Author Topic: Finishing aluminum castings?  (Read 2969 times)
Offline SED
« on: March 15, 2020, 11:38:07 AM »
The 80 year old sand cast aluminum crankcase on the bacon slicer grabs dirt like a magnet.  It seems to have surface porosity that holds an oil film.
I've heard that bead blasting peens the surface closing pores and that the surface stays cleaner after.  Any experience with this?
Are there other techniques?  (I've been told "tumbling" has a similar effect, but can't find any that do a very small number of parts locally.)
BTW don't want polished cases - the original surface should be preserved as much as possible.
Thanks!
Shawn
1983 LeMans III
1981 Monza
1947 Ariel Red Hunter
1939 Ariel Red Hunter
1937 Guzzi GTV
Re: Finishing aluminum castings?
« Reply #1 on: March 15, 2020, 11:42:15 AM »
Bead blasting done correctly (high volume, low pressure) will leave a surface that's smooth and easy to keep clean. Same with vapor blasting. Vapor blasting seems to leave a more shiny surface than HVLP bead blasting though.
« Last Edit: March 15, 2020, 12:40:48 PM by Antietam Classic Cycle »
Offline SED
« Reply #2 on: March 15, 2020, 12:02:14 PM »
Bead blasting down correctly (high volume, low pressure) will leave a surface that's smooth and easy to keep clean. Same with vapor blasting. Vapor blasting seems to leave a more shiny surface than HVLP bead blasting though.
Great info.  Thanks Charlie!
1983 LeMans III
1981 Monza
1937 Guzzi GTV
Offline cliffrod
« Reply #3 on: March 15, 2020, 12:23:59 PM »
In a recent thread on another forum, a trusted acquaintance discussed use of zinc shot (approx $5/lb) to blast certain things like aluminum intakes.  It weighs less than steel shot (like I keep here for occasional stone use) so it can be used in a typical suction rig or cabinet for reuse.   It would likely peen a surface better than glass bead without being as aggressive as steel shot on something soft like aluminum.   I haven't tried it yet but probably will.
This is an old factory aluminum Ford intake after he blasted it with zinc shot-
Offline SED
« Reply #4 on: March 15, 2020, 01:53:14 PM »
Thanks Cliff.  Something to ask about.
1983 LeMans III
1981 Monza
1937 Guzzi GTV
Offline injundave
« Reply #5 on: March 15, 2020, 02:00:38 PM »
I have had success in the past using Pledge furniture polish. Spray it liberally on the castings then go for a ride (20 minutes or so). The wax in the polish gets into the pores of the alloy and dirt can be wiped off. Repeat as often as needed.
1975 850 T3
2019 V85TT
« Reply #6 on: March 15, 2020, 02:03:48 PM »
Vapor blasting will hone the surface smooth and close some of the porosity, once cleaned a liberal coat of ACF-50 will prevent corrosion and make clean up very easy. My 72 Eldo was cleaned and treated to ACF-50 over 5 years ago and grime just rinsed off. I think you will be very pleased with Vapor blasting, you can control the sheen by limiting the blast time.
« Last Edit: March 15, 2020, 02:04:11 PM by Canuck750 »
Offline SED
« Reply #7 on: March 15, 2020, 02:10:09 PM »
Thanks Guys!  Sounds like the pledge and ACF-50 may act similarly.  Have to try the ACF-50.
1983 LeMans III
1981 Monza
1937 Guzzi GTV
Offline SED
« Reply #8 on: March 16, 2020, 07:59:26 PM »
Charlie, I may get the opportunity to blast my own castings.  Do you know the approx. pressure used in HVLP bead blasting?
1983 LeMans III
1981 Monza
1937 Guzzi GTV
Offline harry h
« Reply #9 on: March 16, 2020, 08:39:05 PM »
I just got a vapor honing cabinet and LOVE IT!.  As Jim/canuck750 says, you can control the amount of shine.  Here is a manifold I did, the other one wasn't touched.  Started out pretty rough.  Used #13 glass bead.
« Last Edit: March 16, 2020, 10:04:37 PM by Harry H »
1972 Eldorado
2016 Eldorado
Offline SED
« Reply #10 on: March 16, 2020, 08:59:11 PM »
I just got a vapor honing cabinet and LOVE IT!.  As Charlie says, you can control the amount of shine.  Here is a manifold I did, the other one wasn't touched.  Started out pretty rough.  Used #13 glass bead.
That looks great.  What vapor honing setup do you have?
1983 LeMans III
1981 Monza
1937 Guzzi GTV
Offline harry h
« Reply #11 on: March 16, 2020, 09:49:51 PM »
Vapor Honing Technologies VH3630, I added a closed loop system.
1972 Eldorado
2016 Eldorado
Offline Ryan
« Reply #12 on: March 16, 2020, 09:53:11 PM »
If the goal is to stop the seep without altering the look, can't you blast the inside? It won't make it easier to wipe off, but could slow or stop the oil from making its way to the surface.
« Reply #13 on: March 16, 2020, 09:54:34 PM »
15 psi. It takes a cabinet purpose made for it and large compressors with lots of volume. The shop that does it for me has two huge compressors in tandem to deliver enough volume.
Actually, that was Jim/canuck750.
A friend bought this vapor blasting setup and it does a great job, but is limited in what size parts you can do.
http://vaporhoningtechnologies.com/micro-vapor-hone/
Offline SED
« Reply #14 on: March 16, 2020, 10:20:56 PM »
That is a direct pressure set-up rather than siphon?
1983 LeMans III
1981 Monza
1937 Guzzi GTV
Offline John Ulrich
« Reply #15 on: March 17, 2020, 12:28:28 AM »
After cleaning.  Sodium Silicate brushed on the block, washed off then baked in the oven will provide a protective barrier in the pores against oil staining.
Eagan, MN & Scottsdale, AZ
MN MGNOC Rep  L#800
Offline Frenchfrog
« Reply #16 on: March 17, 2020, 04:45:50 AM »
Interesting John...I use Sodium Silicate for waterproofing masonry and rendering...it's got unusual properties and not well know.
« Reply #17 on: March 17, 2020, 08:54:50 AM »
Yes, it's a pressure system.
Offline SED
« Reply #18 on: March 17, 2020, 10:27:14 AM »
John, Interesting.  What flavor of sodium silicate?  And where do you get it?  There are several chemical versions for cleaning decks, sealing concrete, painting prep...  Some reportedly have impurities that could discolor the aluminum.
Thanks,
Shawn
1983 LeMans III
1981 Monza
1937 Guzzi GTV
« Reply #19 on: March 17, 2020, 10:56:37 AM »
I *think* this was the product recommended to me by Charley Cole:
https://www.aircraftspruce.com/pages/me/metalprep/alodine1001.php
Offline John Ulrich
« Reply #20 on: March 17, 2020, 06:00:14 PM »
Thanks,
Shawn
I purchased mine at a science store that sold chemicals.  I googled the name and found multiple sources in various sizes from 4 oz. to gallons.  The stuff I used was in liquid form.  No idea what "version."  I see a clear version is listed.
MN MGNOC Rep  L#800
Offline SED
« Reply #21 on: March 17, 2020, 10:57:16 PM »
Thank you John and Charlie!  I'll let you know how it goes.
1983 LeMans III
1981 Monza
1937 Guzzi GTV
Offline Frenchfrog
« Reply #22 on: March 18, 2020, 05:55:17 AM »
Over here Sodium Silicate is available at DIY stores....it seems to come in various thicknesses...In English it is also known as water glass , some times it is really runny, other times rather gloopy but always clear here.
