Author Topic: 98 EV passenger seat install  (Read 1275 times)
Offline steven c
« on: May 18, 2020, 01:18:24 PM »
 My 98 EV came with a Corbin seat which is very comfortable but the passenger seat area is smaller then stock so since I seen to have a lot of free times I thought I would mess around with the stock seat that Steve Rossi gave me. There are 4 brackets to mount it to the bike. The front two from what I can figure out mount behind the shocks, the rear look like they should mount on the racks mounting point but the slot on the seat bracket seems to narrow. Of course I think I have them on the seat correctly going by the marks on the seat. Anyone have a photo of under the seat? I'll take some photos.
« Last Edit: May 18, 2020, 01:23:49 PM by steven c »
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
Offline steven c
Re: 98 EV passenger seat install
« Reply #1 on: May 18, 2020, 01:33:29 PM »
Never mind. They mount to the outside of the shock and just rest on the rack mount.
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
Offline larrys
« Reply #2 on: May 18, 2020, 01:36:06 PM »
On my Cal the front brackets mount outside of the shock, inside of the rack. Might be different on EVs.
Larry
'13 Monster 1100 EVO
'95 Cal 1100
'68 Bonneville
MGNOC 7248
Offline steven c
« Reply #3 on: May 18, 2020, 02:21:52 PM »
Thats how these on my 98 ended up. Made sense once I got the mounts mounted correctly.
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
Offline Zoom Zoom
« Reply #4 on: May 19, 2020, 08:38:52 AM »
When you say they just rest on the rack mount, nothing just rests on anything. The rear mount slots into the back by loosening up the bolts that extend out into the rack from under the fender. The back seat is solidly mounted on all 4 points.
As for the shock location, I believe the brackets may be turned around. I don't recall needing to lift off the back seat to mess with the shocks. I **think** the seat bracket goes behind the shock but it has been a while so I could be wrong.
John Henry
Offline steven c
« Reply #5 on: May 19, 2020, 06:02:41 PM »
 I did loosen the the rear rack mounts got zero clearance to slip in the seat bracketand the radius on the metal (not sure what to call it)part between the rack and fender was a perfect fit,so look right to me.The way you describe the front mounts makes sense . I'll have to check again.
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
Offline Zoom Zoom
« Reply #6 on: May 20, 2020, 06:42:34 AM »
Okay, I went back and looked at your pics. I think the front is right as long as the mounting brackets ended up in the same position on the seat as your first picture.
I am 100% certain the back doesn't simply rest on there. There are enough EV's out there that use that same setup that perhaps someone reading this could post a pic of where those brackets slot in at the rear.
John Henry
Offline steven c
« Reply #7 on: May 21, 2020, 07:06:01 AM »
It may not be right but it looks like it is mounted okay
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
Offline Dharma Bum
« Reply #8 on: May 21, 2020, 09:50:51 PM »
ZoomZoom is correct,  they slip over the bolt that holds the rack in place, loosened up from inside the fender.
