Author Topic: Wonky LM3 headlight  (Read 1020 times)
Online wirespokes
Wonky LM3 headlight
« on: March 14, 2020, 11:27:51 AM »
What's the story on the LM3 headlight? Is it a similar situation like the LM1 - the European version outlawed in the US, so a goofy workaround presented instead?
I recently got a LM3 and thought the PO replaced the headlight with something cheaply available. But the more I looked into replacements, found they were the exact same thing. Instead of being a European style halogen light, it's a common generic sealed beam that's the wrong size for the fairing opening and looks goofy as hell. So, of course, I want to make it right.
Am I on the right track? None of the photos in my searches show what I'm talking about - it's like they're all from the promo (which maybe didn't want to show such a goofball thing - it isn't flattering, after all)  or don't show the light at all.
I've found that the Europeans had the right light and the mounting brackets are a little different. I'm wondering if I can convert my brackets to accept the proper headlight? Anyone been there?
Along that same topic, this bike could really use some swan neck adjustable height bars like the V7S. A possibility would be to mock up the headlight ears like the LM4 with clamps and then weld longer 'risers' to the stock clip-ons. That way they could be low or a more comfortable higher position.
Re: Wonky LM3 headlight
« Reply #1 on: March 14, 2020, 12:11:22 PM »
The headlight you describe is correct for a US delivery Le Mans III. It's already "right" as-is.  :wink:
Stein-Dinse sells the European headlight. IIRC, it's also used on a Fiat 127(?) as well.
https://www.stein-dinse.biz/product_info.php?products_id=2847
However, it doesn't seem to come with the adjuster ring it mounts to and I don't even see a number that here.
Edit: Fiat 127 headlight (the cutoff might be for the "wrong" side of the road, best to check).
https://www.ebay.co.uk/itm/Light-Light-Front-Bilateral-Fiat-126-127-Melchioni/174203666616
Mounting/adjuster ring:
https://www.ebay.co.uk/itm/Fiat-127-Fiat-128-Fiat-900-Pulmino-headlight-bracket-light-support-left-right/223676663578
« Last Edit: March 14, 2020, 12:19:05 PM by Antietam Classic Cycle »
Online wirespokes
« Reply #2 on: March 14, 2020, 01:36:29 PM »
Thanks Charlie for confirming my suspicions.  :thumb:
It looks like converting to the 'proper' light requires replacing the headlight mounting ears, mounting ring and headlight. My headlight ears are shorter than the euro version, so won't work.
I'll have to search for the fiat light - anywhere but England.
« Reply #3 on: March 14, 2020, 02:16:40 PM »
The rubber piece around the sealed beam is unobtainium.  If you find one used, BUY IT.  They are hard to find.
Online wirespokes
« Reply #4 on: March 14, 2020, 07:45:18 PM »
Isn't there a workaround? I'll bet there's something that could be substituted.
