Author Topic: NGC. Question for you welders  (Read 4685 times)
Re: NGC. Question for you welders
« Reply #30 on: February 29, 2020, 10:25:38 AM »
Hey  Chuck,
What size tip are you using to weld .020 to .035" tube?  I have a 000 that I am planning to use on an old gas tank.  Not sure of thickness.  I was considering getting one of the mini torches, but without a trial, not sure if I would ever use it.
That depends on what kind of torch you have.  :smiley: Manufacturers number their tips differently. (shrug) I have an antique (naturally)  :smiley: why are all my tools antiques? Purox aircraft torch. The most commonly used tips are 4 and 6 for thin wall tubing up to about 1/16".  I did a brief search to get a cross reference with no luck. I'll look a little harder tonight.
I'm back. I haven't found a chart yet, but the #4 Purox is equivalent to the Victor #1 from a little reading. The important part is the orifice diameter, which is .040".
« Last Edit: February 29, 2020, 10:50:50 AM by Chuck in Indiana »
Online cliffrod
« Reply #31 on: February 29, 2020, 10:50:51 AM »
My torch is a Harris model 85, from the tiny kit I bought off CL, it is like new, 3 tips #1,3&5 plus a cutting torch.
 I have a great guy at a local welding shop only a mile from home. He already exchanged my acetylene tank, cost was $30... I actually have 2 oxy and 2 acetylene tiny tanks so can be prepared for them to run out.
if I do find other tanks to buy I can run it past him to be sure they can be exchanged.. just watching daily for a killer deal, will focus on the 40cfm like you advise.
I don't have flash back arresters, do I need them?
It's best and smart to have them.   Same with at least one fire extinguisher and a back-up hose or container of water right there- not across the yard.  Cheaper than losing your shop/house.  Things go wrong fast.  Sounds like you're in good shape with tanks right now.  Very cool.
Not trying to overwhelm you- it's easy to succeed, fail and collect gear & info for 20 yrs and then say "get this instead of that." to the next guy.  Pre Internet, I didn't have succinct good advice getting started.  Gas welding aluminum and such was voodoo.  Nearly everyone said get a TIG or a cheap MIG with aluminum spool gun and forget about gas welding.  My only goal is to help others waste less money and time than I have.  It doesn't matter who laughs at me.  Unkes it's thick metal, I hardly ever use my TIG or stick.  Gas welding is my go-to method.
Use what you have, Practice a lot (& then practice more) and plan towards better gear to purchase once IF you need it.  If you already have a Harris torch, your tips may fit one of those craftsman gas-saver type handles with thumbwheel on-off.  Do some internet searching.  If you're not cutting a lot and welding small/thin, a Meco midget is the way to go imho because it isn't likely to be phased out soon. I added a couple of link above.  Kent White is a renowned expert and significant resource for serious gas welding.
Practice of proper method is the most significant part of being a good welder. No book or video will practice for you.  If you're good, you're good even if the gear is less than optimal.  People gas weld thin aluminum with a plain cutting torch, usually just to show it can be done.
