Author Topic: Starter Relays Blowing, why? Cali 1100 '95 carb  (Read 4253 times)
Re: Starter Relays Blowing, why? Cali 1100 '95 carb
« Reply #30 on: February 08, 2020, 11:04:35 AM »
Are you saying the battery is about 12V with the starter button pressed?
If so, it is not a starter magnet.
Offline wirespokes
« Reply #31 on: February 08, 2020, 02:53:08 PM »
What Wayne said, but I think you meant that the volt meter is that far off from actual voltage at the battery terminals.
If the starter is locked up, the battery voltage will drop way down when pressing the starter button. So it's not a good load test to determine if the battery is good.
Offline izzug otom
« Reply #32 on: February 09, 2020, 12:57:09 AM »
It's all sorted. It turned out to be a loose connection in the positive feed to the ignition switch.
I have 2 good batteries, a good starter motor and no blown relays  :wink:
Fired up in an instant too! Love my old Cali !!  :thumb:
Thanks for the input guys  :bow:
Wayne mate, what is the thing about using a jump start, when the battery is good in the first place? I don't get it, and I'm a wee bit puzzled by the notion? ..... Cheers, Mart
« Last Edit: February 09, 2020, 12:59:07 AM by izzug otom »
