Author Topic: Next (personal) project - Moto Morini 3 1/2 Strada  (Read 242372 times)
Re: Next (personal) project - Moto Morini 3 1/2 Strada
« Reply #90 on: January 29, 2020, 10:30:54 PM »
Happy Birthday! lo :thumb:okin good
What is your preferred cleaning chemical for bare aluminum cases?
I vapour blast my parts
Online SIR REAL ED
  • uh.... it's personal....
« Reply #91 on: January 30, 2020, 08:21:03 AM »
I did not mean as a restoration, I meant on a bike that is still assembled, what would be your favorite cleaner?
2002 MZ Skorpion
1994 DR Skorpion
« Reply #92 on: January 30, 2020, 09:53:27 AM »
If the engine is in the frame I have used a diluted solution of NAPA Aluminum Brighter, deadly stuff if not used with the appropriate safety gear but it will restore the aluminum to near original finish if you are patient. The Aluminum brighter is used to restore the bright finish on aluminum tanker trucks, manufacturers recommend a 25/1 mix ratio with water, I go anywhere 5/2 ~ 2/1 depending upon how awful the corrosion is. You must have a full face respirator with the proper acid cartridges and wear rubber gloves. Once you mist the surface of the aluminum it will foam up white as the oxidation is broken down then after a few minutes a high pressure wash is run over the engine, it takes anywhere between 5 and 10 passes of solution and high pressure but it will come out looking close to vapor blasting. Do this outside with a good high pressure wash wand. It will not hurt the paint but it will discolor anodizing so keep it off brake calipers! I have used this for many years and before I got a vapor blast cabinet it was my go to method of cleaning aluminum, engine cases, transmissions, wheel hubs, rims etc....
This Eldo engine sat outside in Florida for decades
And this is the cleaned engine case, NAPA product and respirator
« Last Edit: January 30, 2020, 09:54:46 AM by canuck750 »
« Reply #93 on: January 30, 2020, 08:31:18 PM »
A little more done this evening: installed the primary gears and oil pump.
Online SIR REAL ED
« Reply #94 on: January 31, 2020, 05:01:20 AM »
Thanks Jim.  Very interesting.  I have never used that chemical before.  Additional thanks for the safety tips.
« Last Edit: January 31, 2020, 05:02:56 AM by SIR REAL ED »
2002 MZ Skorpion
1994 DR Skorpion
« Reply #95 on: January 31, 2020, 08:45:27 PM »
Prepped the left outer case for installation. Oil pressure relief valve and all seals installed.
how to view direct photos on facebook
« Reply #96 on: February 01, 2020, 09:42:54 PM »
My latest order from Mdina Italia arrived today. New fork tubes and sprockets. The sprockets are for 520 chain rather than the 530 that's stock. There's not much clearance for the chain in a few places, so the 530 chain needs to be the non-o-ring type. With a 520, there's plenty of clearance to run an o-ring chain. The rear sprocket is alloy - hopefully it doesn't wear out quickly. Weighs a lot less...
Made a little more progress this evening. Installed the kickstart assembly and then the left-side outer case.
Offline SED
« Reply #97 on: February 04, 2020, 10:37:59 PM »
Beautiful work Charlie.
1983 LeMans III
1981 Monza
1947 Ariel Red Hunter
1939 Ariel Red Hunter
1937 Guzzi GTV
« Reply #98 on: February 06, 2020, 10:03:17 PM »
Do over. After I installed the left cover, I started on the clutch, first piece was the clutch basket. While installing it, I spun the main shaft - the starter ratchet was not disengaging, which meant that I had somehow installed it incorrectly. Back off with the cover, head scratching what I'd done wrong.
Fortunately, I recently bought an engine assembly manual done by the US importer of Morinis "back in the day", Herdan Corp. It's a bit easier to understand than the "blue book" factory manual. Once I followed the procedure in that and remounted the left cover, the starter worked like it should.
Installed the clutch basket again. "Back to square one."
Online SIR REAL ED
« Reply #99 on: February 07, 2020, 08:40:03 AM »
Good move catching it then Charlie.  Never hurts to doubt oneself a little bit and double or triple check.  It's only time.
On the plus side you end up with some great stories to tell down the line, and the experience of making a mistake is invaluable, saves one lots of money and pain down the line....... but only if you are man enough to admit it!  Great thread!
2002 MZ Skorpion
1994 DR Skorpion
Offline Groover
    • Scooteropolis
« Reply #100 on: February 07, 2020, 10:05:23 AM »
What was the problem? Was it one of those engaging type roller bearings in backwards?
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #101 on: February 07, 2020, 11:33:45 AM »
It's a kickstart assembly, so no "roller bearings" to mess with. For lack of better terminology, the issue was "timing" the ratchet so that it would retract properly. I don't know why I had a problem this time - I didn't when assembling the 3 1/2 Sport engine two years ago. Might be I was just too tired (I'm always working on my stuff at the end of the work day) and should have left it for when I was rested.
« Reply #102 on: February 07, 2020, 08:26:24 PM »
A bit of actual progress this evening. Cleaned, lightly greased and installed the "special washer" that goes between the clutch basket and hub.
Cleaned the hub and installed it with a new locking washer and pushrod seal.
Cleaned (I'm tired of cleaning!  :grin:) the clutch friction and metal plates and slipped them into place.
Too tired to continue, plus it was time to get some supper. Just the pressure plate, springs, cups and nuts to go yet, then I'll be done on this side of the engine.
« Reply #103 on: February 08, 2020, 09:24:56 PM »
Back at it today. Finished assembling the clutch: pressure plate, spring cups, springs and nuts installed.
Spent a little time wet sanding the clutch cover and then hand polishing it. It's not perfect, still a few scratches, but it's likely as shiny as when it left the factory.
Ditto for the ignition cover.
Started on the timing side. Sprocket installed. Cleaned the timing pulleys, washers springs, etc. and installed them. Slipped a new timing belt on.
Online SIR REAL ED
« Reply #104 on: February 11, 2020, 10:07:17 AM »
Charlie,
If you have the time, I for one would be very interested in seeing some pictures of your Moto Morini gas tank when you get it back from your "metal man" prior to body filler, paint, etc.
thanks,
Ed
2002 MZ Skorpion
1994 DR Skorpion
« Reply #105 on: February 12, 2020, 08:31:06 PM »
Installed the clutch pushrods (there are three pieces that go in from this side) and the actuating arm. Also installed the dipstick and oil drain plug.
« Reply #106 on: February 13, 2020, 09:16:58 PM »
Finally! The second shipment of my headpipes and header nuts made it through. Delivered today.
Mmm. Shiny.
Header nuts and crossover clamps.
czakky82
« Reply #107 on: February 16, 2020, 07:19:06 PM »
 :drool:
« Reply #108 on: February 16, 2020, 08:07:59 PM »
like Christmas in February!
« Reply #109 on: February 18, 2020, 08:57:19 PM »
All of the hardware has returned from Parker Metal Finishing. This is the second batch I've had them do and I'm very pleased with the quality.
All of it was done in trivalent clear chromate, except the voltage regulator rectifier cover which was done in trivalent yellow chromate as original.
Plate that holds the reg./rect. and fuse block, the screw for the fuse cover and horn bracket.
Misc. hardware.
Carburetor and airbox hardware.
« Last Edit: February 19, 2020, 08:47:54 PM by Antietam Classic Cycle »
Online SIR REAL ED
« Reply #110 on: February 19, 2020, 05:41:49 AM »
Outstanding thread Charlie.  Thanks for taking the time to post all this.
I love your engine stand!
2002 MZ Skorpion
1994 DR Skorpion
« Reply #111 on: February 24, 2020, 09:31:59 PM »
My friend John Abbleby stopped by this morning to drop off these decals he made for me. The go on the voltage regulator cover, top triple clamp, right gas tank trim and left gas tank trim.
Offline Groover
    • Scooteropolis
« Reply #112 on: February 25, 2020, 02:33:27 PM »
Nice labels. Do you know how he makes them?
1980 Vespa SI Moped
« Reply #113 on: February 25, 2020, 03:53:16 PM »
He printed them with a laser printer.
« Reply #114 on: February 29, 2020, 08:39:40 AM »
The frame is finally back from the welder, steering stop repaired and the divots in the downtubes (from crashbars being clamped on?) filled in. Ready to go to the powdercoater this week.
« Reply #115 on: March 01, 2020, 09:23:02 PM »
Laid the rest of the chassis parts out, inspecting each part as I went. Found one more part that needs a little work - the centerstand has a hole worn through one of the "feet".
I'm planning to have these parts done in wrinkle black.
Cleaned the rear fender and chain guard. Both have scratches and acid stains that need to be buffed out.
« Reply #116 on: March 02, 2020, 10:27:37 AM »
Nice job fixing the frame downtubes, a lot of guys would have just painted over the dented tubes, this bike deserves the full Monty!
« Reply #117 on: March 07, 2020, 08:35:05 PM »
My friend Martin welded up the centerstand "feet" and this evening I ground them back to flat. I'm finally ready to take everything to the powdercoater on Monday.
Offline Motorad64
« Reply #118 on: March 13, 2020, 11:59:43 AM »
looking good!
LesP
« Reply #119 on: March 14, 2020, 05:40:33 AM »
Was at a swap meet today and what did I see.
