Author Topic: 2013 v7 special won't idle when cold  (Read 3234 times)
Hymes Inc.
« on: September 19, 2019, 06:31:27 AM »
Bike is stock. Always have to warm it up before taking off or it dies, which is normal for a factory v7. Just recently it won't stay running when "cold". Would idle up at start but then idle down and die. Won't restart without some throttle either. I can keep it running by playing with the throttle and once it warms up It's fine. Starting to miss that choke cable.
Offline pyoungbl
Re: 2013 v7 special won't idle when cold
« Reply #1 on: September 19, 2019, 09:09:39 AM »
Beetle's map will take care of the cold stalling and probably help with the idle too.  I'd take a look at the valves, plugs and plug caps.  If they are out of spec or (in the case of the plug caps) failing they just make the minor issues that much worse.
'13 V7 Special (red/white)
Offline malik
« Reply #2 on: September 19, 2019, 04:48:11 PM »
What he says. Also ensure the air filter is clean (replace it) and that there's no oil overflow to the airbox. V7's seem to prefer good air.
Hymes Inc.
« Reply #3 on: September 25, 2019, 10:31:44 PM »
Must have been bad gas. Problem went away on it's own.
Hymes Inc.
« Reply #4 on: September 26, 2019, 08:01:02 PM »
So.....only acts up if its below around 75 degrees.  :huh:  Thought it took care of itself but it was around 80 when it worked fine. Went for a ride the other evening and it was 73 out and wouldnt idle.
Offline pyoungbl
« Reply #5 on: September 26, 2019, 08:25:27 PM »
I'll mention it again...Beetle map will solve the problem.  It's a known issue with the OEM mapping.
Hymes Inc.
« Reply #6 on: September 26, 2019, 10:43:48 PM »
I'm aware the map makes it better. I have put 16k miles on this bike in 3 years and have never had this issue. Is my temp sensor going bad?
Offline fossil
« Reply #7 on: September 26, 2019, 11:27:26 PM »
Nothing against a Beetle map. My 2013 Stone has none, it has the last iteration of the standard map. And I can start the engine in any temperature between - 8°C and +38°C, it idles, and after putting on the gloves I can ride without any problem. I think the bike in question has a small issure that should be mended before the map is exchanged. I would take a look on the Lambda probes first (I know similar issues from cars). There is a whole chapter that describes the test procedures of the probes in the shop manual.
« Last Edit: September 27, 2019, 05:42:22 AM by fossil »
Greetings from Germany!
Thorsten
Hymes Inc.
« Reply #8 on: November 09, 2019, 07:26:10 AM »
So it seems that a valve adjustment has solved the issue. Intake valves weren't to far off but the exhaust was .003, should be .008
Offline moto-uno
« Reply #9 on: November 09, 2019, 06:46:17 PM »
  Did you do anything else when you adjusted the valves ? Just curious ?  Peter
Offline blu guzz
  • Loves to ride
« Reply #10 on: November 10, 2019, 06:21:06 AM »
my old air head needed the valves adjusted religiously at 2500 miles or i would get the same problem.  of course modern bikes with modern metalurgy allow far longer intervals but it is still the simple things isn't it.
Blue Guzz
Hymes Inc.
« Reply #11 on: November 11, 2019, 11:35:50 AM »
Nope.
