Author Topic: 1983 Cal 2 float needle and seat  (Read 734 times)
Offline Pfribley
« on: September 15, 2019, 12:42:44 PM »
The float needle in my Cal 2 finally quit shutting off the fuel. A dismantling showed that the original needle had a ring around  it like one of saturns. Quick research revealed that the original needle was no longer available. Now I have to get completely new needle and seats. So a new pair of 250 needle arrived. The next question is " do I have to reset the float levels after replacing the old needle and seat with the new ones????" Thanks.
Re: 1983 Cal 2 float needle and seat
« Reply #1 on: September 15, 2019, 07:10:27 PM »
Yes, you should check the float level and adjust it if necessary.
