Author Topic: Added a 1987 LeMans 1000SE to the Stable  (Read 12544 times)
Offline Cdn850T5NT
  • Cdn850T5NT
Re: Added a 1987 LeMans 1000SE to the Stable
« Reply #30 on: May 07, 2020, 04:16:35 PM »
IIRC the problems with the 16" wheels were not from the size of the front wheel but with the triple trees.   I still have the 16" wheel/tires on the front of my SE.
AFAIK the triple trees are specific to the wheel size; so, for example, fitting an 18 inch frt wheel on a 16"specific triple tree will not give a good result. For the LeMans V Guzzi went to an 18" frt wheel, first with a (presumably) cast ductile or cast steel triple tree (or at least a non light-alloy one, cast or otherwise) - then latterly, later production, cast in light alloy. Can you explain how you figure the 16"specific triple tree is a prb?
1985 Eurospec 850 T5 NT (Nuovo Tipo - New Type... i.e. Series III)
Offline guzziart
« Reply #31 on: May 07, 2020, 05:09:01 PM »
GuzziArt, did you have trouble keeping the amber turn signal lenses on?  It appears you had to use narrow zap-straps on them.  I have a 1985 T5... with (I believe) the same turn signals as your Le Mans 1000 SE.
The PO installed the tyraps on the ts lens to keep them from falling off, sometime in the life of the vehicle the lens tabs got broken.  The lens are a tight enough fit that I was able to take a clear strip of packing tape and run it along the bottom of the lamp housing & lens to secure the lens.  That was 10 years ago, the tape worked great, no more tyraps, no lost lenses....FWIW.
« Reply #32 on: May 07, 2020, 05:20:51 PM »
A lot of the guys didn't like the 16" wheel.  "Weird" handling.  A number of bikes had cracks in the triple trees allowing for flex.  IIRC.  Can't remember if it was a recall or dealer fix.  Maybe Curtis could jump in.
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #33 on: May 07, 2020, 05:25:28 PM »
Thx!
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #34 on: May 07, 2020, 05:26:19 PM »
OK... Thx.
Offline Idontwantapickle
« Reply #35 on: May 07, 2020, 05:32:07 PM »
There was a problem related to geometry on early bikes and IIRC it made them wobble at speed. All early LeMans 1000 were provided with an updated triple tree. I installed a couple. And there was a change for the 18 inch wheel as well. The 16 inch wheel was not an issue except to Japanese bike fanboy "journalists". The bikes are sensitive to tire pressure. I have ridden many and even own one now. It's a fantastic bike! When we received the first of the Lemans 1000 with the 18 I must say it was a disappointment. I think it detracted from the look of the bike but mostly it just slowed the steering. Not the same animal it was. I'm a bit biased on the subject but I think that the 85-86 LeMans 1000 is the best Tonti bike by far. The SE is also great but the gearing makes it chore in town. The later 1000 was a good evolution and I enjoyed it a lot. Just not like the quick, light on it's feet version!
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
« Reply #36 on: May 07, 2020, 05:44:05 PM »
The current  16" front & back on the Eldorado 1400 makes that bike really fun.  I checked my triple trees on my SE and no cracks plus I run higher air pressures in the tires.  I have no problems with it.
I did have problems with the accel pump on one carb pumping 2 times as much gas as the other.  Took a while to figure out that problem.  It was still in the factory setting.  (subject for a different thread)
Offline Groover
    • Scooteropolis
« Reply #37 on: May 07, 2020, 06:35:24 PM »
Hey Groover,
Your SE with corroded fasteners could be one of the "damaged" bikes that came over at that time. There was an entire container of Guzzis that was exposed to moisture during transit. The bikes were sold at a discount. I could have bought all the SE LeMans I wanted for 2500 each in the crate.
But I was a poor Guzzi mechanic!
Hunter
It could be one of those I suppose, but I picked mine up from Larry Klein's / GT Motors estate sale in MI in late 2018. The estate sale had about 60 motorcycles, and because of the circumstances of the dealership closing, a lot of the bikes had some storage/oxidation issues of some sort, some didn't - depending on how/where they had been stored I believe. The plate that came on my bike had an old registration sticker, I don't have it in front of me but I think it was 2012 or 2014 maybe.
« Last Edit: May 07, 2020, 06:41:29 PM by Groover »
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #38 on: May 07, 2020, 08:34:15 PM »
Any idea whether the T5 850 NT received different triple clamps too? Mine is this series 3... with 110/90-16 on a 2.15"wide rim... and a 120/90-18 on a 3.00"wide rear rim. Unlike the 2.5"wide frt LeMans iv frt rim with 120/80 tire... Frame is exactly the same as a LeMans iv. My T5 is of course a Europe only version (the series 3).
Mine was the 44th bike built, built in Nov 1984.
Online wirespokes
« Reply #39 on: May 08, 2020, 01:12:45 AM »
With the early triples that came on the first LM1000 and an 18" wheel, steering is light and easy.
« Reply #40 on: May 08, 2020, 08:27:40 AM »
The T5 has different forks and tree.
72 Eldo
84 BMW R100RS
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #41 on: May 08, 2020, 09:57:27 AM »
Ah yes... I remember now. 38mm forks (versus 40mm). Thx.
Offline Groover
    • Scooteropolis
« Reply #42 on: May 08, 2020, 10:21:33 AM »
Fork spacing is also different. The T5 has 195mm spacing, and the Le Mans has 180mm. Also, the T5 I believe has the 65mm offset like the T3, G5, etc and same offset as the first type triples that came on the Le Mans 1000, then that was changed to 45mm offset as the "fix" and then remained 45mm all the way to the end of the Le Mans 1000 series ('91).
So "technically" the T5 should've had the same wobble issues or any other handling issues claimed as on the first Le Mans 1000 models based on that offset number, but I'm also guessing that other things came into play like riding position, tire sizes, shock heights, etc. Who knows, maybe as mentioned above the only issue with the Le Mans 1000 was as simple as the tire pressure then the rumors got out of hand  :azn:
I've also become a die hard Le Mans 1000 fan in these past few years, and also think it has a very cool distinct lines and stance.
« Last Edit: May 08, 2020, 10:32:33 AM by Groover »
1980 Vespa SI Moped
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #43 on: May 08, 2020, 08:35:21 PM »
Thank you, Groover, for a great, detailed answer!
I attach a graphic for the Series 1 and 2  T5.  Mine is a Series 3, though.  I had thought that this dimension was shown on this graphic... but I see, no....
For the Series iii they put an 18" wheel on the rear, and retained the 16" wheel on the front.  I don't think they changed the offset of the triple clamp.  They DID change the frame...  I believe... only inasmuch as the steering head was now longer (taller) and braced... I think they started doing that bracing for the Cal II... but I don't think the SP II and T5 frame is the same as the frame for the Cal II.
In any case, I believe the forks, triple clamp, frame - are identical between the SP II and the T5.
Finally, I should note that the publication of the day - Motociclismo - noted that the T5 would weave a bit on poor pavement.  They didn't jump up and down about it.... but said the effect was fairly minimal.  So this goes to what you said in your post.
Again, Thanks!
« Last Edit: May 08, 2020, 08:37:41 PM by Cdn850T5NT »
« Reply #44 on: May 08, 2020, 09:13:39 PM »
The bike handles better for me with air pressures near the max, minimizing sidewall flex on the bias-ply tires.
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #45 on: May 08, 2020, 11:55:37 PM »
^^+1
Offline chuck peterson
« Reply #46 on: May 09, 2020, 07:18:24 AM »
Here is a peek at one of mine, it would be in great condition if it weren't some oxidation from storage. The black oxide treated hardware on this bike is very unforgiving. My other one is mostly in boxes and covered by junk in my garage.
HOaRDER! Someone get over there, quick, he might hurt himself...oh okay I'll move this over here, and move this, and ya, you won't need this anymore....want to make you safe ya know..
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline Groover
    • Scooteropolis
« Reply #47 on: May 09, 2020, 10:21:32 AM »
* lol, it has become a challenge in my garage lately. I'm constantly jenga-ing things around, to the point that I wonder if my hobbies are motorcycles and riding them or playing Jenga with motorcycles and scooters in my garage. Being different shapes and sizes adds to the fun, which answers my own question.. I think it's Jenga.  :smiley:
« Last Edit: May 09, 2020, 10:40:17 AM by Groover »
1980 Vespa SI Moped
Offline Listerwa
« Reply #48 on: June 26, 2020, 07:49:13 PM »
Hi all, first time poster alert!
I’ve been searching everywhere trying to work out how many MK4 SE’s were actually produced?
Every article appears to use the same info that “100 were sold in America” but that’s about it.
Does anyone have any information on how many were built?
« Last Edit: June 27, 2020, 06:00:38 AM by Listerwa »
Offline thechief86
« Reply #49 on: June 27, 2020, 08:03:38 AM »
DANG, Andy!
It seemslike every time i see a post from you here or on ADV, you're adding another gorgeous Moto Guzzi to your collection.
I'm more than a little jealous! This new LeMans is no exception. Fantastic looking machine, sir. Congratulations!
« Reply #50 on: June 27, 2020, 03:01:37 PM »
Welcome to WG.. and good luck with that search. I doubt if Mother Goose knows.. :smiley: Guzzi's record keeping has been..uh..suspect.
Offline Turin
« Reply #51 on: June 27, 2020, 04:03:23 PM »
They made 100 SE's for the US Market. The red white paint scheme was available in other markets, but not necessarily with the close ratio 5 speed, or the blacked out drivetrain.
There was one new in crate sold at Mecum, that turned out not to be an SE. ( standard gearbox, I think)
1985 Sidlow Guzzi
« Reply #52 on: June 27, 2020, 04:19:23 PM »
One of them immigrated to Hawaii.  Currently living at the Pacific Moto Guzzi Refuge and Preserve.   :grin:  Recovered from inhalation problems.  After years of therapy, a solution was found for a hidden breathing problem.   :rolleyes: :rolleyes:
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #53 on: June 27, 2020, 05:27:56 PM »
Great catch, Turin. Romanelli was bringing in non-Federalized bikes... The lack of side-reflectors is the giveaway. So it is indeed possible that the Mecum bike (originally imported by Moto 2001 - Francesco Romanelli in LaChine Quebec) does not have close-ratio gears.  It did have a blacked-out engine though.
« Last Edit: June 27, 2020, 05:31:39 PM by Cdn850T5NT »
Offline Bazil
« Reply #54 on: June 27, 2020, 05:42:00 PM »
Interesting comments on the whole 16" / 18" and triple trees alternatives. Mine is an 86 lemans with 16 " wheel, and I do think it doesnt quite have that " running on rails" feel over 140 kph.  I run pressures at 37 to 38 psi, running stock tyre sizes.
 What are you fellow 16 inchers running?
Cheers
Bazil
1986 Lario ( long gone, still missed)
1985 Mark IV Lemans ( Gina)
1991 V40 Targa ( L'il Jeannie)
1962 Royal Enfield Crusader Sports
« Reply #55 on: June 27, 2020, 07:09:52 PM »
I have to go look.
Offline Groover
    • Scooteropolis
« Reply #56 on: June 27, 2020, 11:09:42 PM »
The SE short gear ratio box should have a ZD#### stamp on the left side of the box.
1980 Vespa SI Moped
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #57 on: June 27, 2020, 11:11:39 PM »
Cheers
Bazil
Seems you are running the correct tire pressure, what Others have had success with... like Turin, like Patrick Hayes (Patrick with an SPII).  Folks seem to intimate that NOT having a STRAIGHT central groove down the middle of the tire is NOT a problem.  I think Turin runs a Bridgestone Battleax - which has a squigly groove down the middle... and he says it's great.
Guzzi originally used a Michelin A48 on the 850T5 (with its 16" tire) and a Pirelli on the LeMans IV... both with the straight-as-a-die groove down the centre.  On rain-grooved concrete freeway, those would NOT be good... (and on some metal bridge decks) - but on good pavement maybe those would be worth a try.
Seems to me that you have a 2.5" wide rim, and that the front tire size is 120/80-16.  You could try a Metzeler ME33 Lazer and run at highish pressures?
« Last Edit: June 27, 2020, 11:16:16 PM by Cdn850T5NT »
Offline Listerwa
« Reply #58 on: June 28, 2020, 12:29:22 AM »
So no side reflectors means it’s not a USA release bike? (This one is in Australia)
« Last Edit: June 28, 2020, 12:38:30 AM by Listerwa »
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #59 on: June 28, 2020, 01:37:30 PM »
I should add that it was also said that the REAR tire should have a straight central groove too. If this is true then the pairing with the Laser frt tire (is it the Metzeler ME55??) does not accomplish (or result in) that. I say this 'cuz they comprise a pairing, per Metzeler...
« Last Edit: June 28, 2020, 01:38:19 PM by Cdn850T5NT »
