Bigga hamma and KY jelly, unscented.
Doesn't that shrink stuff?
Ruglide makes all the difference.Ditch the pam, dish soap, etc.I bought the smallest container of Ruglide at NAPA, my great grandchildren's grand kids will have some. kjf
3. Have a decent platform on which to work. All the ones mentioned are good. I use the base from a broken (they all break) Harbor Fright changer, it rotates and it's just the right height.
You ain't changed a tire by hand til you've done a semi truck split rim tire by hand. Breaking a bead with a tire maul is not fun... Giving blood while doing the job is mandatory.Be well,Larry
I always stood way back, with the chuck hooked to the valve, when filling the split rims. I found them really easy to work on compared to non-split rims. Only did a couple but they weren't a problem.
Right you are, actually a great rim design, when in good shape with the right maul, and some lube, not a. bad job at all. Like all things, it depends upon the amount of rust involved. Thank god for Red Lead primer. IIRC, there were no warning labels about drinking paint back them........What ruined it for me, was my Father's idea of fun was having his kids change dump truck tires that are 120% worn out on a regular basis and replace them with tires that are 90% worn out. Replacing summer tires with winter tires and vice versa.I think he invented Wild Guzzi tightwadness even before Dusty and the internet.
I can dig that. Then I was ace #1 tire man in the early’70’s at a long haul semi truck place. Tires are mean ugly bastards but they are not very smart. I learned to try to convince the tire that I was smarter than it was.
When you had a flat at speed you usually laid it down.
Wonder what you have hat broke.I have changed many dozens of tires on my HF stand and nothing broke that I recall.
Yup. My dad told me when I was just learning how to twist wrenches that it's bad policy to let an inanimate object outwit you.Be well,Larry
