Author Topic: how do I remove the hub from my cast lemans rims?  (Read 3051 times)
Offline amamet
« on: February 24, 2020, 03:18:16 PM »
I need to remove the rear hub so I can have my rims powder coated.  c-clip is out, bearings are out.  I don't have a press.  tried heating and tapping out with block of wood.  obviously no luck, didnt want to hit it too hard. more heat?  needs a press?
thx
allen
oh, also, it has a raised x patern going around it.  is that normal for an original hub?  I can post a photo of it later
Re: how do I remove the hub from my cast lemans rims?
« Reply #1 on: February 24, 2020, 03:30:32 PM »
thx
allen
This is what, take a die grinder & cut a slot, soak & beat the crap out of it. The   X   is grooves for grease, no lube, it's rusted as 1.
New inner hubs are $200 and no one has one, not a stocking item. Got mine from MG and waited. I just did 2 of them.
« Last Edit: February 24, 2020, 03:34:35 PM by guzzisteve »
Offline amamet
« Reply #2 on: February 24, 2020, 03:33:53 PM »
I don't want to destroy it, id like to reuse it.  is it a bad idea to reuse?
« Reply #3 on: February 24, 2020, 03:43:31 PM »
I would not bother removing it. Any powdercoater worth a crap will be able to mask it to protect it.
« Last Edit: February 24, 2020, 03:59:38 PM by Antietam Classic Cycle »
Offline amamet
« Reply #4 on: February 24, 2020, 03:54:27 PM »
thx Charlie,  will do
« Reply #5 on: February 24, 2020, 07:08:38 PM »
I would leave it as already posted and only remove it if being replaced with a new one (US$290/AU$399)
I can not say for a cast wheel but on my Eldorado the original worn splined insert was so tight I stripped the wheel (again) so the wheel hub could go in the oven then pressed it out.
I would guess the powder coat baking temperature would have little effect on the interference fit.
It's different for the cush drive wheels, and an even tighter fit.
« Reply #6 on: February 24, 2020, 09:04:05 PM »
If you don't service it, it bonds.  Real pia, both of mine would not hold bearings. They wouldn't come apart either not being serviced since new.
If you don't have to, I wouldn't  just like Charlie says.  You don't notice if it moves or not in cush.
Offline Roebling3
« Reply #7 on: February 25, 2020, 10:29:50 AM »
Like Charlie and others; +1 No hub removal required. I've had several cast wheels powder coated. Most recent were Stone wheels off a new V7. Do not reuse the original bearings! They are no doubt flat spotted from being tapped out/extracted.  R3~
Offline bigbikerrick
« Reply #8 on: February 25, 2020, 12:03:39 PM »
Is that something we can spray penetrating oil into during tire changes to keep it from becoming "frozen" like that? Or would that have no beneficial effect in this application?
Rick.
« Reply #9 on: February 25, 2020, 12:14:57 PM »
Rick.
The central "bearing carrier" isn't meant to move in the wheel, the cush drive plate that slides onto it is though.
The cush drive plate can be fairly easily removed and the interface between the two parts greased.
Online Groover
    • Scooteropolis
« Reply #10 on: February 25, 2020, 02:14:26 PM »
Is it the rubber wedges grabbing it and holding it? I remember removing mine somehow, and it was pretty difficult. I wanted to see inside, which I did, but not sure it was worth the effort  :azn:
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #11 on: February 25, 2020, 02:50:50 PM »
I get it, Charlie. Its not the cush drive , sliding surfaces we are referring to. After your explanation and looking at the parts diagram I can tell where the issue is.
Rick.
« Reply #12 on: February 25, 2020, 03:47:55 PM »
The piece that amamet was asking about is #14 in this illustration:
which looks like this:
Offline Rolf Halvorsen
« Reply #13 on: February 25, 2020, 04:29:25 PM »
Ok - this is simple. Just remove No: 28 (locking ring) and press out No: 14 after you have applied heat from an air gun for a while. You need a big hydraulic press to perform this job. This way you will get the steel disc 25 out. Then you can press in again part 14.
Been there myself and done that.
Rolf
Offline Motorad64
« Reply #14 on: February 28, 2020, 01:49:51 PM »
Per Charlie’s advice I just cleaned mine up, removed all corrosion, but my sleeve was in pretty good shape.  Used heat and kroil on the Cush/sleeve then tapped the brake disk bolts til i worked it off.
I liked how Canuck zinc-plated the Cush plate—May keep it from rusting right.  I’m just going to regrease annually.
Offline Motorad64
« Reply #15 on: February 28, 2020, 01:54:28 PM »
Whoops. Meant to show the sleeve before n after...
