Author Topic: Place your bets..  (Read 18381 times)
Offline Groover
    • Scooteropolis
Re: Place your bets..
« Reply #120 on: February 11, 2020, 08:22:36 AM »
Everything in this thread has been helpful. Thanks for also including the time estimate, of course that will vary, but if I were to do this I'd know to multiply that times 3 for me  :boozing:
« Last Edit: February 11, 2020, 08:23:05 AM by Groover »
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #121 on: February 11, 2020, 08:29:57 AM »
I'm probably too late, but...
Before you complete assembly, make sure the clutch releases. Hook up the cable, grab the driveshaft coupler with Vise-Grip and use that to turn the output shaft. Pull in the lever and make sure the clutch is releasing completely. If it isn't, I slip one of the thrust washers from the old throw-out bearing in behind the new throw-out bearing. That 1 mm is usually all that's necessary.
It sucks to get it all back together and then find that the clutch doesn't release or drags.
« Reply #122 on: February 11, 2020, 10:14:03 AM »
Thanks, Charlie. Yeah, too late, but easy enough to fix once it's assembled. Didn't get a chance to work on it.. honeydoos.  :smiley: I'm wearing my microwave repairman hat as we speak.
Online Gliderjohn
« Reply #123 on: February 11, 2020, 11:38:19 AM »
From Chuck:
Good luck. A couple weeks ago I ordered a new battery for my wife's I-Book. The battery came with a four piece screwdriver set that was suppose to cover all fasteners. Well guess what, not the battery hold down fasteners which were very tiny tri-wing. Never encountered them before so had to then order the proper screwdriver. A few days later got it done.
East Mountains, NM
« Reply #124 on: February 11, 2020, 12:05:34 PM »
And the winner.. drum roll please..
Wirespokes!
My bet is on the Surflex.
was the first.  :smiley: That's *assuming* it all works after I get it back together..
Online fotoguzzi
« Reply #125 on: February 11, 2020, 12:56:24 PM »
I've seen that tri wing, pretty stupid when they could have used a regular Phillips or even the same head as the rest of the screws.
« Reply #126 on: February 11, 2020, 08:54:46 PM »
They use tri-wings on exterior panels of KC10’s,  miserable steenking screws alright!
Offline wirespokes
« Reply #127 on: February 12, 2020, 08:30:59 AM »
Wirespokes!was the first.  :smiley: That's *assuming* it all works after I get it back together..
Thanks, Chuck.
When I replaced the Sureflex in the T3, I started up the engine and couldn't get the clutch to release. I tried to figure out what I'd done wrong, but thankfully didn't pull it all back apart. It wasn't an adjustment thing, what could it be? Took a while, but finally decided to just try it out. Started it up in gear and took off. Once rolling it was good, and by the time I got back from a 30 mile ride it worked fine.
« Reply #128 on: February 12, 2020, 09:30:40 AM »
Thanks, Chuck.
Thanks for the heads up. I'll not be testing anything for a while with 5 inches of snow predicted today.  :smiley:
« Reply #129 on: February 24, 2020, 02:44:28 PM »
This right here is where I'm at and wanted to know how the dbl rubber puck worked out for lever throw.  I used same stuff as Chuck, like new rod & throw out. Lever is right there almost on cover. Puck is in a bit.  Got all stuff coming newer longer dbl rubber puck and extra bearing set. I also found my bag of bearings, just in case.
Plates are a bit thicker and will wear in so I want something I can remove next year maybe.
Just wondering how Chucks worked out, he used same kit from MG?
« Reply #130 on: February 24, 2020, 02:56:27 PM »
Hi, Steve.. I haven't ridden it, but it seems to be ok rolling it around in the hanger. Today, the fog lifted enough to actually *see* the rain coming down.  :grin: I'm also waiting for the unobtainium G5 gas cap from Mark.
« Reply #131 on: February 24, 2020, 03:52:41 PM »
Thanks ,  I used to use a bearing behind the rod on Barnett clutch plates, they were a bit thicker. We've gotten 17" of rain, still raining every day but 2 a week. Better than snow though.
