Author Topic: '76 Moto Guzzi V1000 Convert refresh/reawakening after 28 years...!  (Read 40963 times)
Offline Pescatore
Re: '76 Moto Guzzi V1000 Convert refresh/reawakening after 28 years...!
« Reply #30 on: December 10, 2019, 10:29:09 PM »
Clever spring idea. Love it!
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
Offline radguzzi
« Reply #31 on: December 13, 2019, 06:15:21 PM »
Checking valve clearances before putting the covers back on with new gaskets.
I usually pull the plugs and use the rear wheel with the gearbox in top gear to rotate the engine, cycle on the center stand to find TDC however, this time I decided to simply turn the by way of the rotor securing bolt.
Good thing I went this way... In pulling the alternator cover off I discovered a broken bolt lug. Bummer.
I have another cover to use so it's not a big ta-do although this one has been on the wall of the garage for years, I'll look for another on the SP or T-3.
I found this handy Tee type tool years ago by a now defunct outfit that made them, makes holding the tappet adjuster stud very easy and precise.
Find TDC for the left cylinder by rotating the assembly around to the "S" mark on the flywheel, check that both valves are closed on the compression stroke and check/adjust as needed. "D" mark for the right cylinder.
Valve clearances are set at .009" / .229 mm and they are spot on.  Rocker shafts seem fine although I did not pull them to measure.
The good news is that the alternator, rotor and related connectors appear to be in good condition.
I'll add the cover spacer used on later models which is located behind it, the spacer allows for additional air flow to help keep the engine mounted rotor relatively cool.
More later...
rad__
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
'80 SP 1000 Two (2) actually
2013 Harley FLHTC
'75 Triumph T160 Trident
'78 Triumph T140V Bonneville
'76 Honda CB550 Four
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
The Journey is the Reward
Offline radguzzi
« Reply #32 on: December 14, 2019, 07:33:34 PM »
So yes, I know I jump around like a fart I a frying pan, I'm on the spectrum...  :shocked:
I decided to go ahead and order a few more parts; replacing the dual choke assembly with the individual flip style chokes and after talking with Charlie Mullendore.  The original mounting spot which is a bracket on the top/right, left side valve cover bolt is really just plain in the way.
That location has, in the past caused issues on other Guzzis including chafing on the tank, silly design in my estimation.
Also adding the air spacer for the alternator cover and a couple of other bits etc...
As a side note, if I were doing a full or even partial restoration, I would have attacked the systems individually, assessed needs and placed one large order for all parts. This way, as I bounce around I end up paying for more shipping but hey, it happens.
In the meantime, I went back to the brake system. The rear F08 needed a seal kit, well, I think it did so I have one, might as well use it.
During tear down I had noticed that the rear caliper already had the updated pistons so I ordered just the seal kit. Taking the seals out of the bores show the seals looking fine but again, renewed.
Seals in with the pistons...
Dust boots and O-ring in place...
Bolted up...
Insert the pads and pins...
In place...
While we are on the rear brake... this is a odd little rig, parking brake which is set when the side stand is deployed via a cable. Pretty cool really and fully functional, adjuster as well.
Side stand lug prior to setting the brake...
And with the weight of the motorcycle on the stand... brake set.
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
2013 Harley FLHTC
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
Offline radguzzi
« Reply #33 on: December 20, 2019, 07:23:21 PM »
I just did some little things today, new plug caps, some cleaning, made notes for the missing brake caliper bolts, pulled the rear rack off that I don't want to use, investigated the mounting and wiring for the forward directionals etc.
For some unexplained reason I actually tried some naval jelly on the lightly rusted surfaces, some chrome cleaned up well however, the canisters might get the flat black high heat treatment, we'll see.Old plug caps. I have never liked these, early in the 80's I had my first SP 1000 and the metal plug caps were a constant issue so ever since then I have replaced them with the NGK plastic caps, installed new with dielectric grease for the rubber boots.
New NGKs...
While waiting on the new manifold gaskets, flip type choke assemblies and the alternator spacer with bolts I did a test fit for the carb this afternoon. Due to the new K&N filters, just wanted to make certain of the clearances with no surprises. All good, I can run the new cables, new fuel lines and bolt the carbs and manifolds on. The little chrome thingys are the support guides for the plug wires that will bolt to the lower manifold securing bolt.
The small parts showed up via late day FedEx delivery... easy bolt up in the morning with coffee.
Getting back to the 'Vert after moving a bit of snow and a trip North... busy time of year.
Alternator cover fitted with the spacers and new stainless bolts...
Test fit for the carbs, manifolds with new gaskets and with the tank in place to route the fuel lines including the dual spigot banjos. I'll install the cables tomorrow and use a remote tank to start the V1000.
In the lower shot you can see a small dent in the tank just forward of the fuel tap which was caused by the stock dual choke lever mount. The bracket attaches to an upper valve cover bolt and the tank settles down onto the "L" shaped bracket chafing and scratching or worse, glad to have it gone.
Well she runs but you're gonna have to take my word for it.
I installed the new throttle cables, set up the remote tank and fuel lines and touched her off... so to speak. No leaks, no smoke, no sputtering, no bad noises but Revs were way too high.
I got to looking at the cable adjusters, no problems at the throttle however, the carb tops were adjusted too high.
For a minute there I was wondering if the carb tops should not have adjusters, a PO had them set high and now it idles. Well, did.
So as I looked around for the reason or reasons for the high rev she was started several times and the became reluctant to participate finally came to say, "I'm done"
I get a click click, click from the starter relay. Not certain if the relay is the issue or the tin foil, piece of crap stock started switch assembly. Battery is up.
These components are forty-three (43) years old and have sat unused for twenty-eight (28) so corrosion Could be an issue.
I pulled all the connectors off the relay to hopefully reestablish contact but she ain't havin' it. As I recall though the relay has an adjustment coil in it, I could be mistaken, I'll pop it off tomorrow and have a look.
In a more bizarre situation, I have not been able to find a replacement relay, P/N 12 73 25 00, so far I have only checked one supplier that is usually well stocked.  Some folks on eBay list a relay and show a picture of a regulator... come on peeps.
Anyway, I'll continue to trouble shoot and hope that it actually is that relay and I can find one, the bar mounted switch is not a fun exercise to replace. I have done these on a T-3 and CX LeMans so the task is not out of the question, just time consuming matching wires and all.
In general though, wicked pleased to hear it run, one never knows if you are bringing home a pig in a poke or not Loves me some Tonti Guzzi sounds.
Post start up...
El-crapo starter switch...
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
2013 Harley FLHTC
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
Offline Burkslaw
« Reply #35 on: December 21, 2019, 08:50:03 AM »
This thread is a great motivator! Thank you for all the details/photos. I'm heading out to wheel my old R/100 from garden shed to garage to start the rehabilitation during Christmas vacation.
Fortunately, both of my Guzzi's are up and running properly.
Offline radguzzi
« Reply #36 on: December 21, 2019, 06:29:48 PM »
An R/100 huh...?  Cool. what year...?  So get to it.  We will need progress reports.   :wink:
rad__
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
2013 Harley FLHTC
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
Offline radguzzi
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
2013 Harley FLHTC
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
Offline ozarquebus
  • Grand Canyon Pack Rat
  • Riding since 1979
« Reply #38 on: December 22, 2019, 06:05:09 PM »
Hooray! Sounds good!
 Convert Hangar Queen
Online wirespokes
« Reply #39 on: December 22, 2019, 11:50:23 PM »
Just a note on something I discovered. My 77 T3 came to me with the K&N filters and they didn't want to mount very well. The threaded section they mount to isn't but a 1/4" or 3/8. The clamp is wider. The end of the filter where it clamped had shrunk due to the clamp, so it just didn't fit well.
i had a set of tubes that thread onto the carbs that were probably part of the original airbox setup. With those installed, the filters clamped on nicely and I discovered the bike ran much better. The filters still mounted close to the carb so nothing much had changed there, but the intake tract evidently needed that extra length.
You might check that out.
Offline radguzzi
« Reply #40 on: December 23, 2019, 07:06:25 PM »
Correct, I had grappled with which way to go when I decided to use the K&Ns.  The velocity stacks are employed here with the correct size filters.
Thanks,
Rob
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
2013 Harley FLHTC
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
Offline radguzzi
« Reply #41 on: January 12, 2020, 08:49:12 PM »
A little more progress...  Lots going on up here in the Great White North, we move snow around just for the heck of it.   :rolleyes:
I had experienced a relay giving up the ghost after that many years sitting.
New replacement relay in position, I had removed the rear master cylinder to pull out the old relay and accurately identify where each wire connected.
Final Drive Unit...
The Final Drive was the typical oily, greasy mess. Drained the fluid which amounted to the requisite 250-ish cc of some kind of oil, at least it was not water... I flushed the housing with a healthy dose of 80W-90 synthetic gear oil that I happened to have on the shelf, spun the assembly by hand and will add 250 cc of 80W-90 going back in.
Cleaned up ok, I cannot get the right hand canister off so this is as clean as it will get unless I saw the mufflers off.
29/Gearbox and ATF fluid change...
To heat the gearbox oil for draining that has sat for who knows how long, I set up the V1000 with a roller for the rear wheel while running the engine so as to be able to spin the trans to warm it slightly to drain the gear oil.
The reason for setting the wheel down onto the roller is to reduce any strain on the Cardan Joint (Double U-joint) vs letting it hang with the motorcycle on the center stand. This more closely replicates the road condition of riding on the road.
Just a short time on the roller warmed the gear oil for draining. I ran the rear wheel at about 10-15 miles per hour for a total of about four miles. Drained and flushed the gearbox with more 80W-90 to give the bearings and shafts and nice healthy bath of fresh fluid and topped up the gearbox to the proper level.
Strange little gearbox also, less volume that the conventional five speed boxes, 600cc of gear oil vs 750 and no level plug.
I have yet to decide that to do about the ATF in the torque converter, lines and cooler. I may need to drain that and flush as well, thinking that new fluid is batter than the old stuff but I may need to wait until it is on the road. I would like to be assured that the flush will indeed replace all of the old fluid but I just don't know if I can completely flush the system, a good effort is better than nothing.
Rear wheel in the rollers...
Spinning...
I am working on a Triumph Bonneville concurrent to this rig.  Fun to have progress on one or the other almost continually.
The Guzzi got a new Odyssey PC-680 Battery and it sits in the vast area meant for a big-a$$ juice battery, I have one 3/4" shim on one side and going to use thick, dense foam on the other side to stabilize the battery.  I was please also that the stock securing straps work well with the new battery.
I also stick a Battery Tender loop on everything I own.
On the electrical subject I May install the EME EnDuraLast 450 Watt Charging System on the old boot but that is really getting ahead of things. I have installed these in two other Guzzis and Man, the accessory load is amazing. Heated gear and aux lights, no issues at all. Again, Maybe...
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
2013 Harley FLHTC
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
Offline radguzzi
« Reply #42 on: January 26, 2020, 09:54:40 PM »
Before I can put the tank back on I needed to be certain of the electrical items that need sorting that may access under there. I am actually quite impressed with the condition of the wiring harness in general, glad to see that it has not been hacked up..
Front directionals are all set.
I had to trace a bit of wiring modification due to the Vetter installation. Long story made thankfully short for you, the color codes do Not stay constant from OEM wiring harnesses to aftermarket equipment. The interface from the main harness to the fairing is pretty well done though. These were on the rear of the Guzzi, mounted on the rear rack that has been removed. I like them up front.
With the front signals all set I need to find a set to use out back. All of the Lucas units that I have in the parts stash are in need of either gaskets, lenses, some wiring or repair of some type so I Flea-bay'd a set of Lucas knock-offs complete and reasonably priced.
I will make up a mounting bracket to suit the clearance of the side cases.
The "Driving lights" that were on the fairing are leaving, they are huge, old style sealed beam type lights and were in the way of the signals, I could just hang them off the bottom of the mounts, they are kinda neat but I will use a set of smaller LED units.
The angle bar mounts that must have been fabbed by a bridge builder, 1/4" angle and flat bar incorporated into the Vetter platform, a bit of overkill.  I'll cut them back to a decent size for the replacement lights.
The directionals arrived, actually too nice to put on this old boot... The stem thread ended up as 7/16" - 20, I bought two new lock nuts so that when I make a bracket for them I can secure them on both sides of the bracket.
Rear directionals...
The seemingly never ending saga of the rear directionals... and moving snow...!
These things have had me scratchin' me 'ead over just how to mount them. The biggest issue was that the directionals that had been mounted on the rear were moved to the front because I eliminated that rear rack that they were bolted to. Plus I like the look of them in front.
Another issue is that the Convert does not have the standard Lunchbox style cases so the stock Convert signal brackets May not clear the Samsonite cases.
So, I came up with a plan to attach the signal stalks to the rear of the plate bracket. I welded a pair of machine collars onto the bracket, ground a flat on the OD radius for stability, aligned with a 7/16" diameter rod to hopefully keep them in alignment, clamped in place then welded to the bracket. Boom. Worked pretty well. Painted flat black and replaced the steel set screws with brass.
Stems locked into place with a set screw and nut, I used the Schnorr type lock washers also.
Mounted...
On a side note, that plate light assembly is a tricky little bugger to get into for changing bulbs... wow...!
And they clear the side cases...
In my stash of old plates found a '74 plate with a '76 registration tag on it, in this state one can use a "Year of Issue" plate however, that might be pushing it in that it only has the tag. I may just go Antique, Historic in some states.
I'm going to saw off those giant light brackets up front next and mount the new LED running lights.  Then I can get back to mechanical items, bleeding brakes soon.
« Last Edit: January 27, 2020, 05:09:38 PM by radguzzi »
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
2013 Harley FLHTC
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
« Reply #43 on: January 27, 2020, 10:14:33 AM »
Offline radguzzi
« Reply #44 on: January 29, 2020, 10:48:12 AM »
Back to some mechanical items...
Rear parking brake...
This is an unusual however, pretty effective little device, bolts on behind the rear caliper and activated via cable when the side stand is deployed.
The "Pucks" are adjusted for bite onto the rear rotor by way of the Allen set screws in both sides of the housings. I removed it to service and lubricate the moving parts and to ensure that it works properly.
Bleeding the linked brakes; apply the pressure to the right side foot brake pedal and the front/left and rear calipers are activated... as most of you already know.
I do not recall having the bleeding go so well in recent or even not so recent history.  My lovely assistant Sue Ellen doing the brake pedal work while I release the air from the fluid at the calipers. When the pedal became firm I lifted the rear and set the Guzzi onto the centerstand, spun the rear wheel and hit the brake pedal, stopped the wheel. Excellent.  :thumb:
We will go through the entire process again to gain all that we can but, so far, so good.
I had forgotten to order a front master cylinder rebuild kit so I'll get that heading this way and do that caliper later.
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
2013 Harley FLHTC
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
Offline radguzzi
« Reply #45 on: January 30, 2020, 10:00:52 AM »
Front master cylinder...
For some odd reason I had neglected to order a master cylinder rebuild kit with the first round of parts, possibly thinking that I had one on the shelf... no go. Luckily I can rebuild this one in situ, I would not want to disturb the right side switch, it works... !  :thumb:
This guy was pretty gummy and crappy inside, old fluid etc... it will clean up well.
Small wonder the plunger was stuck in the bore huh...?
These are not a big ta-do for renewing, I use the correct sized deep socket to drive the lock ring with the seal an washer into the bore which looks good.
More later,
rad__
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
2013 Harley FLHTC
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
Offline radguzzi
« Reply #46 on: January 31, 2020, 11:46:24 AM »
Brake bleeding tool...
The rear brake on the big twins has always been an odd thing to get at for bleeding with a straight wrench, for me.
So as not to break up a set of existing wrenches in the garage, I bought a new Craftsman 11MM wrench, heated and formed it to a very useful arc. Works well for a full stroke when bleeding the calipers.
At first I was disappointed to find a twelve point vs a six point however, this actually worked out much better for positioning. The fitting is new and not frozen or tight so, we're good.
Open...
Closed...
More later,
rad__
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
2013 Harley FLHTC
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
Offline radguzzi
« Reply #47 on: February 04, 2020, 06:39:59 AM »
Front master cylinder rebuild...
Which is really not much of a rebuild, the kit consists of a new plunger, O-Rings, washer, seal, lock ring & spring.
Disassembly is straight forward, pull the banjo bolt on the outlet, drive the plunger assembly out with a small diameter punch.  Clean the bore as best you can, install new plunger.
I like to use the proper size socket to drive the new assembly into the bore of the master.  I pulled out the 1/4" drive 13MM deep socket and the 3/8" drive 13MM deep socket and the best fit is the 3/8" drive.
The diameter allows the socket to press the lock ring into the bore completely, the larger diameter 1/4" drive socket would have stopped shy of seating the plunger assembly.
FYI. Mic the OD of the driver that you choose.
Coat the assembled plunger with O-Rings with the Brembo assembly grease, wipe off excess prior to going into the bore.
Slide the plunger into the master cylinder bore, the first O-Ring will offer some initial resistance and quickly give up with slight pressure.
Follow that up with the driver to seat the seal and lock ring, shown here by tapping the driver in with a brass drift and hammer.
I decided to replace the reservoir cylinder cup and rubber bellows just to do it, retaining the original Brembo cap, no idea why...
New sealing washers on the banjo bolt.
The brake lever has great action, bleeding tomorrow...
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
2013 Harley FLHTC
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
Offline SED
« Reply #48 on: February 04, 2020, 10:24:24 PM »
Looks great Rad.  Like the details.  Careful and thorough work.
1983 LeMans III
1981 Monza
1947 Ariel Red Hunter
1939 Ariel Red Hunter
1937 Guzzi GTV
Offline radguzzi
« Reply #49 on: February 07, 2020, 02:57:25 PM »
Replacement driving lights...
The huge aftermarket driving lights that were on the Convert when it came here had to go, old style sealed beams and giant angle bar brackets. Just wow.
I cut down the existing brackets to suit the new LED lights, tucked them in about 6" closer and mounted them under the brackets. All lights work, brake lights even the side marker lights mounted on the Vetter. Pretty cool.
They are more for the visibility of he motorcycle by others on the road than actual driving lights however, the wiring was there and what the hey... A night time ride will tell whether they are good for poaching deer or not.
I am running out of stuff to do it really, she runs, fluids have been changed, needed accessory repairs have been made, additions are done. I will need a road test to determine how the brakes turned out. After that, if it proves to be worthy of tires then we'll go from there. I'll do a leak test on the tank prior to mounting it back onto the frame, install the seat and wait for Spring.
More later,
rad__
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
2013 Harley FLHTC
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
Offline radguzzi
« Reply #50 on: February 10, 2020, 07:39:40 PM »
Painted parts...
So in that this project is, as described a refresh and not a restoration the painted part have come into question. The poor guy has a bit of a patina although the paint is actually not too bad, what to do.
Well one thing fer sure I ain't gonna paint it.
I had used some naval jelly on some of the red chrome just to try it out and that turned out decent. Turning to the lightly pitted and rusty side covers, I coated one with the jelly, let it sit for about fifteen minutes and washed it off. The jelly did not harm the paint at all.
The next dilemma was whether to polish the parts or just which way to go. I think I will clear coat the painted parts right over the areas that is missing paint, it's all the rage with the hot rod guys...!
This left side cover looked just like the right side cover in the lead photo before the naval jelly and wash. The finished assembled motorcycle will have that general tatty appearance so I don't mind.
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
2013 Harley FLHTC
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
Offline radguzzi
« Reply #51 on: February 19, 2020, 08:23:45 PM »
Well I have gone as far as I had first planned to with the refresh on the Guzzi, I knew at the outset that this would not be a full restoration.
I need to do a final brake fluid bleed on the rear and front/left calipers, they are good but just to wrap it up and be certain.
Hoping to get a road test in within a month or so, we still have the rest of Winter to slog through... If she proves road worthy new tires and tubes will be in order. ;)
Thanks for playing along.
More later,
rad___
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
2013 Harley FLHTC
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
Offline s1120
« Reply #52 on: February 21, 2020, 07:44:45 AM »
Just a thought on the side covers...  Not really a "restore" but maybe find a auto touchup paint stick thats close and just touch up those little chips and scratches. Still fits into the "not restored" look, but covers them up, and makes them look "kept up on"..
Paul B
« Reply #53 on: February 21, 2020, 09:39:16 AM »
Looks realy good, the right appearance for a preserved motorcycle. I agree with the suggestion to touch up the paint chips and then shoot a cover coat of semi gloss clear over the covers to protect them.
« Last Edit: February 21, 2020, 07:45:34 PM by Canuck750 »
Offline radguzzi
« Reply #54 on: February 21, 2020, 05:27:13 PM »
s1120 & Canuck,
Yes, I have thought of doing the touch up paint thing and then clear coat, the problem is finding just the right shade of silver.  I also thought I might just shoot the covers black, even I could do that...  And I hate to paint, I'm not good at it.
Thanks or the feedback, really looking forward to riding the Vert.
Best,
Rob
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
2013 Harley FLHTC
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
Offline s1120
« Reply #55 on: March 01, 2020, 08:45:41 AM »
s1120 & Canuck,
Best,
Rob
Go to a few car dealers. Todays cars come in MANY shades of silver and almost all car dealers will have a drawer full on diferent tuchup paints somewhere in parts. Bring a cover, and ask the parts guys. Most all parts guys would be willing to help with a cool project.. unless they are swamped...
Paul B
« Reply #56 on: March 01, 2020, 08:53:54 AM »
s1120 & Canuck,
Best,
Rob
I was going to have the sidecovers painted on my Convert until I got a few quotes that were more than I wanted to spend. So, I dropped them off at the local powdercoater and he made them black for $50/pr. Not too glossy either, matches the tank well.
I wonder if you might find a matching silver in finger nail polish? I've heard of this being done for chipped red colored parts.
Offline radguzzi
« Reply #57 on: March 26, 2020, 05:38:31 PM »
s1120 & Charlie,
I am just now seeing these posts. Good ideas for the touch up, I may end up painting the covers although the nail polish is a good thought too.
Thanks,
Rob
First test ride...!
The Convert was taken down off the lift yesterday, the weather was Not conducive to a test ride, today we had a small batch Maple Syrup to do and with that done got a chance to get a blast in. For fear of sounding like a teenage Valley Girl Oh My Gawd… this thing is a riot. What the Hell took me so long to find these rigs...?
I tried both gear ranges, all good, handles well, brakes are perfect.
Just a nice docile, lumbering hulk of a motorcycle. I like it a great deal already...! I did not put the cases on, wanting to keep a close eye on stuff at first.
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
2013 Harley FLHTC
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
« Reply #58 on: March 26, 2020, 07:35:09 PM »
 :thumb: :thumb:
« Reply #59 on: March 28, 2020, 01:14:38 AM »
Excellent follow through!  Congratulations.
