Author Topic: v85 tt mods  (Read 140940 times)
Offline mondtster
Re: v85 tt mods
« Reply #120 on: April 20, 2020, 04:25:47 PM »
What would you like to know ?
Can you provide dimensions for your stubs? I really don’t want to have to take the bike apart to figure it out until I have the material to make the exhaust. Thanks
Re: v85 tt mods
« Reply #121 on: April 20, 2020, 05:48:16 PM »
I’d tell you if I knew mate, but the fact is I just turned them to whatever looked right, then made a second one.
I did turn the recess for the pipe/s to 44.4 to accept the header, but again it was a “touch” thing more than a dimensional specification.
The I.D. of the stub is the same as the outlet port, and the bit that reaches in to contact the gasket is made to be a relatively neat fit.
This probably the most revealing shot..
As I see it, you’ve to keep the tolerances between the aluminium parts and the stainless a little bit looser than normal because I don’t know what expansion of dissimilar metals is going to do.
If I did it again, I’d probably turn a register for the exhaust clamp to slide on to in the time honoured way instead of welding it, but that’ll be ok.
Also, it really is 5 minutes to take the headers off, there are no demons waiting there.
« Last Edit: April 20, 2020, 05:57:29 PM by Huzo »
Offline Trialsman
Re: v85 tt mods
« Reply #122 on: April 29, 2020, 07:31:09 PM »
Originally I made up a set of mounts for placing the driving lights more or less in the factory position.  I felt they were bright enough to "burn out" the turn signals so I decided to mount a set to the crash bars instead.
I didn't want to weld a bracket to the bars so it meant putting up with a lot of weird angles to come up with the lights in the right placement.
2010 FE570 Husaberg
2019 Alta Redshift EXR
2021 Moto Guzzi V85TT Centenario
2024 Stelvio V100
2025 Arctic Leopard Ex-800
Offline Trialsman
Re: v85 tt mods
« Reply #123 on: April 29, 2020, 07:35:33 PM »
Initially I zip tied the wires to the crash bars and it looked really bad so I tore it all apart.  I drilled into the tubing and fished the wires through and out the top end.  It made for a much cleaner install.  The lights are much better now.
2010 FE570 Husaberg
2024 Stelvio V100
Offline Jayell
Re: v85 tt mods
« Reply #124 on: April 30, 2020, 01:43:38 AM »
Happy with that I went on and did it in aluminium
Nice work. 0.125"?
elvisboy77
Re: v85 tt mods
« Reply #125 on: April 30, 2020, 06:07:08 AM »
The Augostini y-pipe also causes a mild decel-pop.
As for other mods;
Heated grips
Heated seat
Aux LED lights and custom brackets.
Black powder coating for rear frame section, headlight support, and pannier racks.
Tubeless rim conversion with 90* valves.
Heideneau front tire Mitas Dakar rear.
Front fender mudflap.
Moto Mosko tank bag or Eclipse small bag for around town.
Harmonic dampners for bar ends.
KTM turn signals.
KTM sumo mirrors
Renthal bars.
Custom handlebar upright supports.
Voltmeter/dual USB charging.
Centec 5 circuit fuse block under seat.
Earth-x LiIon battery.
Hyper Lytes
Shortened license plate/reflector carrier.
Touring windscreen.
Custom bracket for Garmin 660 GPS.
Plastic film on wear areas.
Shorten spigot for fuel cap.
Cut glove box plastic for custom tool kit.
Change fork oil from 15wt to 7.5wt.
Ohlins rear shock with preload adjuster thinned to give 1/4 "more adjustment.
Turatech stainless, lower footpegs.
Welded wider foot plate for side stand.
KTM Baja ADV larger hand guards.
OEM crash bars.
Battery tender lead.
and the  V85TT  PA tag !!!
Wow!  What a cool list!!
Offline Kitze
Re: v85 tt mods
« Reply #126 on: April 30, 2020, 10:24:13 AM »
Wow some of you guys have gone gang busters with the mods. Nice.
All I’ve done...
MG engine guards
MG center stand
Heated grips
Denali lights
GPS mount
Windscreen mod
Anakee tires
Acres of reflective tape/stickers
Still need to install the hyper light brake lights from the Norge.
And rebuild forks. Gonna wait until everything reopens on the likelihood that I don’t have the correct springs on hand.
Couple of crappy pix. And yeah I know the garage is a mess.
V85TT, SV650
Re: v85 tt mods
« Reply #127 on: April 30, 2020, 11:49:16 AM »
elvisboy77
Re: v85 tt mods
« Reply #128 on: May 08, 2020, 08:54:24 AM »
Well I started on the GPS mount.
I began here and located one of these.
For the record, it’s a V85.
Then I cut this out and the next step is to pretty it up.
It will mount to the handlebar clamp at the requisite angle to be square to the line of sight. To get the angle will involve some chicanery, but I’ll post as I go.
Hey!  Where did you source 12 volt power for it?
Offline Kitze
Re: v85 tt mods
« Reply #129 on: May 08, 2020, 11:03:23 AM »
Elvis, I mounted mine on the bar clamp also. See above post.
I pulled power directly off the USB port on the dash. My unit draws a max of 3/4 amps and the port is rated at a little over 1 amp. Can’t remember the exact number. To be extra safe I also put a one amp fuse for the port and gps. I’ll never use that port anyway as it is a switched port.
V85TT, SV650
Re: v85 tt mods
« Reply #130 on: May 08, 2020, 02:41:17 PM »
I just tapped into the rear tail light wire.
Offline Kiwi Dave
    • Guzzi Gander Ltd
Re: v85 tt mods
« Reply #131 on: May 08, 2020, 03:38:43 PM »
Of course, being a USB port, you're only gonna get 5v out of that source.  For those who require 12v, there is a step up device that can deliver 12v out of the USB socket besides the dash.  I used one for a while to drive a 12v radar detector until I managed to install the proper harness.  Worked fine.
Offline Kitze
Re: v85 tt mods
« Reply #132 on: May 08, 2020, 04:36:22 PM »
True dat. Guess I should have been clearer. I tapped into the 12volt power Before the port. Not the port itself.
V85TT, SV650
Re: v85 tt mods
« Reply #133 on: September 26, 2020, 03:44:44 AM »
I took the pipes off the V85 today to make a small modification to the lines.
I was not totally happy with the way they ran under the motor, they were not parallel with the ground, but they are now.
While the muffler is off, I thought I’d investigate the prospect of mounting a lower one like on my mate’s BMW.
I think it will complement the existing lines and plan to angle it the same as the frame tube.
 Also the space between the top of the tyre and the guard will be see through and consequently enhance the “lighter” look that I am chasing.
It won’t be a carbon copy, but styled similarly.
Is there a photo shopper out there that could pop an Akrapovich, Termignoni or similar on the left side for perusal ?
Also, is there a muffler out there that is known to be appropriate for the ‘85 ?
« Last Edit: September 26, 2020, 04:00:41 AM by Huzo »
Re: v85 tt mods
« Reply #134 on: September 26, 2020, 01:07:01 PM »
I posted these before in my dello pics but don’t think anyone sussed em
Thought it would be mental loud, but no, barely louder than std, owner well happy, clearance for bags and no loss.
The cat is the silencer
picture hosting
Cat still heavy of course but concept I get, how he rides and truth of no loss, nfi
Can I have some details and better shots of what that is please ? I am very interested before I go on with replacing the muffler...
Re: v85 tt mods
« Reply #135 on: October 25, 2020, 02:44:04 AM »
Somewhere or other I posted a bit about bending the float arm on the V85 fuel gauge to give a more accurate indication.
The verdict is as follows.
I took the unit out and lowered the float to the point where the light came on and marked it.
Then lowered it all the way to the bottom and again marked it.
Then raising the arm to half way between those points, I held the mechanism still, while bending the float to the bottom. I rode the bike until the fuel light came on and immediately filled the tank from that point, it took 18 litres to fill, so that means there was 5 litres 120 km left.
That’s good enough..
Offline j.davis
Re: v85 tt mods
« Reply #136 on: October 25, 2020, 09:34:02 AM »
Can you tell me where the High Beam trace was taken from? What colour wire was it? Looking to fit a Skene controller for my spots.
« Last Edit: October 27, 2020, 08:41:09 AM by j.davis »
Offline v85kris
Re: v85 tt mods
« Reply #137 on: October 25, 2020, 09:54:09 AM »
As for other mods;
Heated grips
Heated seat
KTM turn signals.
KTM sumo mirrors
Renthal bars.
Hyper Lytes
Touring windscreen.
OEM crash bars.
Any issues taking off the headlight support?  The rear is straight forward but the front looks to be a bit more involved.
Thanks for any info!
Kris D.
2020 v85tt
Offline Trialsman
Re: v85 tt mods
« Reply #138 on: October 25, 2020, 06:49:54 PM »
No issues taking off the headlight support for powder coating.  When reinstalling you need to align the bracket perpendicular to the frame.  I found a lot of the misalignment came from here.  The holes are larger than the bolts so you can torque it one way or another to get the bracket just right.  While you are there do the bars, loosening then re- tightening the bolts under the top triple clamp and at the clamps to the bars.  A thousand miles or so since I adjusted everything and it is still straight.  Used to drive me nuts.
2010 FE570 Husaberg
2024 Stelvio V100
Offline jacksonracingcomau
Re: v85 tt mods
« Reply #139 on: October 25, 2020, 09:28:00 PM »
No, I saw it in Mandello last year, pics were self explanatory, I thought
The cat is the silencer, all he did was remove the nominal silencer (muffler)
Little chrome tip from auto or HD world, his only expense
Wins in the Guzzi content and amazing how quiet it was, fixed the saddlebag issue totally
Re: v85 tt mods
« Reply #140 on: February 05, 2021, 05:38:53 PM »
Bump for Pescatore.
Offline oggridley
Re: v85 tt mods
« Reply #141 on: February 21, 2021, 07:27:22 PM »
Hello Guzzistas,
I just bought bought my first Guzzi ( 2020 V85TT)and am thrilled.  Winter has allowed me some time to do some farkeling.  My question is where are the fog light leads located, so I may hook up fog lights to those connectors.  Also does anyone know what those connectors are called/size so I can order what I need to hook up to them properly?
Offline Kiwi Dave
    • Guzzi Gander Ltd
Re: v85 tt mods
« Reply #142 on: February 21, 2021, 08:01:33 PM »
Wiring diagram (https://www.thisoldtractor.com/moto_guzzi_small_blocks_wiring_diagrams_-very_large_and_easy_to_read-.html) shows the fog lights (where fitted) amongst the headlight and front flashers, so I think you can assume the connections will be in the headlight shell.
The diagram also shows a headlight relay (#61 on the diagram) which I assume will also go in the headlight shell.  I've never bothered with fog lights, so can't help any further.
Offline j.davis
Re: v85 tt mods
« Reply #143 on: February 22, 2021, 03:16:42 AM »
This might help from another V85tt page.
GIVI Fog Light Mount Kit LS8203
https://www.af1racing.com/Givi-Fog-Light-Mount-Kit-LS8203
STEDI MCX10 MOTORCYLE LED LIGHT DRIVING BEAM
https://www.stedi.com.au/mcx-10-motorcyle-led-light-driving-beam.html
Quad Logic ATV Adjustable 3/4" - 1" Rack or Handlebar Clamp Mount
https://www.amazon.com/dp/B01N7DTTJP/ref=cm_sw_r_cp_api_glc_fabc_wBxZFb9DHP1RN?_encoding=UTF8&psc=1
AUX Light Wiring harness by Gregory Bender Part number: V85TT-AUX-LIGHTS
https://www.thisoldtractor.com/for_sale_wiring_harness_small_blocks_V85TT-AUX-LIGHTS.html
Works with factory switch gear. Relay is under the tank next to evap canister. I actually prefer this location and it made the install a relatively cleaner one vs the relay and harness buried behind the headlight.
Still had to lift the tank enough to get the side panel off and fish the connector through but only had to remove the windshield and hang the headlight to connect the wires and zip ties.
Offline egschade
Re: v85 tt mods
« Reply #144 on: February 22, 2021, 05:46:18 PM »
Bought a set of these driving lights to put on my engine guards. Main attractions were the wattage and clamp system. https://www.amazon.com/SUPAREE-Auxiliary-Driving-Protect-Motorcycle/dp/B072L2SQMV/ref=sr_1_21?dchild=1&keywords=40w+motorcycle+driving+lights&qid=1614067419&s=automotive&sr=1-21[/url
Not sure if I'll tie them in to the harness though as that would limit their use to high-beam only. Thinking I want them on all the time to be more conspicuous (aimed correctly of course to avoid blinding oncoming drivers). Kinda interesting which bike they used in the advertisement...
« Last Edit: February 23, 2021, 02:13:44 AM by egschade »
The elder Eric in NJ
2016 V7 Stornello #394
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Offline j.davis
Re: v85 tt mods
« Reply #145 on: February 23, 2021, 04:37:07 AM »
I fitted my lights with a Skene controller to allow the spots to run as DRL's.
Re: v85 tt mods
« Reply #146 on: November 05, 2021, 06:25:33 PM »
Bump
Offline Willeand
Re: v85 tt mods
« Reply #147 on: January 01, 2022, 10:42:08 AM »
As for other mods;
Heated grips
Heated seat
KTM turn signals.
KTM sumo mirrors
Renthal bars.
Hyper Lytes
Touring windscreen.
OEM crash bars.
@ Trialsman
what Voltmeter did you buy and where did you put the indicator. I am looking for ideas.
Also the oil temperature would be of interest. Albeit the V85TT has an oil temperature sensor I am tempted to use one at the drain plug instead (not to mess with the Guzzi on board electronics).
cheers
Andreas
Offline Bisbonian
  • Living the Dream
Re: v85 tt mods
« Reply #148 on: January 01, 2022, 02:58:54 PM »
@ Trialsman
cheers
Andreas
I've bought the LED kits that show basic voltage state on a number of different bikes, and I'll probably get one for the V85 as well. It's simple, so you can tell relative voltage state at a glance, and it is tiny so it can mount in a variety of places. I'm considering the blank panel on the opposite side from the dash of the USB port.
http://www.sparkbright.co.uk/sparkright-eclipse-battery-voltage-monitor.php
Offline Trialsman
Re: v85 tt mods
« Reply #149 on: January 01, 2022, 04:25:00 PM »
Here you go Andreas;
BlueFire Upgraded Aluminum Alloy Quick Charge 3.0 USB Car Charger Socket & 2.4A USB Port IP66 Waterproof Dual USB Power Outlet with Voltmeter for Car Boat Marine Rv Motorcycle(Silver-Green)
Another mod I made was to the brake pedal.  I kept dragging the rear brake as my toe would hit the pedal tip.  The brake pedal  takes a dramatic bend and places it squarely in line of my boot.  I cut the pedal and re-TIGged it so that it now is about parallel to the frame but without the offset.  It is tucked in about an inch and a half.  I have never dragged it since and have always been easily able to find it when needed.
I also never warmed up to the matte finish on the Centenario so I sprayed gloss over it and added some green to the tank.  It looks so much better now.
2010 FE570 Husaberg
2024 Stelvio V100
