Author Topic: 850 engine power output?  (Read 7663 times)
Re: 850 engine power output?
« Reply #30 on: November 08, 2019, 05:58:34 AM »
It's not a heron head.
What N3 said... ∆∆∆
The Bobber was introduced with the new Hemi head smallblock. In both 850 and 750 versions the new smallblock punches above it's weight class when compared to the old Heron head motors.
« Last Edit: November 09, 2019, 10:56:43 AM by Kev m »
Rough Edge racing
« Reply #31 on: November 08, 2019, 06:24:17 AM »
 I'm surprised at the what I consider low output from modified 850's...This is my 650 Triumph ,the one that holds several speed records but it's not radical, starts on one kick and idles at 900 rpm..More or less a Bonneville with 10.5 compression, larger carbs, slightly hotter cams and a head porting done by Rob Hall from HCV Motorsports in N.C. I'm just a hobbyist engine builder but some effort was spend on piston quench . Look at the flat power curve ,it's making 45 RWHP at 5000 rpm, 55 at 7000.There are more dyno runs than shown here testing intake length and so on...Vintage Triumphs have a no so good head designed in the 1930's..I believe there's more Hp to be had from a Guzzi without making the engine a pain in the ass for street riding. I believe Rob Hall may be of help...
Offline acguzzi
« Reply #32 on: November 08, 2019, 02:15:39 PM »
my 850 LM with a B10 cam and 40mm carbs dynos at 63hp rear wheel
Offline wirespokes
« Reply #33 on: November 08, 2019, 04:50:20 PM »
From what I've heard, actual HP figures from dynos shouldn't be taken as gospel, only comparison. Compare the graphs to earlier runs on the same machine, preferably on the same day to determine if changes improved power output.
Rough Edge racing
« Reply #34 on: November 08, 2019, 05:13:48 PM »
Correct, but this thread is about bragging rights  :wink:
Offline wirespokes
« Reply #35 on: November 08, 2019, 11:15:17 PM »
Oops. Sorry about that.  :embarrassed:
Offline earemike
  • Lurker
« Reply #36 on: November 09, 2019, 08:11:46 AM »
Thank you, I need to keep up with y’all. I think small block, I think heron head 😭
850 T3
850 LeMans
SP1000 Stucchi
V11 Ballabio
Offline Turin
« Reply #37 on: November 09, 2019, 11:10:17 AM »
I think the same thing. I hear Smalltalk and an image of a v50 pops into my head.
1985 Sidlow Guzzi
