Author Topic: 850 engine power output?  (Read 7394 times)
Offline n3303j
  • Ron Cichowski
« on: November 06, 2019, 08:46:55 PM »
I've got a '76 T3 and it's rated at 68 HP
I've looked at the V9 Bobber and it's rated at 55 HP.
Same displacement.
40 years more modern.
Where did the horsepower go?
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline Kev m
Re: 850 engine power output?
« Reply #1 on: November 06, 2019, 08:50:19 PM »
Same displacement.
1. SAE standards for hp rating was different.
2. The T3 was so far from meeting today's emissions standards it might as well be a chain saw.
Offline Gliderjohn
« Reply #2 on: November 06, 2019, 09:16:35 PM »
From n3303j:
Guzzi was wildly optimistic with that claim. I have a 75 T-3 with a modified motor. Mods are as follows:
1,000cc kit
36mm carbs
Port and polished heads opened to match the carbs
Heavy duty valve springs
V-7 Sport cam
K&N cone filters
Former professional mechanic that has ridden it says: "Runs like a stripped ass ape."
Here is the dyno run:
Back in central KS
Offline 1down5up
« Reply #3 on: November 06, 2019, 09:33:50 PM »
From n3303j:Guzzi was wildly optimistic with that claim. I have a 75 T-3 with a modified motor. Mods are as follows:
1,000cc kit
36mm carbs
V-7 Sport cam
K&N cone filters
Interesting, I wonder how much more you would expect with LeMans Heads & Pistons - prob another 8-10HP or so?
Thats a nasty drop at 3,000rpm, any feedback on whats causing that?
Offline Gliderjohn
« Reply #4 on: November 06, 2019, 09:56:50 PM »
From 1downSup:
For what ever reason that was an intentional throttle chop according to the dyno operator. Should of asked why. Power is very even through the entire range.
Back in central KS
Offline Perazzimx14
« Reply #5 on: November 07, 2019, 04:04:36 AM »
I never really understood this. The 850 round fins I had always got 55+ MPG whereas the fuel injected catallactic converter wearing DL650 got 42 MPG.
If a motor uses more fuel  to go the same distance does that not create more harmful combustion emission gasses?
Offline Kev m
« Reply #6 on: November 07, 2019, 06:13:11 AM »
Unfortunately unintended consequences of dumb emissions standards are that they don't actually spec efficiency and they only test for emissions at certain odd points in the power band. So a bike can be inefficient as you want/as polluting as you want at other points. It just has to be choked enough where they test it and that can adversely effect the whole power band.
I will say it seems to have worked out for Guzzi smallblocks, especially the Hemi head ones. They are as efficient as @##$_&$#@.
Rough Edge racing
« Reply #7 on: November 07, 2019, 06:17:41 AM »
 Newer engines with three way catalytic convertors require the air fuel mixture  to be held very close to  stoichiometric, approx 14.5  during part throttle to meet emission standards....Older non emissions engines at part throttle can run as lean as 16-1  at part throttle cruising...yes, uses more fuel but less harmful emissions in some cases..
Offline n3303j
  • Ron Cichowski
« Reply #8 on: November 07, 2019, 06:27:51 AM »
I want to know how you are getting 55 mpg out of the 850. I'm averaging 44 one up with plexifairing 3 and 200# rider & camp gear at legal speeds. Runs great, 100K miles, no oil consumption.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline huub
« Reply #9 on: November 07, 2019, 07:51:41 AM »
a stock 850 T3 will produce in the region of 45-46 hp at the back wheel.
a typical V7sport is lucky to hit the 50 HP mark.
not sure how that translates to the SAE hp figure,
the difference in 40 years?
the bobber might actually make the claimed Hp , the 850 t3 power output was a marketing statement.
Online PeteS
« Reply #10 on: November 07, 2019, 08:22:08 AM »
My 850 Lemans runs pretty strong with its Raceo Heads but I seem to average 42-44 mpg. My friend had a really built LmIII. Bored and stroked to near 1100ccs, Raeco heads, cam (??), 40mm Delortos. He could actually pull Japanese liter sport bikes 50-100 mph. He would consistently get 52-55 mpg. We would be riding together, stop for gas. I would put in 5 gallons and he would only use 4. Go figure.
He was a real perfectionist when it came to jetting.
« Last Edit: November 07, 2019, 08:24:14 AM by PeteS »
« Reply #11 on: November 07, 2019, 08:31:19 AM »
My V700 and all of the Ambassadors I've had have averaged in the 50-52 mpg range, only the Convert has dropped below that to around 43 mpg average.
Offline Roebling3
« Reply #12 on: November 07, 2019, 08:41:59 AM »
I followed Amadeo Castellani's work when he moved to UK, but haven't seen Manfred Hecht's name since the early 90's.  Anybody? (LMI, LM1000).  R3~
Online PeteS
« Reply #13 on: November 07, 2019, 08:47:11 AM »
Manfred passed away quite a few years ago now, 10 at least. Chain smoker.
Offline acogoff
« Reply #14 on: November 07, 2019, 08:49:26 AM »
     As this is drifting into an 850 round head mileage thread, my T3 with stock jetting and restrictive stock mufflers and a plexistarII always gets 47 mpg driving 60-65 mph.
Marshall County Minnesota USA
« Reply #15 on: November 07, 2019, 08:53:51 AM »
Same displacement.
The 1976 bike had 68 bhp: "Brochure Horsepower".
Offline Tusayan
« Reply #16 on: November 07, 2019, 08:56:23 AM »
FWIW January 5th, 2011 according to the NY Times Obit.
Offline Two Checks
« Reply #17 on: November 07, 2019, 10:32:35 AM »
The figure Guzzi claims is probably taken at the crank and not at the back wheel.
As for jetting, what is stock? I've seen em all over the place.
1987 1000 SPII "Il Duce' II"
Offline wicks
'77 LM1 / '93 1000s / '73 V7 Sport / '06 Ducati Paul Smart  / '73 Porsche 911s / '94 Porsche 964 Turbo / '94 Defender 90
Offline Gliderjohn
« Reply #19 on: November 07, 2019, 10:41:35 AM »
From Two Checks:
I would question that as if the motor put out 68hp at the crank it would be showing something in the mid-50s at the wheel instead mid 40s.
Back in central KS
Offline moto-uno
« Reply #20 on: November 07, 2019, 12:12:29 PM »
I'm the owner of a Le Mans 2 , factory rated at 80 horsepower . Years later , I'd installed a 990 cc kit with 10.5 to 1 pistons,
40mm Dellortos , Megacycle cam (Norris SS grind copy) , Bub 40mm header pipes and megaphone exhaust and twin plugged
the heads and lightened flywheel . 4 hours of dyno time at the shop I worked at and I finally got 70.4 rear wheel horsepower !
They must have been using Shetland ponies for horses  :grin: . But it still gets 18 kilometers per liter .  Peter
Offline Two Checks
« Reply #21 on: November 07, 2019, 04:43:01 PM »
Quote from: gliderjohn on Today at 10:41:35 AM
From Two Checks:I would question that as if the motor put out 68hp at the crank it would be showing something in the mid-50s at the wheel instead mid 40s.
Wrong quote. 1down5up asked that.
But ya did answer my statement about hp at the crank vs at the wheel.
Its all good.
Offline Gliderjohn
« Reply #22 on: November 07, 2019, 04:49:30 PM »
My bad. Was even sober.
Back in central KS
Online Turin
« Reply #23 on: November 07, 2019, 07:05:44 PM »
I got similar results to Glider John.
850T with new gilardoni barrels (849cc)
36mm carbs
Megacycle X-9 ( norriss s ) cam
ported heads
compression ratio increased with copper head and base gaskets (10.5:1?)
stock heavy flywheel.
It runs great and is a hoot to ride.
I cant figure where Guzzi got their #s, Crankshaft HP is still optimistic.
« Last Edit: November 07, 2019, 07:19:19 PM by Turin »
1985 Sidlow Guzzi
Offline Gliderjohn
« Reply #24 on: November 07, 2019, 07:45:40 PM »
From Turin:
Back in central KS
Offline Tusayan
« Reply #25 on: November 07, 2019, 09:20:42 PM »
I vaguely remember a magazine dyno test of a new early-80s round barrel 1000 SP showing 48 RWHP. With big carbs, porting and a different cam you’d reasonably get 8 HP more from a 949 cc modified 850 engine, as per the tests above.
Move ahead 35 years and you get still another 10 HP with a small block V85TT that (I’m led to believe) benefits from computerized valve train analysis to produce 68 RWHP from an 850 with quiet mufflers and single throttle body.  That’s still amazing to me. Awesome  :thumb:
« Last Edit: November 07, 2019, 09:25:18 PM by Tusayan »
Online bad Chad
« Reply #26 on: November 07, 2019, 09:27:25 PM »
Just looked at my small block Guzzi Work Shop manual for the original small blocks.  Max output of v65=52hp.
My seat of the pants says no way, no how!  Rear wheel hp, my guess somewhere in the mid 30s.
Offline moto-uno
« Reply #27 on: November 07, 2019, 11:21:19 PM »
This is from the last dyno runs I made on my Le Mans 2 literally decades ago ! Still runs great , Peter
« Last Edit: November 07, 2019, 11:23:03 PM by moto-uno »
Offline earemike
  • Lurker
« Reply #28 on: November 08, 2019, 02:34:40 AM »
The bobber is a small block heron head?
Seems the horsepower sounds right, I’d guess a good T3 would be close
You could probably guess which way I lean  :grin:
850 T3
850 LeMans
SP1000 Stucchi
V11 Ballabio
Offline n3303j
  • Ron Cichowski
« Reply #29 on: November 08, 2019, 05:05:30 AM »
It's not a heron head.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
