Author Topic: '17 V7 III Wheel Wobble  (Read 8342 times)
Offline Murray
Re: '17 V7 III Wheel Wobble
« Reply #30 on: April 16, 2020, 12:04:22 AM »
3 year old bike from that probablly gets washed regularly from a factory famously allergic to grease, I'd say the steering head bearings probablly have a notch in them. With the front wheel off the ground the bars should smoothly move from one side to the other no "clicks" or tight spots especailly on dead centre (normally where the appear).
« Reply #31 on: April 16, 2020, 02:40:11 AM »
As a matter of interest, what size wheel is on the V7lll, 17" or 18"?
Offline Two Checks
« Reply #32 on: April 16, 2020, 05:07:07 AM »
The handlebars should not flop freely to either side, either.
I had a bike that did it after the first front tire change. I was told it was loose bearings. Silly me, I said it had to be the new tire and I did the on centerstand check of the head bearings. All checked ok...then I snugged the bearings. Problem solved.
1987 1000 SPII "Il Duce' II"
Offline sib
« Reply #33 on: April 16, 2020, 07:54:13 AM »
It seems to me that slightly over-tightening the head bearings works because it adds some friction to the steering.  Wouldn't installing a steering damper be a better way to solve the wobble problem?
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Offline Two Checks
« Reply #34 on: April 16, 2020, 08:49:05 AM »
It will only mask the real problem if at all.
EDIT:that is if you are referring to a hydraulic type or the friction type between the frame and forks.
« Last Edit: April 16, 2020, 08:51:04 AM by Two Checks »
Offline Murray
« Reply #35 on: April 16, 2020, 09:25:00 AM »
Or make it worse.
Offline Guzzi Gal
    • Sonoran Sunriders, YouTube
« Reply #36 on: April 16, 2020, 12:40:30 PM »
3-year-old bike from that probably gets washed regularly from a factory famously allergic to grease...
Anni has never had a bath because she never gets dirty beyond a bit of bug here and there.  Our Lady of the Garage is willing to sit still for a polish but is quite aquaphobic, which is fitting for a desert deity.  :bow:
18" front
17" rear
"Velvet" '16 Honda CTX 700,
"Miri" and Mori"
Offline Zoom Zoom
« Reply #37 on: April 16, 2020, 12:50:15 PM »
Before you begin tearing into the bike, consider it could simply be the tire itself. I have experienced that on a tire that was no where close to worn out. Perhaps not first on the list when you consider cost, but if the steering head bearings are not loose, this may be your next consideration.
John Henry
« Reply #38 on: April 16, 2020, 12:56:27 PM »
Thanks for all your suggestions! :bow:
If after removing the top-case the problem persists, I will check the spokes (watched https://www.youtube.com/watch?v=9eOKzknv-TE ) and bearings (watched https://www.youtube.com/watch?v=zQJhcfdsWTk among others).  Additionally, I've always checked tires cold.  I also find running the front pressure a few pounds lower negatively impacts my ability to steer.  They only have about 1600 easy miles on them so, in theory, they should be excellent condition.
Any ideas on how to lift the front end safely without a lift, jack or center stand? :gotpics:
Call Fay and ask if Richard can check them for you.  He also wouldn't mind tutoring you.  He's retired.  :thumb: :grin:
Offline Guzzi Gal
« Reply #39 on: April 16, 2020, 01:02:37 PM »
I may do just that if it becomes a problem.  Of course, only after the world returns to semi-normal. :azn:
"Miri" and Mori"
Offline Two Checks
« Reply #40 on: April 16, 2020, 01:22:40 PM »
Quote from: Zoom Zoom on Today at 12:50:15 PM
John Henry
One problem...something caused the tire to wear like that. When the new tire wears the problem will get worse.
« Reply #41 on: April 16, 2020, 03:45:41 PM »
18" front
17" rear
The Breva has a 17" front, marvelous in the tight twisties and although stable in a straight line it can feel a bit "uncertain' in sweepers above 85mph if there are any irregularities.  I can take my hands off the bars and it feels fine.
Having said that, my bike was one where Luigi lost his grease pail, and I did put some grease in the steering head bearings and tightened the head.  This did make quite a difference.
