Author Topic: Quick swing arm centering question  (Read 2003 times)
Offline wicks
« on: March 27, 2020, 04:10:31 PM »
I'm installing my swing arm after putting in a new u-joint and boot (and fresh spline slime and fresh greased bearings, new seals, trans output seal, fresh clutch rod seals, etc), and I'm doing the technique I've read about here (thanks!), but an option is occurring to me. The swing arm/drive shaft should be centered on the trans output, not on the frame. Those two, in an ideal world, are the same. But...
So when I have the swing arm at rest and then gradually tighten the pins evenly on both sides, increasing to a light, even torque, they are almost at identical depth. So I think it's very close to perfect, but it occurred to me that an enhanced way to do this might be to install the rear wheel and then have a friend (with a mask on) spin the rear wheel constantly as the pins are evenly torqued on both sides. This way the axle is in rotation and so it more likely to be exactly on it's center, making the swingarm get into an ideal position for running with the joint and axle straight.
The swing arm should lifted a bit so the tire is off the ground but the swing arm is at running angle (no springs installed) while doing above.
Does it make sense? What am I missing...
« Last Edit: March 27, 2020, 04:27:41 PM by wicks »
'77 LM1 / '93 1000s / '73 V7 Sport / '06 Ducati Paul Smart  / '73 Porsche 911s / '94 Porsche 964 Turbo / '94 Defender 90
Re: Quick swing arm centering question
« Reply #1 on: March 27, 2020, 04:41:23 PM »
The bike?
Offline mtiberio
    • TiberioRacing
« Reply #2 on: March 27, 2020, 04:42:18 PM »
You are over thinking this. Guzzis are rare in the motorcycle driveshaft world in that they have a "dual" u-joint or a homo-kinetic u-joint or to put it yet another way, they have a constant velocity u-joint. Back in the day (it might be different now) there was only one yamaha that had this besides guzzi. What this means is that the u-joint will tolerate some side to side offset. Now you do want to minimize this and measuring the large set screws is only a first order solution. There may be better ways to do this, I don't know one. When I raced, I had a 4" rim and I used to run 140 tires on early narrow swingarms. I had to offset the rear wheel .4" or 10mm to the left for the tire to clear my notched swingarm. They only way I got any sembelence of handling back was to run the swingarm offset to the right as much as the set screws allowed. I never had a u-joint failure on my race bike. I also used to run tall rear shocks and would have to grind on the u-joint body to clear the u-joint chamber at full shock extension.
« Last Edit: March 27, 2020, 04:43:44 PM by mtiberio »
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
LesP
« Reply #3 on: March 27, 2020, 04:54:43 PM »
Machine checker.
Set swing arm level and adjust pins until the coupling slides smoothly on output spline indicating on centre/center.
Check swing arm bearing pin height with Mitutoyo depth micrometer.
Scratch head when two heights turn out to be with thousands of each other.
Conclusion, not all you read on the internet is BS.
Offline wicks
« Reply #4 on: March 27, 2020, 05:34:01 PM »
ooooh that's a cool tool!
It's my 77 LM1
« Last Edit: March 27, 2020, 05:34:31 PM by wicks »
« Reply #5 on: March 27, 2020, 05:40:37 PM »
Offline delrod
« Reply #6 on: March 27, 2020, 06:58:38 PM »
Just for the sake of conversation. In my experience in another power transmission application. Many diesel firepump applications use a short conventional u joint driveshaft. Most of the setup charts avoid or caution against dead true alignment. Not always but most setup check lists in this application. I'm not an engineer but just a dumb sprinkler fitter. None of my setups have experienced driveline failures. My vote goes for close is good enough YMMV
Doug in Pittsburg KS
2003EVT
Offline wicks
« Reply #7 on: March 27, 2020, 09:49:08 PM »
HAH thanks all. I tried both methods and the position was the same. So she's all bolted back together now and ready to ride.  :boozing:
Offline SmithSwede
  • I don't want a pickle
« Reply #8 on: March 27, 2020, 09:55:14 PM »
Hmmm.  That is very interesting.    Anyone have an explanation for why such charts would warn against a dead true alignment?
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
« Reply #9 on: March 27, 2020, 10:53:44 PM »
Possibility of harmonics of some description? :undecided:
LesP
« Reply #10 on: March 27, 2020, 11:35:26 PM »
If not mistaken they are talking about drive shafts (same as Automotive) with universals not a compact unit as per a Moto Guzzi.
Offline wirespokes
« Reply #11 on: March 27, 2020, 11:53:13 PM »
The dead alignment has to do with the U-Joint being directly in line with its driven shaft. The U-Joint needs to 'work' - input and output should be at angles to each other.
Offline nc43bsa
« Reply #12 on: March 28, 2020, 12:03:33 AM »
No!!
No one ever does that on this beeb.   :evil:
1990 MilleGT
LesP
« Reply #13 on: March 28, 2020, 12:22:40 AM »
There will be folk running to the shed to wind one pin in another 2 turns, the other 2 turns out.
Offline wirespokes
« Reply #14 on: March 28, 2020, 10:26:46 AM »
With airheads (lots of experience there) I've always used an allen wrench to judge spacing between frame and swingarm. Get about the same wiggle one side to the other = good to go. Never even thought about stresses side to side on the shaft. Never a problem I can recall - never a U-Joint issue.
But now, next time, I'll have attention on it and take a look. Like others have said, it's not an issue so I'm definitely not concerned.
Offline wicks
« Reply #15 on: March 28, 2020, 12:48:02 PM »
This *could* be a method to temporarily "fix" a worn u-joint or loose carrier bearing! Hmmmmmmm haha
Offline Denis
« Reply #16 on: March 29, 2020, 10:04:37 AM »
No!!
Haha!
Offline Denis
« Reply #17 on: March 29, 2020, 10:47:43 AM »
When I align mine I thread in the pins until they bottom out and eyeball them to get them as even as possible.
Then I slowly back them out until the swing arm moves freely up and down. Then I adjust the pins left to right in small increments until they are even.
It's not difficult.
Offline pehayes
« Reply #18 on: March 29, 2020, 04:21:53 PM »
Many years ago in my early days with Guzzi I restored a crashed 73 Eldorado.  Someone advised me to lace up a 5.10 X 16 rim to the rear hub.  Bigger tire = more weight carry capacity.  Doing so, the fatter tire hits the driveshaft tube.  So, you have to adjust the spoke lacing so the hub is substantially "out of dish" in order to make the tire fit the swingarm.  Requires cutting and modifying the drum rear brake anchor rod.  Also requires the swingarm pivot pins to be substantially mis-matched (by about a cm! differential) in order to get the center of the rear tire to track the center of the front tire.  I drove it 100,000 miles that way  before I converted back to a standard rear wheel/tire and equally centered swingarm pins.  The odd adjustments never seemed to bother the u-joint.  BTW, handled a LOT better with the stock, narrower rear wheel/tire.
