Author Topic: Guzzi breather plumbing  (Read 1352 times)
Offline F-22
« on: May 26, 2020, 05:47:10 AM »
The way Guzzi routed all the breathers always bothered me a little. Especially on my T5 where the main breather line has two sharp curves to reach the inlet on the frame, and the big tube tends to pinch really easily. At first I only wanted to change that main line, but I ended up doing all of them.
For the main line, I simply used real 18mm plumbing copper tubing, with sharp machine-made 90 degree elbows.
For the rest, I used some spare (refrigeration?) bendable copper tubing. You can't bend it as sharp, but still much better than a rubber tube.
Now I'm thinking about perhaps doing something similar with the fuel lines too (depends on how well I'll be able to route them).
I love how little space it all takes now.
Offline bigbikerrick
Re: Guzzi breather plumbing
« Reply #1 on: May 26, 2020, 06:09:20 AM »
Nice work, F 22! That should last forever!
Rick.
Offline Two Checks
« Reply #2 on: May 26, 2020, 07:18:57 AM »
Now ya gotta keep em polished...
1987 1000 SPII "Il Duce' II"
Offline F-22
« Reply #3 on: May 26, 2020, 07:34:29 AM »
Yeah, I hope they don't get that nasty green copper patina (though they probably will). Sometimes it just turns very dark/black. This is why I considered chroming them... But with the fuel tank on, they're hardly visible, so I don't think I'll do anything more to them for now.
Offline n3303j
  • Ron Cichowski
« Reply #4 on: May 26, 2020, 07:42:05 AM »
Steam Punk Guzzi. All you need is a couple of big brass dial gauges (temp & pressure maybe) coming off those lines and you are set for a week at Burning Man.
Hope vibration Isn't your undoing.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline F-22
« Reply #5 on: May 26, 2020, 08:49:38 AM »
There's still ~2cm of a rubber hose connection between the copper and the engine/frame fittings, and I "dressed" the sections of copper which would rub against stuff in rubber (those zip-tied sections of rubber are just to hold it on, there are no connections underneath).
I think I shouldn't have a problem. Pre-WW2 bikes did have problems, but they did not use any rubber sections, just copper with usually some coils/windings to relieve stress. The loop frame Guzzis didn't even use any such coils/windings on the steel cylinder head oil lines, but those did eventually make stress fractures and cracked.
