Author Topic: Help me understand Pre-load  (Read 25441 times)
Offline zedXmick
Re: Help me understand Pre-load
« Reply #90 on: March 14, 2020, 10:15:20 AM »
So in this example you have both sets of shocks set to a perfect sag of 150mm now you want to change your ride height. One set of shocks you have to “compromise” your perfect sag to “fake change your seat height“ The other set of shocks you are still at your perfect sag height and now you truly change your ride height by changing the length adjuster.
2010 VFR1200F  DCT
Offline bad Chad
« Reply #91 on: March 14, 2020, 10:17:49 AM »
Thanks Huzo and company.   I pretty much get it now.  If I don’t over think it, it’s fairly easy to comprehend!
Offline zedXmick
« Reply #92 on: March 14, 2020, 10:32:48 AM »
 :thumb:  :thumb:
2010 VFR1200F  DCT
« Reply #93 on: March 14, 2020, 03:23:43 PM »
What I find incredible, is how I have read so many articles over the years where some scribe says..
“I wound on some pre load and that firmed up the arse end...”
You could have an arse end like Serena Williams (firm), and winding on pre load’ll do nothing.
They think it was firmer because the seat didn’t drop as far when they jumped on..( the bike , not Serena...)
An idealised example, lets start with a 9” one...(wouldn’t THAT be nice.. :evil: :drool:)
A. Zero pre load +. 200 lbs load = 4” of spring compression to stabilise to a compressed length of 5”.
B. 1” of pre load + 200 lbs load = 3” of spring compression to stabilise  to a compressed length of 5”.
C. 2” of pre load +200 lbs load  = 2”  of spring compression to stabilise to a compressed length of 5”.
And so on until you could wind on enough pre load so the spring compressed 1/4” when you dragged your carcass aboard and you’d convince yourself that the suspension was as hard as a bull’s arse but not so..
The ride height has changed but..THE COMPRESSED LENGTH OF THE SPRING IS ULTIMATELY THE SAME.
In all examples, the spring “winds up” ( :grin:) arriving at the same compressed length, but y’all will have thought examples “B” & “C” were firmer settings, ‘cos it didn’t drop as far when you clambered aboard.
Once the damper has come off the top stop (ie not topped out), the pre load you applied becomes irrelevant to the spring performance as an isolated system..
Moreover.
If the shock had no damper rod and the spring was free to expand or contract with no mechanical limitations, it can be seen more easily, that winding on pre load has zero effect on firmness...(just picture that for some time..)
So it therefore can be accepted that if the damper stays off the stops...? (No topping or bottoming out..)
The preloading has no effect other than ride height... :popcorn:
Hope that helps..
« Last Edit: March 14, 2020, 03:52:45 PM by Huzo »
Offline Kiwi Dave
    • Guzzi Gander Ltd
« Reply #94 on: March 14, 2020, 03:51:41 PM »
For a linear spring, yes, agreed.
« Reply #95 on: March 14, 2020, 04:05:43 PM »
I’ll need educating on that..
Offline 80CX100
« Reply #96 on: March 14, 2020, 05:12:37 PM »
I'm almost afraid to jump back into this,  :evil: because as I read your post, I said to myself, finally "clarity" but as I thought about it a bit more, not so much.  :undecided:
ie. I'm pushing my CalVin, the refined couch that it is, hard around a bumpy corner with your setting "A" and it seems to wallow as I use up the 4" of available spring compression before I hit the firmer 5" compressed spring.
Repeat the same thing but with your setting "C" but now I only have to use up 2" of available spring compression before I feel that secure stable firm feeling of the 5" compressed spring.
The bike to me on your setting "C" feels like it is tracking and responding much more securely and decisively, much firmer ride and much less wallowing.
Am I dreaming? I don't think so, ime setting "A" can feel unsettling, vs setting "C" feels much more stable and secure.
Seems to me, that a little bit more than just ride height is being accomplished.
fwiw ymmv
Kelly
« Last Edit: March 14, 2020, 08:29:16 PM by 80CX100 »
2008 California Vintage
2003 V11 Lemans
1979 G5 & 1980 Lemans CX100
« Reply #97 on: March 14, 2020, 05:48:47 PM »
I mean this in all sincerity, not to be sarcastic and I’m not hiding a swipe..
I cannot explain what my point is any other way without repeating myself.
However, there is one point of which I may make mention. The example “A” with no preload present, compared to “C” with max. preload does contain one potential difference in reality.
The “A” example allows for larger stroke on the shock/s due to the fact that it won’t “top out” as readily. This of course means that there will be more pitching motion and that will amplify any geometric changes to your bike in the dynamic environment that you describe.
That however is no more than an educated guess that I would not readily hang my hat on... :popcorn:
Offline 80CX100
« Reply #98 on: March 14, 2020, 06:27:51 PM »
^^^^^^That makes sense, especially with cheaper older shocks with loose bushings/seals etc  :thumb:  :bow:
fwiw I had a bargain lined up on a new set of Ikons, because Wolfgang out in British Columbia is getting out of the biz,(will still service Ikon but no new sales once stock is gone) but he didn't have my model  :cry:
Tks for your insight and patience
Kelly
« Last Edit: March 14, 2020, 08:31:46 PM by 80CX100 »
2003 V11 Lemans
Offline Tusayan
« Reply #99 on: March 14, 2020, 06:42:00 PM »
@Huzo, you have this figured out fine.  The only thing that may be missing is that with the static sag reduced by higher preload, and the shock (s) now being thereby longer when carrying a given rider, rear suspension linkage geometry may be different at the static sag position and the effective suspension rate at the wheel slightly changed by that geometry change.
« Reply #100 on: March 14, 2020, 09:39:07 PM »
Things that make ya’ go
Hmmmm...
Offline Kiwi Dave
    • Guzzi Gander Ltd
« Reply #101 on: March 14, 2020, 09:42:56 PM »
Take a look at a bike with a non-linear spring.  The stock V85 rear spring is such an example.
You will observe that the coils are wound tighter (less space between windings) than those at the bottom.   As the spring compresses, the top windings will close together, and therefore unable to compress any further.  This in effect creates a spring of shorter length, which has a higher compression rate.  Then it requires greater force to compress this spring further.
There's probably other forces not considered in my simple explanation, but that's how I understand it.
« Reply #102 on: March 14, 2020, 09:51:18 PM »
Look that’s fine.
Also the tighter wind gives a less vertical aspect to the wire, which increases the bending moment yada yada...
What I REALLY wanna’ know is, how will pre load affect this arrangement ?
I’m developing my understanding
« Last Edit: March 15, 2020, 06:05:27 AM by Huzo »
Offline 93spada
« Reply #103 on: March 15, 2020, 08:44:27 AM »
Just because I am still a little confused and not sure who is correct on ride height...….
How about some pics with measurements to prove you theory???
PJM
Offline Kiwi Dave
    • Guzzi Gander Ltd
« Reply #104 on: March 15, 2020, 03:00:31 PM »
Them's the other forces I'm talking about, but insignificant IMHO.  Nothing's perfect.
Offline Tusayan
« Reply #105 on: March 15, 2020, 03:55:34 PM »
Look that’s fine.
The effect of progressive spring rates is unaffected by preload, because as long as the shock moves any amount off the limits of its travel when the bike is loaded, the spring is no more or less compressed when preload is changed.
Offline Kiwi Dave
    • Guzzi Gander Ltd
« Reply #106 on: March 15, 2020, 04:25:15 PM »
Agreed.  That is, until the closer wound coils reach the end of their travel (hopefully not all at once).  Then the spring becomes effectively shorter, and therefore provides a greater resistance to further movement.
« Reply #107 on: March 15, 2020, 07:41:39 PM »
Yes Dave, but by then the shock has moved off it’s stops and the pre load has become irrelevant.
Offline Kiwi Dave
    • Guzzi Gander Ltd
« Reply #108 on: March 15, 2020, 09:17:34 PM »
You would not want a situation where the shock has not moved off it's stops with the rider on board.  If this situation exists, then there is too much preload wound 1n.
« Reply #109 on: March 16, 2020, 07:07:55 AM »
Well I guess so Dave, but no one suggested otherwise.
Online Chuck in Indiana
« Reply #110 on: March 16, 2020, 08:32:09 AM »
Four pages on preload? It must still be winter.. :evil: :smiley:
« Reply #111 on: March 16, 2020, 09:53:00 AM »
What really matters is what oil you use in the shocks. Dino or synthetic?
 :violent1:
And a couple of pages devoted to if preload changes the ride height.  :boozing:
Offline bad Chad
« Reply #112 on: March 16, 2020, 11:00:16 AM »
I have to toot my own horn, I’ve started a lot of far too long threads over the years!
« Reply #113 on: March 16, 2020, 11:31:54 AM »
If 20 guys were chosen at random from the membership, I’m given to wonder what % would be able to explain definitively what pre load is and a few of the basic facts surrounding it... :popcorn:
« Reply #114 on: June 09, 2026, 05:35:24 PM »
Bumped for Guzziboy66
Online SIR REAL ED
  • uh.... it's personal....
« Reply #115 on: June 09, 2026, 06:30:37 PM »
I'm going to say 15.475% with a tolerance of +80%/- 12.5%.
Throw in the effects of improper engine oil selection on achieving the correct shock preload and you can cut that number in half.....
2019 Beta EVO 250
Offline DenverSteve
« Reply #116 on: June 09, 2026, 11:29:42 PM »
  (I know you Guzzi guys won't spend for a new bike and only buy used).
Pretty closed minded and incorrect assumption.  You're on a Moto Guzzi forum so does that make you a "Guzzi guys"?  I'm a long-term "Guzzi Guy" and I only buy new.
Steve
2023 MG V85TT Adventure
Offline MikeP996
« Reply #117 on: June 10, 2026, 12:47:59 AM »
I never have been able to figure out/understand preload/spring rates BUT after reading this thread today I can confidently state that I still can't...  :violent1:
« Last Edit: June 10, 2026, 03:41:55 AM by MikeP996 »
2021 Moto Guzzi V7 850 Special (UK)
1976 Honda CB400F (UK)
2017 BMW R1200RS (TX)
'73 Norton Commando (Mexico
2015 BMW R9T (Mexico)
(Wife's bikes:
2015 Ducati Diavel (TX)
2019 Honda Africa Twin  (Mexico)
2021 Honda NC750  (UK)
« Reply #118 on: June 10, 2026, 03:46:31 AM »
I never have been able to figure out/understand preload/spring rates BUT after reading this thread today I can confidently state that I still can't... ;)
Work on each one separately.
Preload…
Preload and spring load are not cumulative. Once the spring receives the load that it is asked to carry and it comes off the top stop, whatever preload it had becomes irrelevant.
If your weight compresses the spring to 150 mm from 250 mm (unladen no preload), you sank 100 mm.
If you preload the spring to 200 mm and jump on, you’ll still sink to 150 mm but you’ll have sunk only 50 mm.
See how the spring ends up the same length in both cases ?
Don’t resort to analogies to try to understand the principle, just dwell on the example.
Rate.
A spring is just a steel rod that is being bent, you know it is harder to bend that rod 100 mm than 50 mm.
The “spring rate” is simply how much force to need to deflect the rod a given amount.
Say… 100 lb per inch.
Now if to look at your coil spring, imagine it to be lots and lots of short little bars end to end. The total length of the wire in the coil might be 50 inches and the coil compresses 5 inches under 100 lb of load.
That’s 0.1 inches of bend on each one inch segment.
That is the spring rate.
« Reply #119 on: June 10, 2026, 05:49:45 AM »
I missed this thread the first time through and I think I know why from the dates. I was in Ireland and the world was crashing around me as I received reports that toilet paper had disappeared (along with most food) from US stores and the pubs were all about to close.
So I finally read it last night and this morning and think it taught me how to understand preload.
But that stiffness thing seems so counterintuitive. Maybe because of the simple impression (sitting on the bike with the preload set at different points). Or maybe it's just semantics but I want to pose a question.
If I understand you correctly you're saying preload doesn't stiffen the ride in terms of how the shock reacts to a bump because the spring rate being what it is doesn't change on a linear spring just because it's starting point was set to carry more weight and that damping occurs according to the valving at the same rate once the shock starts to move.
Do I have that correct?
IF I DO, then may I ask, what happens when the preload is incorrectly set too high, topping out the shock, and causing the force pushing down on the swingarm (pushing up against the frame) to require more force than the rider to start to move? Does that not increase how much force is felt from hitting a bump? Does that not change the way the frame reacts to said bump? And if so, would that not be a stiffer rear end?
What am I missing?
« Last Edit: June 10, 2026, 05:52:25 AM by Kev m »
