Author Topic: V7 III vs V7II  (Read 9395 times)
Re: V7 III vs V7II
« Reply #30 on: April 12, 2020, 08:07:09 PM »
The bobber sport looks good just the way it is.
You're not wrong.
But it could be even better!
Offline SIR REAL ED
  • uh.... it's personal....
Re: V7 III vs V7II
« Reply #31 on: April 12, 2020, 08:58:13 PM »
That's what I would do if I were looking now.
Silver tank one looks better, but probably due to shortened fork.
I agree with Kev, but would add shocks that are 2" longer than stock.
2002 MZ Skorpion
1994 DR Skorpion
Offline SIR REAL ED
Re: V7 III vs V7II
« Reply #32 on: April 12, 2020, 09:00:39 PM »
Ok, I haven't converted these km/h to mph yet, but here are done notes I have on our bikes:
MKI V7 Stone:
Rpm vs speed in 5th
55  3500
60  3800
65  4100
70  4400
75  4700
80  4900
80 mph is about 5000 rpm on my 2007 Nevada.  Not sure what MK # it is.
2002 MZ Skorpion
1994 DR Skorpion
Re: V7 III vs V7II
« Reply #33 on: April 12, 2020, 09:20:23 PM »
Ha ha, probably 0.5 or maybe -1, not sure either.
The MKI moniker grew out of a need to quickly describe the first generation of the 1tb model V7s from the V7II and V7III. Before that there were various generations of the V7c/Breva750/Nevada 750 but all were 2TB models and though very similar, a little different.
Offline mobiker
Re: V7 III vs V7II
« Reply #34 on: April 12, 2020, 09:34:09 PM »
The tank swap interests me as well.  Is it a straight bolt on?  Does the seat need to be swapped for a V7 seat?
I would like to know this also. I seem to remember reading somewhere that it took some fabrication, but can't find it now.
Mike
'88 BMW R100GS
Offline chrisfer
Re: V7 III vs V7II
« Reply #35 on: April 13, 2020, 01:53:48 AM »
Tank installation is not a problem.
But you need a V7 saddle that matches the footprint of the tank.
A V7 saddle requires a modification for its rear attachment.
2022 V7 850 Stone - 2019 V7 III Carbon - 2004 V11 RossoCorsa - 2002 V11 Le Mans - 1995 750 Nevada
Offline greer
Re: V7 III vs V7II
« Reply #36 on: April 13, 2020, 05:52:30 AM »
Here's Crashcraddock's thread:
https://wildguzzi.com/forum/index.php?topic=102756.0
Do we have any idea of the year range for a V7 tank?  2013 on up?  Can you keep the pump and lines from the V9?
Sarah
Offline egschade
Re: V7 III vs V7II
« Reply #37 on: April 13, 2020, 06:52:35 AM »
Sarah
I'm considering the reverse - putting a Bobber/Roamer tank on a V7 III to give it more of a tracker look. As Sarah asked, the tank internals the same? If so you could do the tank swap in minutes and could go back and forth if you wanted to swap range for looks.
The elder Eric in NJ
2016 V7 Stornello #394
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Offline mobiker
Re: V7 III vs V7II
« Reply #38 on: April 13, 2020, 03:51:32 PM »
Sarah
Thanks  :thumb:
Mike
'88 BMW R100GS
Offline MMRanch
  • MMRanch
Re: V7 III vs V7II
« Reply #39 on: April 14, 2020, 09:50:49 AM »
I've got two V7 seats I'd like to sell , they both are factory seats , one is gel , other reg.   PM me if interested .
« Last Edit: April 14, 2020, 10:03:49 PM by MMRanch »
2016 V7-II Stone
Online DaSwami
Re: V7 III vs V7II
« Reply #40 on: April 15, 2020, 05:58:44 AM »
PM sent!
Offline Crashcraddock
Re: V7 III vs V7II
« Reply #41 on: April 15, 2020, 10:27:45 PM »
Sarah
I just had a quick check of AF1's parts lists for the pumps and they have different no's.  My recollection is they are different.  I don't have the v9 tank with me to check.
As far as tanks go any will work.  You could try and locate a really early and likely very cheap 17l tank with pump, but the early v7 small tanks used a different pump to the later 21l tanks.  Ideally you'd try and get a steel 21l tank with pump.
Ebay can be your friend of course, although sometimes TLM and AF1 have reasonable priced stuff.  I think I paid about aud800 for both, although I bought them seperately.  The tank was new and the pump 2nd hand from AF1.
I don't know if it's the case worldwide but the V9's are going a bit cheaper than similar year V7's in OZ.  There's a couple of dealers with lightly used (1000km) 2016 demo's for 11k.  So for an extra 1200 you would have a v9 special, which is cheaper than what 2016 v7's are going for.  :thumb:
Daniel
2016 V9 Racer
1980 GSX1100 (never ending project)
1984 Gpz550
Offline greer
Re: V7 III vs V7II
« Reply #42 on: April 16, 2020, 04:58:22 AM »
Thank you, Daniel!!
Sarah
Re: V7 III vs V7II
« Reply #43 on: April 16, 2020, 06:52:29 AM »
Off the top of my head my swag would be different base plates to fit the tanks.
