Author Topic: Replacement of a ABS brake accumulator  (Read 652 times)
« on: March 24, 2020, 07:46:25 PM »
Anyone replace one on a car?  How did you bleed the brakes?  Did you use a pressure brake bleeder?
Offline guzzimaster
Re: Replacement of a ABS brake accumulator
« Reply #1 on: March 24, 2020, 07:54:04 PM »
I have to replace the rear brake line from peddle to ABS box.  :popcorn: I will be watching your thread in hopes of learning how to bleed the rear brakes also.
MotorOverTimeObedie ntly GasUpZigzagZoomInde finetly
'74 California "Santana" / 2020 V85tt "Liberty / 2014 California Custom "Black Pony"
Offline Steve Scott
  • Ride, Fettle, Repeat
« Reply #2 on: March 25, 2020, 12:24:33 PM »
What kind of system? The Teves systems used in GM, Jaguar, SAAB etc don't require bleeding at all. just pump down the 2000 psi accumulator, unthread the old one, thread-in the new one, clean up the mess, allow the system to pressurize back up.
'79 Morini 500S
'00 'Guzzi Jackal
'67 Teisco ET-440
Spring Grove, PA USA
« Reply #3 on: March 26, 2020, 04:10:49 PM »
Mercedes Benz.  The pressure accumulator has caution sticker on it saying under high pressure.  When you bleed the brakes, you have to reset the ecu with an OBD2 scanner and pressure bleeder.
