Author Topic: Bell Crank Cable Source  (Read 1618 times)
« on: May 13, 2020, 07:19:51 AM »
The internal cable #8951@76mm is no longer available from Dellorto.  There is a 73mm cable (8831) or a (11003)  non flexible rod. Anyone have an opinion on which of the two available are OK. The rod would be easier to attach to the slide but I can see how there might be issues with movement.
Re: Bell Crank Cable Source
« Reply #1 on: May 13, 2020, 09:14:31 AM »
« Reply #2 on: May 13, 2020, 09:56:37 AM »
I guess you've checked with Eurocarb?
https://www.dellorto.co.uk/shop/dellorto-motorcycle-carburettors-parts/carburettor-parts/phf-parts/phf-internal-cable-76mm-long/
It would be possible to have one made.
I looked at their website but it doesn't look like they have any of the 76mm cables as Dellorto no longer makes the part. The Carburetor Shop has the 73mm cables and I will give them a call this morning, but I'm not sure if that 3 mm difference is an issue. I have one carb with a fraying cable which I've trimmed but it would be nice to have a spare in case it goes south.
d_for_Dellorto_PHF_ carburetors.html" class="bbc_link" target="_blank" rel="noopener noreferrer">https://www.dellortoshop.com/contents/en-us/p1544_(18)_Internal_Cable__Ro d_for_Dellorto_PHF_ carburetors.html
Offline spmoto
« Reply #3 on: May 13, 2020, 10:08:47 AM »
You can always convert to flat tops which I did once upon a time.
Offline bodine99
« Reply #4 on: May 13, 2020, 10:28:36 AM »
www.barnettclutches .com ventura cal. may be able to duplicate yours.
« Reply #5 on: May 13, 2020, 10:32:30 AM »
No, I want to keep it stock.
This being my first bike with these carb tops, I think it is easier to deal with the cables than the flat top carbs. The pull does seem a bit stiffer but not a huge difference than the flat tops.
« Reply #6 on: May 13, 2020, 10:33:42 AM »
Yes, they are the last resort if the 73mm cables won't work.
Rough Edge racing
« Reply #7 on: May 13, 2020, 06:13:06 PM »
   I often fabricate cables, parts are available online from Flanders...Its kinda fun once getting past the frustration of so may little pieces and measurements...
