If the timing chain went south, a'la Luap's bike, at speed, could that have caused this issue?
You'd think the valves would stay closed when the chain lost tension, unless the chain was stuck when the valves were open.
Very impressive for Piaggio to take such quick action and to ship a whole new motor. No idea why the valve dropped but none the less, congratulations to the dealer and to Piaggio.
What really has me going HMMMMM, is the fact that the engine has a mechanical failure and the operator is thinking dead battery? Like what was all that rattling and crunching going on just before the silence? DonG
You may be lucky enough for that to happen, but remember that the valves on one cylinder are only closed in unison while the piston is coming up on compression and on the power stroke.Even then, the opposite cylinder will be at a different phase.You’ll never have all valves closed at the same time.
Well, it wasn't electrical, thats all I can say.
Well it could be...I once stopped to hep an old guy who’s car had broken down on the side of the road..It was after dark and the relic was sitting there in a pool of black oil in pitch darkness, (the car, not the bloke..)When I asked if there was something I could do to help, he relied..“Oh I think I’ve got an electrical problem..”“Jeez, says I”, (looking at the tsunami of 7 year old crude running out from underneath...)” What leads you to that thought..”“Well..” (says the old timer ruefully stroking his beard and staring at the carnage..)“Looks like she’s thrown a con rod and it’s come out through the side..”“How’s that electrical then..”)“Well (opines the old timer), it’s knocked the generator clean off it’s off it’s mountings..” Well alllrrigghhhttyyy then.....
Can remeber if his name was Allan grince or Win Percy per chance?
If you read the original post you would see how I was doing about 70 miles an hour. And I also had a battery problem in the previous weeks. All I can say is at 70 miles an hour with cars around you I wasn't paying a whole lot of attention to valves dropping, as it continued to run on one cylinder and thinking what the @#* is going on!
Thank you for posting the images that show the engine damage to your low mileage MGX. If they determine what caused this problem, please let us know with an update.
Well it's time for a update. I got my MGX back on the 25th of April. New motor from Guzzi, I have put about 675 miles on her so far and am very happy with how everything is running. (I was 14 months ago also) I have been told that the motor will be going to the Guzzi training center in CA for evaluation as to what happened. The dealership seems to think it was a broken two-piece valve. I will be staying in contact with the dealership for any more information. Now it's time for a set of tires, oil change and a summer of riding!!
Glad you got it worked out and motor swap went so quickly. Quick question, I think that you said the dealer reported the lower plugs were damaged on both sides? Did it drop a valve on one side or both? To the Guzzistas, which other models use a 2 piece valve stem? That's nukin futs............
Keep us posted on what you find out about the valve problem. It would be good to know if I am still riding a time bomb. Did they have a problem with valves and if so did they upgade? I may need to invest in a backup. I need a good excuse to put a V7 in the garage. kk
I think that dealer did a good job for you. They quickly identified the problem (6 hours after drop off) without the bike standing around for weeks and got the ok for a new motor. You were back on the road pretty quick in my opinion. Considering you were worried about their lack of experience I think they did you proud. Maybe you'd like to mention the dealer in case others are reasonably close?
I definitely will keep everyone posted. Honestly I don't think it's a known problem, actually I think it's a fluke. Only 1 other one that I have heard of, and it wasn't seen by the guy, just told "it dropped a valve"
