Mercedes/Tomtom plug referred here? Or have an idea of where I could order one. Want to add some visibility to my V7iii
