Author Topic: Floorboard conversion  (Read 1065 times)
Offline dxhall
« on: October 31, 2019, 10:29:50 PM »
I’m thinking of getting rid of the floorboards on the CalVin and using pegs.  I think this requires different lower frame rails. Would any of the Tonti frame rails bolt up to the CalVin frame?  I’d like to make a list of the stuff I’ll need.
Offline Ncdan
Re: Floorboard conversion
« Reply #1 on: November 01, 2019, 06:22:01 AM »
That’s going to be a lot of work. I had a CalVin for a couple years and rode it several thousand miles. With the floorboards, one can position their feet in any position desired, if you remove the heel shifter, which I did. Just some thought but each to his own.
« Reply #2 on: November 01, 2019, 07:05:39 AM »
It's not a lot of work and all Tonti frame lower rails will fit.
Offline steven c
« Reply #3 on: November 01, 2019, 07:59:43 AM »
 I had a T-3 FB that I changed over to pegs. I used it's lower rails and just cut off the floor board mounts, tabs and got a hold of a pair of T-3 foot peg mounts shift and brake lever.
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
