Author Topic: Inner Tube Choices - LM3  (Read 1932 times)
Offline Vince in Milwaukee
« on: September 15, 2019, 12:44:08 PM »
So, I already have my rear tire picked out for LeMans III, but need to make sure I purchase the correct sized inner tube.  Going to some web sites is like sorting through a jungle of numbers, ratios, sizes, etc...The tire size is a 110/90-18.  I know that there are quite a few old Tonti framed owners on here; what are you using?  Thanks in advance.
Gone but not forgotten:
Offline guzzista
Re: Inner Tube Choices - LM3
« Reply #1 on: September 15, 2019, 02:22:57 PM »
Michelin, Metzeler,  Continental,Avon,  Pirelli, IRC, Kenda. They all work. Using heavy duty type tubes  as in trail bikes , makes them  more cumbersome to  fit in rims due to their thickness . Alternatively you could go tubeless. Safety beads were not built in in the FPS wheels used on vintage Guzzis so the decision to go that way is purely yours. I have been running cast Guzzi wheels tubeless since the mid 1980's without any problems.
« Reply #2 on: September 15, 2019, 03:14:43 PM »
When I need tubes I try to buy ones made in Japan not China,Bridgestone are good.
My tubes from Japan have lasted 47 years without a single flat,
« Last Edit: September 15, 2019, 05:54:00 PM by fotoguzzi »
Online Aldo
« Reply #3 on: September 15, 2019, 08:24:31 PM »
You need a 3.50x18 inner tube. They're usually pretty cheap, so I recommend you buy a spare just in case.
MGNOC Lifetime Member
1973 Eldorado 850
1971 Ambassador 1000 Automatic
1960 Gilera Giubileo 98
1967 Benelli Sprite 125
Offline Groover
    • Scooteropolis
« Reply #4 on: September 16, 2019, 07:39:15 AM »
Go with the Michelin that are of natural rubber. Some of the weird brands split when perforated, whereas the naturals won't do that. I'm also running tubeless on those rims. They should have stampings on them, and depending what they are, even though not rated tubeless, will work and be safe. Of course, at your own risk  :azn:
There are a bunch of threads on this forum in regards to tubeless, and here is one of them: https://wildguzzi.com/forum/index.php?topic=76391.0
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline Stevex
« Reply #5 on: September 16, 2019, 11:29:40 AM »
I'm running my LM2 on tubeless.
« Last Edit: September 16, 2019, 11:30:09 AM by Stevex »
